Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
79 registered members (928, -SyN-, Aero540T, 2010Civic, Al, 2002 Maxima SE, 4 invisible), 1,325 guests, and 27 spiders.
Topics290,811
Posts4,850,834
Members66,040
Most Online3,590
Jan 24th, 2017
Page 1 of 9 1 2 9
Ballistol #4574784
11/15/17 11:08 AM
11/15/17 11:08 AM
Cajun Country, La.
BlueOvalFitter Offline OP
Cajun Country, La.
Is Ballistol really as good as people claim it to be? shrug
Re: Ballistol [Re: BlueOvalFitter] #4574789
11/15/17 11:12 AM
11/15/17 11:12 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
No. Its mediocre at best as a cleaner, mediocre at best as a lube. Basically, bypass it and find no need for it, unless someone gave you a can for free, in which case you can use it up, since it was free.
I have a can of it and I have no idea what to do with it, since it wont touch my guns. The more modern stuff is just so much better.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: Ballistol [Re: BlueOvalFitter] #4574793
11/15/17 11:18 AM
11/15/17 11:18 AM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
If you had to hit it real quick to get back out on the street. Other than that, I pretty much agree with Bubba.
Re: Ballistol [Re: BlueOvalFitter] #4574823
11/15/17 11:35 AM
11/15/17 11:35 AM
Southern Oregon, USA
sdude2k2000 Offline
sdude2k2000  Offline
Ballistol is actually very good at being a CLP as designed, but I agree there are better products out there nowadays (especially for Modern Sporting rifles like AR, AK, etc)... and it's isn't all that cheap. Hoppes 9 bore cleaner (my preferred bore/barrel solvent) is MUCH faster at cleaning. Apply, agitate, wipe... good to go. if it's super dirty, a second application or extra elbow grease on agitation makes it clean enough by my standards. Something like Ballistol requires you to spray, walk away for five minutes, agitate, wipe, see how it looks, perhaps repeat all over again. As a lubricant, I think it depends on the application. For an MSR, they get so dang hot that something like Ballistol will flash off pretty quick since it's primary lubricant is just basic mineral oil... meaning you'll need to be reapplying fairly consistently. For hunting rifles, revolvers, etc... it would work just as well as just about any other lube in my opinion (lower rate of fire = lower heat). As a protectant - it works great for me. Just keep the firearm wiped down a few times here and there... no rust.
On a side note - it's also non-toxic and biodegradable (if that's important to you), so it can be used on more things than just a firearm. I use it on my gardening tools, gardening leather gloves, lawnmower, etc. Does a great job keeping the parts lubed and rust free.
I guess to summarize - if a basic CLP is what you're looking for, Ballistol will work every bit as well of just about any other basic CLP. There are "better" options out there for sure, but diversity of use and non-toxic nature is worth enough to me to keep a can of it around. CLP's by design are a "one stop shop"... which by nature will be "good" at everything, but often not "great" at anything.
'08 Ford Fusion SEL 3.0L
'15 Toyota Prius 1.8L
Re: Ballistol [Re: BlueOvalFitter] #4574837
11/15/17 11:44 AM
11/15/17 11:44 AM
Cajun Country, La.
Cajun Country, La.
When I must use a CLP I use Grizzly Grease.
http://grizzlyguncare.com/grizzly-grease-non-toxic-clp-4-fl-oz/
Re: Ballistol [Re: bubbatime] #4574849
11/15/17 11:55 AM
11/15/17 11:55 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
Originally Posted By: bubbatime
No. Its mediocre at best as a cleaner, mediocre at best as a lube. Basically, bypass it and find no need for it, unless someone gave you a can for free, in which case you can use it up, since it was free. I have a can of it and I have no idea what to do with it, since it wont touch my guns. The more modern stuff is just so much better.
This ^^^^^^^^^^^^^^
Ballistol is basically mineral oil. The MSDS will confirm that.
http://www.ballistol.com/wp-content/uploads/2013/09/MSDS_TECH_BIO.pdf
"Ballistol is based on medicinal grade white mineral oil"
If you still like the idea of using mineral oil to clean, lubricate, and protect your firearms, you can buy it much cheaper than Ballistol sells it for with they're name on it. And it will also double as a laxative the next time you get constipated. Be advised that you'll have to add your own licorice scent to it however. It's also available.
https://www.walmart.com/ip/Equate-Minera...13=&veh=sem
https://www.naturesgardencandles.com/black-licorice-fragrance-oil
Re: Ballistol [Re: BlueOvalFitter] #4574890
11/15/17 12:45 PM
11/15/17 12:45 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I'm not a big believer in an all in one CLP. None of us particularly need to worry about living autonomously in the field for days/weeks/months, with limited amounts of stuffed can carry.
Ballistol is relatively good because it does clean, it does protect against corrosion, and it does lubricate. It's also relatively safe on wood, and non toxic for parts to be readily handled.
There are relatively better oils and greases for high friction/high wear points. Other than a few odd spots, ballistol has worked fine for corrosion protection. It also works well enough as an interim cleaner, as I'm not keen on running brushes too often, or strong solvents. A few patches with ballistol (sometimes following a first patch with hopped elite or butch's bore solvent) works great and leaves behind a protective film.
I like ballistol for what it is. I also use it to coat hand tools that are prone to surface rust. Works great there too, and zero concerns regarding subsequent skin contact.
Re: Ballistol [Re: BlueOvalFitter] #4574983
11/15/17 02:21 PM
11/15/17 02:21 PM
Cajun Country, La.
Cajun Country, La.
Call me crazy, but another product I like to use, not just on my firearms, is KROIL.
Before moving to Tampa, FL in 1987, I was working A LOT of shutdowns and turnarounds in the Petro plants throughout Louisiana. AEROKROIL (KROIL) was used on EVERYTHING. I had NEVER used a penetrant, lubricant, and cleaner like KROIL before. They used to pass it out to us like it was candy. Like I stated, USED TO.
One of my cousins is an engineer for EXXON-Baton Rouge. When I need a can he gets it for me. I have never seen any other product like this, work the way it does. If you can afford a small can of it, you should buy one. You won't be let down.
http://www.kanolabs.com
Re: Ballistol [Re: BlueOvalFitter] #4575028
11/15/17 02:51 PM
11/15/17 02:51 PM
ne atlantic coast & sw desert
jstert Offline
jstert  Offline
i actually like ballistol, but i only shoot handguns these days, and dont even own a msr/ar/ak variant. most recently while away from home i put 400 rounds of russian steel ammo through a russian ij70 380acp and used wd40 as an expedient cleaner, all worked just fine.
that said, to blue oval fitter, im keen to try kroil but three variants are listed on kanolabs.com. which one do you suggest?
2013 vw passat s
2014 toyota yaris l
Re: Ballistol [Re: jstert] #4575256
11/15/17 06:11 PM
11/15/17 06:11 PM
Cajun Country, La.
Cajun Country, La.
I suggest either original AEROKROIL-KROIL or SiliKroil - Kroil with Silicone. The latter of the 2 will give you more lubricity.
AMAZON sells KROIL as well.
https://www.amazon.com/s/ref=sr_gnr_aps?rh=i%3Aaps%2Ck%3AKROIL&keywords=KROIL&ie=UTF8&qid=1510787415
Re: Ballistol [Re: BlueOvalFitter] #4575291
11/15/17 06:45 PM
11/15/17 06:45 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
It has a huge following. So it obviously works well. I clean my pistols with it, inside and outside. Works great on wood stocks too. I prefer to lube with Lucas Syn Oil and Superlube grease.
She's the only sister-in-law I have. But she's not my favorite.
Re: Ballistol [Re: bubbatime] #4575449
11/15/17 08:49 PM
11/15/17 08:49 PM
Chadds Ford
Toros Offline
Toros  Offline
Chadds Ford
Yeah, your opinion. But we all know how that goes. I find it works just fine as an all around.Cleans well, lubricates fine. Protect fine in the dhort-medium term. A can will last you a long time.Good value for money.
Re: Ballistol [Re: Toros] #4575480
11/15/17 09:14 PM
11/15/17 09:14 PM
Chadds Ford
Toros Offline
Toros  Offline
Chadds Ford
Yeah, your opinion. But we all know how that goes. I find it works just fine as an all around.Cleans well, lubricates fine. Protects fine in the short-medium term. A can will last you a long time.Good value for money. All that veggie oil based [censored] guns up in short order...Frog Lube for all the wannabe keyboard operators...hahh. what a joke. [censored], I still run with Hoppes #9 Solvent and RemOil or Outers gun oil. All good stuff.
Re: Ballistol [Re: BlueOvalFitter] #4575602
11/15/17 11:59 PM
11/15/17 11:59 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
Oh gawd no, not this again!!!
duh
Do a search and read some of the varying opinions about Ballistol. If it still interests you, try some and draw your own conclusions. My shortened opinion of it is that it is very versatile and will work well enough for most people in most situations. It is not a high tech, high performance, "cutting edge" product of any sort but it will clean and lubricate an average firearm well enough for most average firearm uses. It has a huge following and even people who shoot a fair amount like Hickock45, use Ballistol and it does the job just fine.
18 Honda CR-V - Factory Fill
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Delvac 15w-40
Re: Ballistol [Re: AMC] #4575671
11/16/17 04:43 AM
11/16/17 04:43 AM
Chadds Ford
Toros Offline
Toros  Offline
Chadds Ford
duh
I'd say you summed that up correctly.
Page 1 of 9 1 2 9
