Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
I'm on a Lawn Boy jag
by andyd. 09/18/18 01:13 PM
Old (New) Tires
by ET16. 09/18/18 12:05 PM
iOs 12 for Apple
by madRiver. 09/18/18 12:01 PM
Synthetic oil overrated??
by Ablebody. 09/18/18 12:01 PM
Ferrari Monza SP 1/2
by DeepFriar. 09/18/18 11:58 AM
Any option to "Mark all forums read"
by Rick505. 09/18/18 11:54 AM
1981 280ZX Turbo
by 16HC. 09/18/18 11:12 AM
Muscle car emblems
by Snagglefoot. 09/18/18 10:15 AM
Burn out question
by Fitter30. 09/18/18 10:15 AM
Collector Oil Cans
by Snagglefoot. 09/18/18 10:06 AM
Thoughts on this truck and price.
by ls1mike. 09/18/18 08:39 AM
Canadian Tire Lucas Synthetic Motorcycle Oil 20w50
by Snagglefoot. 09/18/18 07:58 AM
Blast from my past
by 53' Stude. 09/18/18 07:25 AM
Happy Birthday USAF!
by Astro14. 09/18/18 06:35 AM
Ever had a total engine failure?
by Exhaustgases. 09/18/18 02:58 AM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
106 registered members (2010Civic, Analyzer, AndyB, 2009Edge, Ablebody, 15 invisible), 1,797 guests, and 42 spiders.
Topics290,597
Posts4,847,127
Members66,004
Most Online3,590
Jan 24th, 2017
How much does coolant mix with the overflow? #4573937
11/14/17 04:53 PM
11/14/17 04:53 PM
Phoenix, AZ
Nick1994 Offline OP
Nick1994  Offline OP
Phoenix, AZ
This is for my Jeep. I flushed the cooling system out and replaced the radiator, cap, and thermostat. I refilled with 50/50 green coolant and distilled water.
Well, I was in a big hurry a little over a month ago before heading out of town and went to top off the washer fluid and for whatever reason poured it into the coolant overflow bottle. I then unbolted it and poured it into a gallon jug and filled it up with water, I didnít have any coolant with me at the time.
Iíve put about 1,000 miles on it since then, including highway at 75 mph, hard off-road driving, and traffic. So itís been up to temp.
My question is, shouldnít the radiator cap be letting some coolant into the overflow bottle? And then sucking it out? Because whatís in the overflow is still crystal clear and if it was mixing it would be very obvious since itís vibrant green in the radiator. The radiator cap was from OíReillyís and looks like it was made out of a tin can, I really donít like it.
Just wondering if maybe my cap is bad? Thanks.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: How much does coolant mix with the overflow? [Re: Nick1994] #4573953
11/14/17 05:08 PM
11/14/17 05:08 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
It depends on the system. Some flow into the bottle as the car is running at temp, and other systems (usually older) draw/supply via the reservoir to move a small amount of makeup or expansion fluid. I don't have a radiator cap on one of my cars as it has a separate high point vent plug. The "reservoir" (pressurized degas bottle) sits lower. So that exchanges a lot more fluid than my 1999 GM where the radiator sits higher than the reservoir and the reservoir is not pressurized. If your reservoir gets quite hot, it's probably exchanging considerable fluid.
So what's in washer fluid that cause issues with engine coolant?
Consumer advocacy groups and auto enthusiasts believe that the alcohols and solvents present in some, but not all, windshield washer fluid can damage the vehicle. These critics point to the corrosive effects of ethanol, methanol, and other components on paint, rubber, car wax, and plastics, and groups propose various alternatives and homemade recipes[specify] to protect the finish and mechanics of the motor vehicle.
You're not the first one to ever do this. If you google it I'd bet you'd find many interesting anecdotes and findings.
Bloggy
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: How much does coolant mix with the overflow? [Re: Nick1994] #4573974
11/14/17 05:41 PM
11/14/17 05:41 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
So you caught the issue right when you did it? If that's the case, zero washer fluid mixed with your coolant. This isn't your concern right?
Assuming you don't have any obvious issues such as collapsed hoses or overheating, I would say your cap is just fine. I like to think of radiator caps as an oil filter bypass. Who really knows how often they open.
The cap has a warranty right? Swap it out if you're really worried.
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: How much does coolant mix with the overflow? [Re: 69GTX] #4574119
11/14/17 08:06 PM
11/14/17 08:06 PM
Phoenix, AZ
Nick1994 Offline OP
Nick1994  Offline OP
Phoenix, AZ
Bloggy
I wasnít sure if it would hurt it, I was about to put 300 miles on it and was in a hurry and didnít want to risk t so I poured out the overflow and filled with water.
Not concerned about the washer fluid in the reservoir, thatís why I dumped it out and refilled with just water.
The Jeep does run a bit hotter in the summer than Iíd like, wondering if this is the cause.
Iím going to get one from the dealer either way, this Murray capís build quality is like someone formed it out of an aluminum can. Just wondering if anyone thinks the coolant will then flow.
Re: How much does coolant mix with the overflow? [Re: Nick1994] #4574129
11/14/17 08:14 PM
11/14/17 08:14 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
Are you saying you emptied the overflow (because of the mix-up) right after you changed the coolant, and there still isn't any fluid in the overflow tank?
If that's what you're saying, the reason may be that there isn't any overflow. The cooling system could a little short of coolant, as it often is after changing. Seems you don't get all of the air out of the system and it takes a while for it to "burp out". That air "burped out" is replaced by fluid from the overflow, but your overflow has been empty because you didn't have any extra coolant to fill it. In that case you need to put some premixed coolant into the overflow and likely add a bit more over the next few days until you get the cooling system full of coolant again.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: How much does coolant mix with the overflow? [Re: ecotourist] #4574167
11/14/17 08:38 PM
11/14/17 08:38 PM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
I think the system maybe sucked water because he put back the reservoir with water. No big deal for the quantity. On my Yaris qqun the level in the overflow reservoir went down only to replace air that may have been left in the circuit after flushing. Then I went changing the color to see if it mixes up sometimes. Blue instead of red. It only turned dark after being stuck in traffic in a hot sunny day
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealerís overfilled, 16000 Km
Re: How much does coolant mix with the overflow? [Re: Nick1994] #4574222
11/14/17 09:08 PM
11/14/17 09:08 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I'd put some straight coolant into the overflow if there is room. Otherwise don't worry about it. You can have the cap tested to make sure it is holding the correct pressure
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: How much does coolant mix with the overflow? [Re: Nick1994] #4575317
11/15/17 07:03 PM
11/15/17 07:03 PM
ME
eljefino Offline
eljefino  Offline
ME
The methanol from the washer fluid would have boiled off if it got in the real radiator which I doubt it did in any real quantity. No worries.
