Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
94 registered members (aquariuscsm, 55hambone, Armkb, Ag76, 77GrandPrix, anndel, 12 invisible), 1,868 guests, and 33 spiders.
Topics290,955
Posts4,853,176
Members66,062
Most Online3,590
Jan 24th, 2017
Block heater input jack #4575547
11/15/17 10:32 PM
11/15/17 10:32 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
I recently made a mount for a Noco GCP1 AC input jack on my 2003.
This is a recent pic of my '03 after the GoRhino install.
Heres a pic of the Noco input jack
So I decided I wanted to mount that jack onto the push bumper and thought of a few ways. Drilling a hole straight through the steel and have it out the side was one, but would permanently alter it. Also, would damage and remove the powder coat. I pretty much wanted to mount it some way that was removable and would not modify the GoRhino.
So that meant making a mount that would attach the plug to the GoRhino.
This is what I came up with. Pretty much a box with a hole in it the cord goes through. This was finished prodect, just before paint. You can see Im bolting through the side plate, but Im using a already existing hole. Then I have a piece of 2x1/8 stock going down to the bottom 1/2" bolt to support it there. The whole thing is 2x and 3x1/8" flat stock. It was very nice that the 3" wide stock was pretty much the ideal size for it. Very overkill, very solid. Does not give when you are pushing the cord into the jack.
And finished, put together and in use. I did upgrade the supplied bolts with the Noco part to stainless with some shopping at lowes. The one negative about it, I think is the steel bolts it comes with. Easy to fix, though.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: Block heater input jack [Re: Colt45ws] #4575561
11/15/17 10:40 PM
11/15/17 10:40 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Looks like a former WSP car!
Cool setup by the way.
2004 Corolla 124831
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Block heater input jack [Re: Colt45ws] #4575605
11/16/17 12:01 AM
11/16/17 12:01 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Neat job. If you pulled up behind me, my foot would lift off the gas in an almost involuntary action grin2
Coming home in the wee hrs on the Mass Pike. If I saw a set of headlights approaching rapidly, I would go into the far right lane and coast down to 70. In a half minute a Panther would roll past in the left lane doing upwards of 80. grin2
Thick oil is better grin2
Re: Block heater input jack [Re: Colt45ws] #4576520
11/16/17 09:18 PM
11/16/17 09:18 PM
In the Garage...
ls1mike Offline
ls1mike  Offline
In the Garage...
Looks good man!
Mike
00 Trans Am WS6 5.7 LS1
02 Silverado 2500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Block heater input jack [Re: Colt45ws] #4576534
11/16/17 09:28 PM
11/16/17 09:28 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
That's really cool! That kind of plug would work good for a car that sits a lot or over winter, could install a battery maintainer and plug in simple with that.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Block heater input jack [Re: Colt45ws] #4576575
11/16/17 10:15 PM
11/16/17 10:15 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
I didn't know that existed. That is the solution to my block heater needs. Thanks thumbsup
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Block heater input jack [Re: Nick1994] #4576668
11/17/17 02:37 AM
11/17/17 02:37 AM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
Yes. I actually have one on my '02 as well, and since its out of commission waiting for an engine, I disconnected the block heater and plugged in a battery maintainer. Since its sitting outside, I tucked everything under the hood and shut it.
On that car, the bumper cover has a big tear in it, so knowing it looks bad anyway, I just drilled a hole right into the bumper cover and mounted it that way.
Glad you like it Stevie! I got into an argument with a Canadian on a Panther-centric FB page over this plug. He said he'd never seen anything like it and it was stupid overkill, unnecessary.
Maybe, yes, but I like it. Its pretty much sealed when not in use. Ive never seen water in it. There is a drain hole to let water out, but you'd still see moisture on the inside if it was getting in.
I can plug and unplug one handed. Which is nice if you are carrying something to the car. Just grab and pull, put the cord away and close the lid. Opposite for coming home.
-Colton
Re: Block heater input jack [Re: Colt45ws] #4576871
11/17/17 10:03 AM
11/17/17 10:03 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
Facebook can be quite the place. I don't belong to many groups any longer because it seems to only attract people that want to argue. Anyway on my next vehicle I will install one of these for sure because every vehicle I have had where the cord dangles out by the head-light it has scratched the headlight because of it flopping up/down with regular driving and I'm not about to pop the hood each time to put it away. Plus I also like to keep my battery on trickle charge overnight so the dash cam is recording in parking mode and this would be ideal for that too. I will just put a switch to allow me to only run the charger or the charger and block heater. (Waterproof connections and switch of course)
Re: Block heater input jack [Re: Colt45ws] #4577243
11/17/17 05:21 PM
11/17/17 05:21 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I don't care what anyone says; I like it, too.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Block heater input jack [Re: StevieC] #4577542
11/17/17 10:09 PM
11/17/17 10:09 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
Thats a good idea with the switch. I'd like to see that when its done.
-Colton
