Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
Brake Bleeder
by supton
06/20/18 06:56 AM
As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Pennzoil Platinum at Walmart
by TheLawnRanger
06/19/18 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
06/19/18 10:45 PM
What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
101 registered (2009Edge, aquariuscsm, 14ecocruze, badtlc, 15 invisible), 1361 Guests and 30 Spiders online.
65276 Members
67 Forums
285637 Topics
Page 1 of 2 1 2 >
#4573540 - 11/14/17 08:28 AM Battery Chargers - Schumacher, Stanley, Peak
mjk Offline
Loc: Wishin' I was in Wi
Hi,
It seems like the Schumacher brand doesn't get much respect, when doing a past search on this site.
Of those 3 brands (if all are indeed separate companies), which would you choose?
Looking for general charger, have some deep cycle marine batteries to maintain and any impending auto issues.
Thanks.
I currently have an older 6 amp Schumacher manual charger, just want to get something with a minimum of 10 amp charging.
#4573551 - 11/14/17 08:37 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mjk]
440Magnum Offline
Loc: Texas
None of the above, although I still have an old Schumacher and its fine for what it is.
My current pick is a Prologix Solar smart charger/maintainer. Has a very good 7-stage charge/desulphate/maintain profile that has resurrected batteries that wouldn't hold a charge for more than a day using the old manual Schumacher.
Also if you choose to leave a battery on it for months at a time, it doesn't constantly apply voltage like a typical "maintainer," which can lead to sulphation. It just monitors most of the time, then periodically will put a light load on the battery for a while, then re-charge it.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
#4573554 - 11/14/17 08:38 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mjk]
JohnnyJohnson Offline
Loc: Wet side WA
I've had my Schumacher for 12 years now not any problems. They have a pretty nice one at Walmart at the moment at least at my local store. Mine is 2/10 amp and an Auto/manual unit. The one at Wally world was pretty much the same $59.
2004 Toyota Corolla 121668
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4573556 - 11/14/17 08:39 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mjk]
Nick1994 Offline
Loc: Phoenix, AZ
I bought a 6 amp Stanley last summer and it worked pretty good until my brother hooked it up backwards to a battery (supposed to be able to take it, obviously can't). So I ordered the ProLogix that 440Magnum posted above. Really like this charger!
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4573563 - 11/14/17 08:42 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mjk]
wheelman1991 Offline
Loc: Watertown, NY USA
I have an older Schumacher buzz box identical to the one in the picture. I mostly just leave it on 10 amp mode, but sometimes use the 30/50 amp boost setting. It does the job for the most part. another bonus is if it's raining or snowing out and I need to charge a battery, I can just stick the charger under the hood. if I need more, I use the rolling battery charger that is 2/15/50/250 amp and 12v/6v. (Both chargers are fully manual, but I monitor both charging amperage and voltage)
Edited by wheelman1991 (11/14/17 08:43 AM)
1999 Toyota Camry, 1MZ-FE v6 ,5-speed, 305k miles. Project car.
#4573564 - 11/14/17 08:43 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mjk]
Langanobob Offline
Loc: Reno, Nevada
Not on your list but I'm having good luck with BatteryMinder chargers (not to be confused with Battery Tender) They have settings for various battery types and a temp sensor that allows an internal circuit to adjust the charging rate to keep batteries from getting too hot while charging. They also have a desulfating mode that I question whether it actually works but they charge batteries very well. Adjustable for 2, 4, or 8 Amps which is a bit below your 10 Amp requirement.
#4573573 - 11/14/17 08:48 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mjk]
mk378 Online   content
Loc: USA
An old iron-core manual or semi-automatic Schumacher is good to keep in the garage because it is best at (attempting to) revive a battery that has been run down completely dead. The fancy digital stuff often refuses to charge at all. Maintaining a battery in storage is a different situation that calls for a completely different machine.
#4573575 - 11/14/17 08:49 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mjk]
StevieC Offline
Loc: Ontario, Canada
I have experience with CTEK and Noco and have been happy with those.
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4573593 - 11/14/17 09:04 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mjk]
mjk Offline
Does anyone know if the Stanley and Peak are actually Schumacher? Just throwing out some common brands that I see at Walmart, Menards, Fleet Farm, etc.
I have to admit that Solar Prologic is tempting.... if I could save some money and get a reliable unit with these other brands, I would probably go in that direction.
#4573600 - 11/14/17 09:11 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: 440Magnum]
SatinSilver Offline
Loc: OH
I'm looking for a good solar powered battery charger. So this one isn't solar powered even though it's in the name?
#4573605 - 11/14/17 09:16 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mjk]
PimTac Offline
Loc: Soviet State of Washington
Stanley is Stanley Black and Decker.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
#4573623 - 11/14/17 09:34 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mk378]
DriveHard Online   content
Loc: Middle of Iowa
Pretty simple way around that. Wire a battery with some charge in it in parallel with the dead battery and charger. Let the charger start working, then after a few minutes remove the extra battery from the circuit. The charger will take it from there. You just need some initial voltage to get the charger going.
Smile, it increases your face value
2011 Silverado Crew Cab LT 6.2L/6spd
2017 Jeep Renegade Trailhawk (wife's)
2007 Nissan Xterra (trail toy)
2013 Fiat 500 Abarth
Elio...?
#4573659 - 11/14/17 10:16 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: StevieC]
Tdbo Offline
Loc: Ohio
+1. I own both, and both are good.
However, I prefer the CTEK, as I find it easier to use.
2012 Honda Accord LX-P 92K
2008 Ford Mustang Pony Package Convertible 16K
2006 Honda Odyssey EX-L 76K
2003 Ford Ranger 3.0 Supercab 107K
#4573665 - 11/14/17 10:25 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: mjk]
MolaKule Offline
Loc: Iowegia - USA
I have had the Stanley 25 Amp/75 amp charger now for about three years and it has been very reliable.
I would never buy another Schumacher as I have had two them that have failed and their specs are over rated.
#4573706 - 11/14/17 11:20 AM Re: Battery Chargers - Schumacher, Stanley, Peak [Re: SatinSilver]
440Magnum Offline
Loc: Texas
Correct. I don't know why they put 'Solar' in the name, maybe the company started out making solar chargers.
Page 1 of 2 1 2 >
