The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
39 registered members (alcyon, berniedd, avi1777, 928, 555, aleneros, 1 invisible), 593 guests, and 65 spiders.
Topics286,097
Posts4,902,483
Members67,560
Most Online2,967
Mar 10th, 2019
Easy apartment parking lot oil change #4574961
11/15/17 02:06 PM
11/15/17 02:06 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
I am reveling in my victory as I finished the easiest, cleanest oil change I've ever had in an apartment parking lot.
I've always done my own oil changes, all the way back to when I was 16. Since I've lived in apartments though, I've dreaded doing it because I didn't have the comfort of a garage to do it in. I was exposed to the elements, namely the wind, which always seemed to play a role in me making a mess. Last oil change, however, I installed a Fumoto drain valve with the idea that I could hook up a hose to it and drain it right back into the oil jug. Well, I just finished the first oil change since installing it and I didn't spill a drop.
While it did take a fair bit longer, and I didn't replace the filter (an Ultra with 5,000 miles on it), I can definitely say that this made the process a much more clean and enjoyable experience.
Also, since this is BITOG, the oil that went in was QSUD 5W-20, replacing the QSUD 5W-30 that went in 5k miles ago. Since I didn't replace the filter, I guess the concoction is a 5W-25. grin
Re: Easy apartment parking lot oil change [Re: JustN89] #4574968
11/15/17 02:12 PM
11/15/17 02:12 PM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
Good work! I imagine a car with a top side filter would make apartment changes easy. Use a fluid extractor, then just pull the filter. I know what you mean though, its tough at apartments. From what I've heard people with home owners associations have it bad also.
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: Easy apartment parking lot oil change [Re: JustN89] #4574970
11/15/17 02:14 PM
11/15/17 02:14 PM
out there
spasm3 Offline
spasm3  Offline
out there
Nice and clean, do it at night and they will never know!
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Easy apartment parking lot oil change [Re: JustN89] #4574976
11/15/17 02:18 PM
11/15/17 02:18 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
What's inside diameter of the hose that fits on the Fumoto ?
Re: Easy apartment parking lot oil change [Re: Merkava_4] #4574984
11/15/17 02:22 PM
11/15/17 02:22 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
3/8", I do believe.
Re: Easy apartment parking lot oil change [Re: HemiHawk] #4574990
11/15/17 02:24 PM
11/15/17 02:24 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
I have a bottom side filter, but fortunately it is completely vertical. Next oil change, I'll put a gallon sized ziploc bag around the filter and unscrew it inside the bag. Hopefully, it will all drain into the bag and I can just zip it up and take it to the recycling center along with my used oil. All in the name of no messes! banana
Re: Easy apartment parking lot oil change [Re: JustN89] #4575003
11/15/17 02:35 PM
11/15/17 02:35 PM
Canada
i_hate_autofraud Offline
Canada
Yeah! The wind outdoors can blow draining oil all over the place!
I'm used to laying out newspaper under the drain pan to be sure no spills on the driveway!
In the past I'd put a big card board against the side of the car to block the wind!
I guess you slide off the hose when you're done?
Re: Easy apartment parking lot oil change [Re: JustN89] #4575013
11/15/17 02:41 PM
11/15/17 02:41 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
That looks Nice! With less of a mess...
approved
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: Easy apartment parking lot oil change [Re: i_hate_autofraud] #4575026
11/15/17 02:50 PM
11/15/17 02:50 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
Yeah, I moved the hose around to get the air pocket that formed when it was about done draining to move to the top, then slid the hose off and held it up so that it would finish draining into the jug.
It is a 4.23 quart sump, and I drained out a little over 3.5 quarts. I'm not sure what the capacity of the Fram Ultra filter is, however. I figured that it didn't quite get everything, but I keep my intervals short enough that I'm not too concerned about it.
Re: Easy apartment parking lot oil change [Re: JustN89] #4575035
11/15/17 03:02 PM
11/15/17 03:02 PM
Chicago,IL,USA
pandus13 Offline
pandus13  Offline
Chicago,IL,USA
Originally Posted By: JustN89
... Next oil change, I'll put a gallon sized ziploc bag around the filter and unscrew it inside the bag. Hopefully, it will all drain into the bag and I can just zip it up and take it to the recycling center along with my used oil. All in the name of no messes! banana
Can I borrow this idea from you?
This was the only thing missing from my stealth nightly garage HOA oil extractor changes....
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Easy apartment parking lot oil change [Re: pandus13] #4575067
11/15/17 03:39 PM
11/15/17 03:39 PM
DFW
JustN89 Offline OP
JustN89  Offline OP
DFW
Haha, well I haven't tried it yet so I can't speak for its effectiveness. It works in theory though!
Re: Easy apartment parking lot oil change [Re: JustN89] #4575196
11/15/17 05:13 PM
11/15/17 05:13 PM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
I also have a vertical oil filter that sits under my engine.
When changing the filter I have an old protein powder container I carefully drop the
used filter into and the remaining drips from the engine also go into the container. After it's finished dripping, I fist out the old filter and toss it into a plastic produce bag and dispose of it at an oil recycling facility.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Easy apartment parking lot oil change [Re: JustN89] #4575240
11/15/17 05:58 PM
11/15/17 05:58 PM
iowa
Traction Offline
Traction  Offline
iowa
Reminds me of the days when I was in the Navy changing the oil on my 427 69 Corvette using a tall curb for a ramp on one side. Worked pretty good for lots of undercar work using the terrain as needed. Changed starters, fuel pumps, etc. doing it that way. Got kicked off the base hobby shop because my car was too loud, and had to wing it for awhile.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Easy apartment parking lot oil change [Re: i_hate_autofraud] #4575241
11/15/17 05:59 PM
11/15/17 05:59 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
I lay a piece of cardboard about 4'X 6' under the car and do everything on top of that. It's a bit softer than pavement, keeps my clothes cleaner and it catches the little bits of oil that blow around. Never seems to get too oily either, so there must not be that much oil blowing around.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: Easy apartment parking lot oil change [Re: i_hate_autofraud] #4575244
11/15/17 06:00 PM
11/15/17 06:00 PM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
I use old pizza boxes to put the pan in. After I'm done I wipe it off and into the recycle bin it goes.,,
