Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
91 registered members (2015_PSD, Aero540T, AdditiveOCD, 77GrandPrix, 928, 2004tdigls, 8 invisible), 1,369 guests, and 41 spiders.
Topics297,006
Posts4,963,319
Members67,013
Most Online2,821
Jan 21st, 2019
bypass oil line #4575568
11/15/17 09:58 PM
11/15/17 09:58 PM
AZ
ron17571 Offline OP
ron17571  Offline OP
AZ
Hi! I have been trying to figure out how to run a line from my T On the oil pressure sending unit to a remote filter setup.I see no 1/8 inner diameter oil lines out there. I have found many stainless lines for a turbo.bUt they use AN lines and I am not sure they will fit my filter mount that has 1/2 inch NPT. I do have npt fittings that fit the remote mount and provide a 1/8 barb for a line.I do admit to being a bit confused. The T on the oil pressure sending unit has 1/4 inch hole that another barb fitting fits onto.I will use an adapter to make it so an Amsoil bp 90 will fit on. If I can find a line I can have my bypass setup for around a hundred bucks.
I do think the AN fitting would be the best.I just don't get the size and fitting needed. sorry to babble on.Ideas?
2003 Dodge Caravan 140.000 miles
1992 Ford f-250 217,000 miles
Re: bypass oil line [Re: ron17571] #4575574
11/15/17 10:08 PM
11/15/17 10:08 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Any big NAPA Auto Parts store can make up any length line you want. NPT is not an issue. Plenty of line fittings in NPT smile
Re: bypass oil line [Re: ron17571] #4575612
11/15/17 11:16 PM
11/15/17 11:16 PM
Maryland USA
rubberchicken Offline
Maryland USA
I had a similar problem on my Suburban. Rather than mess with cutting lines, finding fittings etc., I just bought the entire Amsoil bypass filter kit. The adapter goes where the stock oil filter fits, and it was a 99% bolt on affair. I drilled 2 holes in the plastic 2nd battery tray to hold the assembly, so both filters can be changed without lifting / raising the truck.
The truck itself looks like garbage due to the late 90's poor paint quality, but the bypass filter assembly has worked fine since installed in 2000.
Re: bypass oil line [Re: ron17571] #4576287
11/16/17 04:35 PM
11/16/17 04:35 PM
On the road Midwest
Ihatetochangeoil Offline
On the road Midwest
I don't remember the specs on this line; but I called the manufacturer and questioned its suitability to hold oil pressure and engine compartment temperatures...It works fine; it is easy to cut with a utility knife and is almost as flexible as heater hose, assembles easily onto push loc (proper spelling for the application) fittings. Push loc fittings are available in adapters and various shapes and sizes on eBay.
https://www.ebay.com/itm/Blue-4-AN-1-4-P...nt/263321827446
Here is the hose and fittings under my hood on multiple bypass filters in series:
Here are some fittings: https://www.ebay.com/itm/PRE-20400-4-AN-...ok/331180463646
https://www.ebay.com/itm/4-An-90-Degree-Hose-End-Push-Lock-Tite-Fitting-Jic/311761434094
If you prefer, Amsoil sells a pretty good selection of line and various fittings: https://www.amsoil.com/bypassfilters/partslist.aspx
Amsoil and all the push lock fittings are easy to cut with a utility knife and assemble onto the fittings with a drop or two of oil and you're ready to go. Hope this helps you.
Whatever
Re: bypass oil line [Re: ron17571] #4576614
11/16/17 10:05 PM
11/16/17 10:05 PM
AZ
ron17571 Offline OP
ron17571  Offline OP
AZ
I looked at the push loC fittings.They look good and make me nervous with the whole no clamp thing.But i could not find any 1/8 fittings. I don't think 1/4 would offer enough restriction. All the push loC fittings seem to be female. Do the push loC fittings match up to NPT?
Re: bypass oil line [Re: Ihatetochangeoil] #4577455
11/17/17 07:58 PM
11/17/17 07:58 PM
AZ
ron17571 Offline OP
ron17571  Offline OP
AZ
i have looked and figured out how to make the smallest size fit.an-4.Using an adapter that goes from NPT to AN. So this is 1/4 inch line. 1/8 Just wasn't going to happen.Curious how you mounted up a restriction in the line? I think 1/4 inch would flow to much/fast for a bypass.
Re: bypass oil line [Re: ron17571] #4591507
12/01/17 09:11 PM
12/01/17 09:11 PM
On the road Midwest
On the road Midwest
Ron I'm sorry for a delayed response but I did not see your last post. To answer your question, there is no restrictor in the lines. The restrictors are built into the inlets of the bypass filters, by the manufacturers. You can also find restrictors of different sizes on eBay by searching for "turbo oil restrictors." https://www.ebay.com/sch/i.html?_from=R4...amp;_sacat=6028
Whatever
Re: bypass oil line [Re: ron17571] #4684338
03/04/18 05:25 PM
03/04/18 05:25 PM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
AN lines, fittings, and AN to NPT adapters. No affiliation, just like one stop shopping.
Bypass Tubage and Accoutrement
beanoil: Tough under heat, real dirty afterwards.
Re: bypass oil line [Re: ron17571] #4685454
03/05/18 05:57 PM
03/05/18 05:57 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: ron17571
I see no 1/8 inner diameter oil lines out there. Ideas?
I use 1/8" oil pressure gauge tubing for my bypass oil filter.
