oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
103 registered members (ammolab, andythedrew, aba4430, 97f150, 4WD, anndel, 12 invisible), 1,775 guests, and 39 spiders.
Topics295,018
Posts4,926,087
Members66,666
Most Online2,553
Oct 27th, 2018
Best Scantool for Checking ATF Temp? #4573282
11/13/17 09:02 PM
11/13/17 09:02 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
What is the best "Scantool" for checking the ATF fluid temp in a 2005 Lexus LS430 and a 2009 Lexus IS350?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4573287
11/13/17 09:12 PM
11/13/17 09:12 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
Scanguage II to easily monitor all sorts of different things as well as your fuel economy. I love mine but it is a bit expensive.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4573290
11/13/17 09:14 PM
11/13/17 09:14 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Best? probably the lexus manufacturer tool.
Techstream?
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4573316
11/13/17 09:41 PM
11/13/17 09:41 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Best would be a Snap-On Zeus for the low, low price of $16,000.
Perfectly adequate would be any scantool with live data. They're all going to have the trans temp.
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4573328
11/13/17 09:57 PM
11/13/17 09:57 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Let me rephrase the question. What is the "best" scantool for under $200?
Silly boys...
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4573357
11/13/17 10:44 PM
11/13/17 10:44 PM
CA
The Critic Offline
The Critic  Offline
CA
I have not personally use this model, but I have Autelís MS906TS and it has been awesome for the money:
https://www.auteltech.com/Professional%20Scan%20Tools/559.jhtml
https://www.jbtoolsales.com/autel-md808p...ASABEgLte_D_BwE
It also comes with free lifetime updates.
2011 Toyota Prius - 178k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 133K - Mobil 1 EP HM 5W-30
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4573620
11/14/17 09:33 AM
11/14/17 09:33 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
Won't any scan tool that shows real time data show this? My Actron one does.
Re: Best Scantool for Checking ATF Temp? [Re: zzyzzx] #4573639
11/14/17 09:55 AM
11/14/17 09:55 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Nope
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4573667
11/14/17 10:30 AM
11/14/17 10:30 AM
Texas
40w8 Offline
40w8  Offline
Texas
I use Scanguage II for $159 or Google it for lower from Rv place I bought last from.
It's the best guage thing I've ever seen.
I put it on my 2007 6speed auto RX8 many years ago, and found a code from a guy with Mazda 6 that gives me trans temp.
I had some kind of problem with trans at 23k miles, and Mazda gave me a new one.
I put a 18,800BTU tube and fin cooler and lowered temps 14 deg f measuired at inlet and outlet.
Now I can cruise high spped on hot day with engine coolant 193f and trans 193f.
Scanguage on my BMW X1 s28i doesn't work to scan codes since BMW is tricky, but gives turbo boost and hp.
I use as Corrected speedo, reaL WATER TEMPS, ATT TEMPS, AND VARIOUS current or tank mpg.
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4573686
11/14/17 10:51 AM
11/14/17 10:51 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
This is so that you do a drain and fill on your new Camry? What would happen if I drained the Atf into a container, after I have removed the plastic over flow tube as shown in the "how to" ? Drain cold , measure the stuff in the bucket. refill with new after replacing the overflow? Why all the folderrol about heating the ATF ? I don;t get it.
Thick oil is better grin2
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4573755
11/14/17 12:17 PM
11/14/17 12:17 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
I have just researched this for Toyota to change the trans fluid in a sealed system.
What kind of "Smart" phone do you have?
IPhone: OBD Fusion with WIFI interface.
Android: Torque with Bluetooth interface.
You can buy the interface from Amazon called ELM327 scanner.
You also need to programmed in the Trans temp PID, I know it is on OBD Fusion.
Google for more information in the Toyota's forum.
All these should not be more than $50 for apps and interface.
  • 2017 Toyota Sienna
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4575999
11/16/17 11:48 AM
11/16/17 11:48 AM
Ontario, Canada
MobilinHyundia Offline
Ontario, Canada
Scangauge 2 . It show engine oil temp, coolant temp and tranny fluid temp for my 2009 Sonata. Use it everyday.
RIP......2009 Sonata GL 2.4L (226000km)-QS FS 5W20, OEM oil filter
2009 Sonata LTD 2.4L (170000km)Castrol Edge 5W20,
2018 Sedona SX+ -TOTAL INEO mc3 5W30 with Kia filter
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4576005
11/16/17 11:52 AM
11/16/17 11:52 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
That's what I'm getting today. $119 at AutoZone. A company rep has been emailing me. Extremely helpful! Scangauge II
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Best Scantool for Checking ATF Temp? [Re: Gebo] #4576011
11/16/17 11:57 AM
11/16/17 11:57 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
The Torque app and plugins for under $10 and then a good ELM 327 adapter for $50 or so. Beware the cheap ELM 327s. Scantool.net has the best ELM adapters.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Best Scantool for Checking ATF Temp? [Re: JMJNet] #4576035
11/16/17 12:30 PM
11/16/17 12:30 PM
California
nthach Offline
nthach  Offline
California
I use a Carista OBD-II dongle that uses a newer version of the ELM327 interface, couple it with Torque Pro and you'll come close to more expensive tools. Too bad it can't do ABS on older GMs. It even can set C-BEST on newer Toyotas and custom body settings(and maybe some module coding) on VAG/BMW products with the Carista app and a pro subscription.
I used it to help me get the CMPRET cam/crank correlation set on my friend's Chevy after I did the intake gaskets and fixed a misfire.
