GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
37 registered members (1WildPig, c502cid, 1991AirCooled, Bailes1992, Buzzsaw, 4 invisible), 683 guests, and 37 spiders.
Topics290,964
Posts4,853,467
Members66,063
Most Online3,590
Jan 24th, 2017
Correct tire pressure? #4575589
11/15/17 11:33 PM
11/15/17 11:33 PM
IL
lukejo Offline OP
lukejo  Offline OP
IL
2009 Chevy Silverado 2500HD, gas, 17" on Z71 package. Sticker on door jamb is missing, don't see a chart in owners manual specifying for the 17". New Michelin Defenders but same size as the 17" OEM...also same 'E' load rating. Never paid much attention to the old tires, but tire shop (per TPM) set these at high 40's front and mid 60's rear. Where is the best place to get a definitive answer? Dealership?
Re: Correct tire pressure? [Re: lukejo] #4575632
11/16/17 12:56 AM
11/16/17 12:56 AM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
My dad had an 04' Duramax and it called for 55 front 80 rear. But when not towing you could probably put the rears at 65 for a better ride.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Correct tire pressure? [Re: lukejo] #4575644
11/16/17 01:38 AM
11/16/17 01:38 AM
Nevada, USA
gaijinnv Offline
gaijinnv  Offline
Nevada, USA
The 2012 issue of the Tire Guide ( 2012 Tire Guide ) has the following:
2009 Silverado 2500 HD 4x4 Crew Cab Std. Box (LT/LTZ) Z71 Pkg.: LT265/70R17/E 121/118Q 65psi Front / 80psi Rear
or
2009 Silverado 2500 HD 4x2 Crew Cab Std. Box (LT/LTZ) Z71 Pkg.: LT265/70R17/E 121/118Q 65psi Front / 80psi Rear
HTH
USN NAVSECGRU 1970-1974
Re: Correct tire pressure? [Re: lukejo] #4575692
11/16/17 06:20 AM
11/16/17 06:20 AM
IL
lukejo Offline OP
lukejo  Offline OP
IL
Great--thanks!! I'll make adjustments today.
I don't tow during the coldest winter months so will probably keep the year at 65?
That would surely be okay if 65 is correct for front?
Re: Correct tire pressure? [Re: lukejo] #4575701
11/16/17 06:36 AM
11/16/17 06:36 AM
new jersey
hemitruck Offline
hemitruck  Offline
new jersey
I would think that the pressure could go lower in front and rear when riding empty. As to how much lower, I go by how the truck feels and do the chalk test.
Re: Correct tire pressure? [Re: gaijinnv] #4575721
11/16/17 07:21 AM
11/16/17 07:21 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
or
HTH
Require account to access the site.
Mind sharing a screen shot here ?
Re: Correct tire pressure? [Re: hemitruck] #4575745
11/16/17 08:23 AM
11/16/17 08:23 AM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
Chalk test, could you please explain? I put my snowies on my truck the other day and have them all at 38 PSI. I was considering 35 but with winter fast approaching I figure they will be close to that anyways soon.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum for all 3.
Re: Correct tire pressure? [Re: lukejo] #4575760
11/16/17 08:41 AM
11/16/17 08:41 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
If you tow or haul often you'll need to compromise, but most pickups (especially diesel) are going to be heavier in the front than the rear. Couple that with the greater propensity of front tires to wear the shoulder of the tread in turns, and I run my fronts higher than the rears on my C3500. Firestone Transforce A/T's rated for 80 PSI and I run them about 60/55 unless I'm hauling something heavy. If you can find a load/inflation chart for your tires you can take that and the weight/balance of your truck and do the math.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: Correct tire pressure? [Re: zeng] #4575870
11/16/17 10:34 AM
11/16/17 10:34 AM
Nevada, USA
gaijinnv Offline
gaijinnv  Offline
Nevada, USA
or
HTH
The link is to the site where you can purchase the Tire Guide book ... like I did.( Online Store )
No screen shots, sorry.
HTH
