Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
ariefnrst, tcoffin014, Schm1d, EagleC, Dinka
66655 Registered Users
93 registered members (BigShug681, badtlc, aquariuscsm, bfleeman, biodiesel, 11 invisible), 1,570 guests, and 36 spiders.
Topics294,970
Posts4,925,084
Members66,655
Most Online2,553
Oct 27th, 2018
2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k #4575322
11/15/17 06:05 PM
11/15/17 06:05 PM
MINNESOTA
GRIMland Offline OP
GRIMland  Offline OP
MINNESOTA
2014 Chevy Cruze Eco 6MT. First time UOA, collected sampled after 75mi drive @ ~45degF, collected during drain. Oil history was factory fill, Pennzoil PPP (2x). Blackstone said universal averages on this engine are 7k, since I'm half that I would hope to see half the copper, but that wasn't the case. Everything else was about in line with half the universal averages. I use fuelly for all fill ups and have a lifetime avg mpg of 45.5. I store the car in winter, so that's why I run the oil for a year and change it before winterizing. Stock car setup, original air filter and I use the OEM oil filters (ACDelco PF2257G).
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: GRIMland] #4575327
11/15/17 06:08 PM
11/15/17 06:08 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Look at those Iron and silicon numbers.
2004 Corolla 126649
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: GRIMland] #4575350
11/15/17 06:23 PM
11/15/17 06:23 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
So, I am reading that right, they are suggesting a longer drain interval even though the oil has been in use a year?
Does that old adage still not apply, X number of miles or one year, whichever comes first? shrug
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: GRIMland] #4575379
11/15/17 06:44 PM
11/15/17 06:44 PM
MINNESOTA
GRIMland Offline OP
GRIMland  Offline OP
MINNESOTA
EDIT: The oil history I listed is wrong, I had a brain [email protected] The first 4 oil changes within 2 years were free, I only did 3 within that 2 years, forgot about that.
So it was:
FF
Chevy dealer fill 5w-30 (dino I believe) 3x
Pennzoil PPP 5w-30 2x
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: irv] #4575425
11/15/17 07:29 PM
11/15/17 07:29 PM
DFW
JustN89 Online content
JustN89  Online Content
DFW
I really don't think age is as much of an issue any more. There's a report on here which was posted not that long ago where 10 year old oil was tested and it was still in pretty good shape, all things considered. Any more, I believe mileage and type of driving is more important.
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: JustN89] #4575711
11/16/17 06:06 AM
11/16/17 06:06 AM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
10 yr old oil sitting in a jug on the shelf, unused, or 10 yr old oil that was run through an engine for that long?
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: GRIMland] #4575744
11/16/17 07:21 AM
11/16/17 07:21 AM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
Good report - you can easily go two years between changes if you stick with PP and continue with the low mileage routine - just keep it topped off. If you are worried about a warranty claim problem, just stick with your annual change. My 2013 Dart likely won't see an oil change for 3 or 4 more years. I've only put about 1000 miles on it in the last 15 months since the last change - it also uses PP.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: bigt61] #4575764
11/16/17 07:45 AM
11/16/17 07:45 AM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
Not that I'll likely ever do that with the amount of miles we do, but I thought even the oil analysis guys would still recommend an annual oil change despite the amount of miles that are on the oil?
I guess they can obviously see those things so they likely wouldn't recommend extending one's drain interval if they thought harm could be done. Interesting. Thanks for the info. Cheers2
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: GRIMland] #4575790
11/16/17 08:22 AM
11/16/17 08:22 AM
MINNESOTA
GRIMland Offline OP
GRIMland  Offline OP
MINNESOTA
With the 2017 Pennzoil rebate on a 5 qt jug of 5w-30 at walmart, which was I believe $12, I ended up only paying $10 for the oil plus I get the oil filters for free on amazon (I get amazon gift cards using bing rewards) so it's cheap peace of mind for me. The UOA was the most expensive part! smirk
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: irv] #4575824
11/16/17 08:57 AM
11/16/17 08:57 AM
DFW
DFW
It was 10 years old, used oil. If I remember right, they drew it from an engine that had been sitting for quite some time.
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: JustN89] #4577779
11/18/17 07:11 AM
11/18/17 07:11 AM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
I assume they had no idea how many miles were on the oil? I assume, the old, no matter how many miles are on it, if one year is up, it should be change annually, no no longer applies? I also assume they, if true, are talking about synthetic oils and not dino oils?
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: irv] #4578028
11/18/17 01:10 PM
11/18/17 01:10 PM
DFW
DFW
Here's the thread
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: JustN89] #4578258
11/18/17 06:53 PM
11/18/17 06:53 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
Here's the thread
Good to know.
Thanks for posting it up. Cheers2
Re: 2014 Chevrolet Cruze Eco 6MT Pennzoil PPP 3.5k [Re: GRIMland] #4585889
11/26/17 05:00 PM
11/26/17 05:00 PM
Great White North.. eh
webfors Offline
webfors  Offline
Good report. Thanks for posting.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w20, Fram DL11665
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
