2015 Chevy Sonic LS Automatic 1.8l - Drain Plug
Texas
Drained the oil yesterday . Wished to replace the rubber gasket on the drain plug .
All the online parts places list the drain plug as 14 -1.5 . Wrong , it is 12 - 1.75 .
O'Reilly store in town found the gasket for me . :)
Best wishes , :)
I was experiencing a leak , either at the oil filter plastic " cap " or at the drain plug . I was trying to be pro-active .
Thanks , :)
I figured it was just an o-ring . No , it was a " flat " rubber washer . We will see how well it works ......
Originally Posted By: bigt61
Drain plug washers are the one thing I always get at the dealer.
+1 or you can buy in bulk online OEM for less.
Is the sonic the car with the 10 or 12mm bolt and it's straight up and down? If so I have rounded so many of those off at Walmart. Those bolts are made of some super soft metal. We always replace them with a dorman plug, they never strip like the OEM ones.
