2 Stroke Oil in 4 Stroke Engine 4:1 / 40:1
Cool demo. I used to run my old 2 cycle mix in my lawnmower, thinking that a little top lube would not hurt a Briggs. Now, based on the carbon buildup with a quart of 40/1, I will not do that again.
I like his videos because you get to see the inside of the engine and he has no agenda, just wants to try stuff his user suggests.
This is ridiculous...the base oil is the same, just a different additive package. This guy needs to quit with the youtube's and get a real job!
More important, would 2 stroke oil work in a 4 stroke sump ?
Done it....but it wasn't my bike. Ended up with the engine though, and there was nothing wrong with it.
Many decades ago, my grandpa used to preserve engines for the winter with a 2:1 (gas & 30wt) oil mix.
Smoked a lot - but definitely kept everything lubed up for first fire in the spring again.
Back in middle school I played around with and old pushmower with a 3.5hp Tecumseh. It kept leaking oil so I said p1ss on it, leak all you want. I started running a 30 to 40:1 (approx.) fuel, 2 stroke oil mix. Knowing full well it wont lube the crankcase I ran it for quite some time. Obviously never leaked enough to kill it but finally the parents told me enough is enough and bought a new mower. I ripped the old girl down and it was surprising it still ran as there was so much carbon in the chamber.
One thing to consider, much of that oil in the gas does not combust, and it ends up in the oil sump, contaminating the oil.
I never bothered mixing oil in the gas, but when I've put engines in long-term storage (several years) I would set the engine to fast idle and then slowly pour 2-stroke oil or Marvel Mystery oil down the carb until I got a huge smoke show, then close the throttle and let it stutter out (or shut it off if it didn't voluntarily die). Then I filled the carb bowls with MMO through the vent tubes so that they wouldn't go dry.
The last engine I did that way was the 318 in my old 73 Satellite. It sat 5 years, and when I got rid of the car I had it back up running and on the road in 45 minutes (counting installing 4 tires and wheels and pulling it down off jack stands). Starting it was as easy as pumping the throttle to lower the level of MMO in the bowls, priming the bowls with a few shots of fresh gas from a squirt can, putting 5 gallons of fresh gas in the tank, hooking up a battery, and turning the key. Another smoke show, but running perfectly as soon as the oil cleared out.
Originally Posted By: StevieC
Old Sarge, been testing,,did all this in cars back in 2006,,,11 years ago,,,history repeats itself..its in the archives in here somewhere.
Sarge is offline
Grand Imperial Wizard
Sarge's Avatar Join Date
Aug 2005
Texas Department of Corrections
Posts
18,129
Retired Outlaw Sum [censored]
Been testing Oil
you guys know I test constantly and oil/tribology is my thing so here goes. I know the gasoline today is [censored]. Very dry and poor quality. Throw in ethanol and you got [censored]/corrosive gasoline. I use Fuel Power/Lucas UCL with great success in my cars and other peoples cars. At the first of the year some of us "lubrication physcho's" (mainly from the aircraft industry) discussed the [censored] quality of gasoline and the absolute advantages of running a fuel additive with lubrication capabilities and I think the testing is now complete and the results are very good. Biggest problem we had was the proper amount but we are now satisfied this works very well and you will have a smoother running engine/more power/better MPG....so here it is.....
What we are trying to accomplish ( The deliverables)
We need to lubricate the fuel pump/seals/injectors.
We need to clean the fuel system and scavenge water that ethanol attracts.
We need a film of protection in our fuel system to stop corrosion.
We need a cleaner for our spark plugs/valves/combustion chambers.
We need to clean the ring packs
We need to leave a film on the cylinder walls to eliminate cold start metal wear.
This was my groups short list of deliverables. Of course we knew if we accomplished this list the car should A) Run Smoother B) Run more efficiently C) Parts will last longer i.e. fuel pumps/injectors etc. D) We should see more RWHP and MPG
We did it. For pennies.
2 Stroke oil. Not just any two stroke oil But we needed the detergents etc. and found the perfect oil/add packs/viscosity in a marine 2 stroke oil you can get for under $10 bucks a gallon anywhere. We used Pennzoil Marine 2 stroke for our testing. Here is the "blurb" from Pennzoil.....
Pennzoil Marine® Full Synthetic
Ultimate Protection
Pennzoil Marine® Full Synthetic 2-Cycle Oil is designed for your hard-working, large displacement, high-horsepower 2-cycle engine. High temperature protection is necessary for higher horsepower engines. High temperatures in an engine can cause loss of lubrication, carbon deposits, piston-scuffing, and pre-ignition. The combination of synthetic ester base oils and a premium, ashless performance package in Pennzoil Marine® Full Synthetic 2-Cycle Oil provides protection for high horsepower applications that require approved NMMA TC-W3® oil.
Benefits:
Pennzoil Marine® Full Synthetic 2-Cycle Oil is recommended for use in those makes and models of water-cooled, 2-cycle engines with direct injection systems, oil injection systems or those requiring use of a pre-mix. It is recommended for and meets the warranty requirements of Johnson/Evinrude, Mercury Marine, Yamaha, Suzuki, Force/US Marine, Mariner and others requiring NMMA TC-W3® oils.
Pennzoil Marine® Full Synthetic 2-Cycle Oil:
Performs in extreme conditions.
Provides excellent lubricity to protect against piston- and cylinder-scuffing.
Helps protect against ring sticking, exhaust port deposits, and spark plug fouling.
Biodegradable and low aquatic toxicity.
Recommended for direct injection engines.
Whether running full throttle to open water for that fishing tournament, cruising your favorite waterway, pulling a skier or racing you need an oil to protect your high-horsepower engine. Pennzoil Marine® Full Synthetic 2-Cycle Oil is that oil.
Use 1oz of the two stroke oil per 5 gallons of gas ( 1oz-5gallons/ 2ozs - 10 gallons etc. and that is the perfect ratio. Too much and it will make your engine run worse....too little and it wont do anything.....use the proper amount.....get a little bottle and keep it in your car.....We have seen a maximum of 5% better MPG down to a minimum of 2% better MPG. All of our test mules reported much smoother idles and cruising. No smoking or ill effects. No residue on plugs our pistons....actually the opposite....we saw "cleaning".....I am now comfortable recommending this for all. I also now run this mixture in my GTO/Mercedes/Silverado and G6 with all having smoother running motors and all gaining MPG. Give it a try and let me know your experience. Follow the mixture ratio to the letter. 1 oz per 5 gallons of gas.
Share
Reply With Quote Reply With Quote
07-07-2008, 07:58 PM #2
joejenkinsglass joejenkinsglass is offline
someday
joejenkinsglass's Avatar Join Date
Oct 2006
Iowa
Age
40
Posts
1,120
green
98 formula
I used to use 2 stroke oil in stored (older) cars. Is the oil not gonna plug the cats?
07-07-2008, 09:16 PM #3
slims00ls1z28 slims00ls1z28 is offline
Senior Member
slims00ls1z28's Avatar Join Date
Apr 2007
TN
Posts
1,212
2005 GTO M6 Black
2000 Z28 A4 Red
What is the old wise tale of 1 gallon of diesel to 10 gallons of gas? Never had the guts to try it but I know many who swear by it. A friend of mine who is heavy in the racing scene says he does it once a month on his DD's to clean it. He poped a valve cover off to show me it looked like it had less than 10K and the odometer showed 175 and I know it's the original engine. What say you ol' guru of all things oily? Ever tested that? I know diesel contains more oils than gasoline.
07-07-2008, 10:00 PM #4
rednari
Guest
Interesting. I also use Lucas fuel treatment in all my vehicles with good results. I will try your suggestion, since it appears to be more economical. Lucas fuel treatment is added at the rate of 3ozs per 10 gallons and costs about $8 per quart, so that would be a savings if it provides the same results.
But I have two issues: first, it must produce the same or better results; and two, an over treatment with Lucas does not make the motor run worse or foul the motor. Also, getting the exact amount seems difficult and requires guess work, such as how much gas will the car hold, and do I have a graduated cylinder handy to measure in the correct amount.
In any event, I will try it.
07-07-2008, 10:29 PM #5
JoshieDoom JoshieDoom is offline
Impounded
Join Date
Oct 2007
Beaver Dam KY
Posts
7,746
79 T/A -91 Firebird
1998 Trans Am -Oynx Black
Send a message via AIM to JoshieDoom Send a message via MSN to JoshieDoom
Wow. Thats reminds me that my jeep requires lead substitute(thick oil looking [censored].. not lead based..) anyway I didnt have any unmixed gas for the mower one day and said screw it and that gas lasted all day. So I tried the substitute in my truck and it helped as well. Make sense to you sarge??
07-08-2008, 04:06 AM #6
Sarge Sarge is offline
Aug 2005
Posts
18,129
Quote Originally Posted by joejenkinsglass View Post
No. Nor O2 sensors. It is very safe.
07-08-2008, 04:07 AM #7
Aug 2005
Posts
18,129
Quote Originally Posted by slims00ls1z28 View Post
Yeah we talked about diesel....but why go through all that trouble with the low sulfur stuff now days? This is easy to do and much more effective from a add pack for our gasoline engines perspective.
07-08-2008, 04:13 AM #8
Aug 2005
Posts
18,129
Quote Originally Posted by rednari View Post
Yup....I used Lucas UCL myself and this is better both from a performance/MPG perspective for pennies I got better results over 5000+ miles in my Silverado 5.3..... It is just as easy to follow as any other gas additive regiment. Just go and get yourself a measuring bottle and everytime you fill up or top off....round the total gallons up and when you get home put that amount of 2cycle oil in. Example....you put in 8 gallons....when you get home put in 2oz's....if you put in 6 gallons round down to 5 and when you get home put in 1oz. What we found is this.....the first few tankfuls coat/lubricate and clean......you really will not see/feel anything the first couple of tanks until the cleaning/lubrication has had a chance to do its thing....from there on out you are just maintaining the protection/solution. Very simple. You don't have to carry it around with you unless your on a long trip then just take a 12oz bottle or so with you.
07-08-2008, 04:14 AM #9
Aug 2005
Posts
18,129
Quote Originally Posted by JoshieDoom View Post
I guess....
07-08-2008, 10:14 AM #10
PatrizioD PatrizioD is offline
Member
PatrizioD's Avatar Join Date
Nov 2007
The **** of America; RI
Posts
381
Nero
2006 gto
Alright I want to make sure Im reading this right... and I bet im not the only one wondering here. So I get the Pennzoil 2 cycle oil thats pictured in the starting post, and add 1oz for every 5 gallons of gas in the tank? (If im half-full and only add it to what I pump in, it'll be diluted, I assume) So in my GTO, I would add just under 4oz for a full tank.
This will "clean" and increase efficiency in the engine/fuel delivery system? Thats awesome; I'll start doing this to every vehicle I own.
07-08-2008, 10:35 AM #11
rapter34
Guest
Quote Originally Posted by PatrizioD View Post
+1 just want to make sure before i do something bold like put anything in my tank.
07-08-2008, 10:45 AM #12
Aug 2005
Posts
18,129
1oz to 5 gallons of gas. So if you fill up and have never added it before....you would put in 4oz's. From there you would maintain a 1oz to 5 gallons added. You'll go through like 2 full tanks before you will start noticing a difference....yes it cleans the [censored] out of the fuel system and the combustion chamber. Allows a smoother start up/idle etc......it works.....for pennies....
07-08-2008, 10:46 AM #13
Aug 2005
Posts
18,129
Quote Originally Posted by rapter34 View Post
I've been doing it for over 7 months now in all my vehicles.....
07-08-2008, 12:29 PM #14
Texas Jack Texas Jack is offline
Member
Texas Jack's Avatar Join Date
Jul 2008
Central Texas
Posts
675
Cyclone Grey
2006 GTO M6
Great info!!!!!!!!!!!!!!!! Thanks
07-08-2008, 03:05 PM #15
ledesma54 ledesma54 is offline
Member
ledesma54's Avatar Join Date
Dec 2007
Houston
Posts
365
Red
04 GTO
Okay so every 5 gallons u put 1 oz into were? In the oil fill hole or the gas tank might be dumb but i want to make sure before i do anything thanks.
07-08-2008, 04:15 PM #16
cant.b.caught.z28 cant.b.caught.z28 is offline
Member
cant.b.caught.z28's Avatar Join Date
Feb 2008
Wichita, KS
Age
29
Posts
476
Silver
2005 Ram Daytona
Is there a better way of adding it into your tank?... Like should you pour the oil into the tank first, then fill the gas, or should you fill the gas and then put in the oil?
07-08-2008, 04:31 PM #17
doozjamann doozjamann is offline
3-Time F-Body Offender
doozjamann's Avatar Join Date
Apr 2008
NC
Posts
1,365
Pewter
2000 SS Camaro
Send a message via AIM to doozjamann Send a message via Yahoo to doozjamann
Good info Sarge.
Has anyone other than me heard of putting tranny fluid in the tank to clean fuel system. It works not sure what the long term effects are, and never tried it in a car with cat's. Car will smoke like a diesel on a cold morning, but it cleans everything.
07-08-2008, 04:59 PM #18
Aug 2005
Posts
18,129
Quote Originally Posted by ledesma54 View Post
In the gas tank.
07-08-2008, 04:59 PM #19
Aug 2005
Posts
18,129
Quote Originally Posted by cant.b.caught.z28 View Post
Doesn't matter....going to get all sloshed around anyway
07-08-2008, 05:01 PM #20
Aug 2005
Posts
18,129
Quote Originally Posted by doozjamann View Post
Good info Sarge.
Yeah but ATF has phosphorus and that kills catalytic converters and is a short term cleaning solution. ATF has no lubricating properties either. This is a long term full spectrum cleaning/lubricating solution.
Page 1 of 571234521314151...NextLastLast
Quick Navigation GTO Top
« DeWitt's Radiator for 2004 GTO | - »
LinkBacks (?)
INJECTOR CLEANER - HD Forums Australia
Refback This thread
03-07-2017, 02:00 PM
TC-W3 2 cycle oil in the gas - General 70-72 Monte Carlo Forum - First Generation Monte Carlo Club
Refback This thread
01-01-2017, 02:29 PM
TC-W3 2 cycle oil in the gas - DODGE RAM FORUM - Dodge Truck Forums
Pingback This thread
01-01-2017, 01:26 PM
Stock Fuel Pump failure with E85?? - CorvetteForum - Chevrolet Corvette Forum Discussion
Refback This thread
12-24-2016, 03:12 PM
I've upgraded to 5/30 oil... | Page 13 | 2016+ Honda Civic Forum (10th Gen) - Type R Forum, Si Forum - CivicX.com
Refback This thread
11-30-2016, 05:27 PM
Loud high pressure fuel pump | 2016+ Honda Civic Forum (10th Gen) - Type R Forum, Si Forum - CivicX.com
Refback This thread
11-30-2016, 03:55 PM
Gas treatments - 986 Forum - for Porsche Boxster Owners and Others
11-05-2016, 05:52 PM
Odd recommendation by Mechanic - The Hull Truth - Boating and Fishing Forum
11-04-2016, 11:44 AM
Gas mileage on a 1977 Newport with a 400 | For C Bodies Only Classic Mopar Forum
Refback This thread
10-26-2016, 05:44 AM
Acetone in gas... 2+mpg do it! - DodgeForum.com
Refback This thread
10-13-2016, 04:37 PM
Adding 2 Cycle Oil to Fuel?? - AcuraZine - Acura Enthusiast Community
Refback This thread
10-13-2016, 03:17 PM
What kind of mpg in your 3rd gen? - Page 10 - YotaTech Forums
Refback This thread
09-25-2016, 03:31 PM
Marine 2 cycle oil --> ethanol gas - CorvetteForum - Chevrolet Corvette Forum Discussion
Refback This thread
09-19-2016, 10:31 AM
Ethanol Free vs Ethanol Gas: Does it affect performance - Page 2 - 986 Forum - for Porsche Boxster Owners and Others
Refback This thread
09-19-2016, 08:58 AM
Ethanol Free vs Ethanol Gas: Does it affect performance - 986 Forum - for Porsche Boxster Owners and Others
09-19-2016, 06:32 AM
2-Stroke oil in gas? - Drive Accord Honda Forums
09-03-2016, 07:57 AM
Synthetic Oil - Page 487 - DODGE RAM FORUM - Dodge Truck Forums
Refback This thread
09-01-2016, 06:19 AM
MAZDA 6 FORUM • Olej 2T jako mieszanka paliwa do diesla z DPF • Ogólny GH
Refback This thread
08-09-2016, 12:57 PM
running rich 1 cylinder, traced back to fuel distributor... need advice
Refback This thread
08-05-2016, 09:27 PM
Bataie La Rece! - STILO 1.6 - == CLUB FIAT ROMANIA==
Refback This thread
08-05-2016, 03:40 AM
How much Techron to use? - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
Refback This thread
07-28-2016, 08:02 AM
What grade of gas do you run in your chevy? | Page 2 | Chevy Truck Forum | GM Truck Club
Refback This thread
07-27-2016, 09:54 AM
What did you do to your e21 today? - Page 39
Refback This thread
07-19-2016, 09:16 AM
Wollfen's 1971 Sport Fury GT ! | Page 45 | For C Bodies Only Classic Mopar Forum
Refback This thread
07-12-2016, 07:45 AM
Mpg Nightmare! - Dakota Durango Forum
Refback This thread
07-06-2016, 08:38 PM
UCL data? | Fuels and Fuel Additives: Gasoline and Diesel | Bob Is The Oil Guy
Refback This thread
07-06-2016, 10:26 AM
Synthetic Oil - Page 424 - DODGE RAM FORUM - Dodge Truck Forums
Refback This thread
07-06-2016, 09:41 AM
Synthetic Oil - Page 419 - DODGE RAM FORUM - Dodge Truck Forums
06-29-2016, 12:09 PM
2SO JASO FC en Petrol Enjins
Refback This thread
06-13-2016, 04:38 PM
Additives - The FORDification.com Forums
Refback This thread
06-12-2016, 06:36 PM
Experiment met TC-3W 2T - De BMW K-serie door Bert Meijerink
Refback This thread
06-02-2016, 10:50 AM
TCW3 2-stroke oil for ethanol defense - Smart Car Forums
Refback This thread
05-11-2016, 02:56 AM
The Right Car and the Right Deal. . . | Page 2 | For C Bodies Only Classic Mopar Forum
Refback This thread
05-09-2016, 10:57 AM
Interesting read
Refback This thread
04-20-2016, 06:29 AM
Anyone hear of Mystery Oil to your Gas Tank? - Page 2
Refback This thread
04-19-2016, 11:12 AM
2-stroke oil experiment. - Page 22
Refback This thread
04-13-2016, 07:28 PM
gen 3 650 post break-in fuel economy? - Page 3 - Kawasaki Versys Forum
04-02-2016, 11:32 PM
Strange Thing Happened Today | Page 5 | For C Bodies Only Classic Mopar Forum
Refback This thread
03-28-2016, 05:15 AM
www.iFourWinns.com • View topic - Engine / Fuel pump squealing noises.
Refback This thread
03-24-2016, 11:19 PM
Ab 2011 E10, mit 1% Zweitaktöl im Benzin keine Schäden. - 2CV, Ami, Dyane, Méhari, Visa, LN/LNA und Verwandte - André Citroën Club
Refback This thread
03-14-2016, 02:21 PM
TC-W3 Two-stroke oil as a fuel additive - Chevy Impala SS Forum
Refback This thread
03-08-2016, 09:35 AM
oleo 2t no tanque alguem ja usou? eu ja! - Página 12 - CXT Brasil
Refback This thread
02-13-2016, 12:34 PM
Uniacidz Ride VX SS Monaro Themed - Page 87
02-12-2016, 04:59 PM
Wally world TCW-3 2 cycle oil in my 7.3? - The Hull Truth - Boating and Fishing Forum
Refback This thread
02-02-2016, 02:32 PM
E10 Korrosion und Motorschäden verhindern mit 1% Zweitaktöl im Sprit
Refback This thread
01-31-2016, 05:07 PM
Piston slap - Toyota Tundra Forums : Tundra Solutions Forum
Refback This thread
01-30-2016, 06:57 PM
What do you put in your gas? - Page 3 - Vulcan Bagger Forums
Refback This thread
01-28-2016, 03:02 AM
horrible mpg and weird idle drop | Page 8 | GMTNation
Refback This thread
01-24-2016, 10:04 AM
Does anyone ever use fuel treatment??? - Page 2
Refback This thread
01-21-2016, 05:07 PM
Welches Öl für den SC 3.0 Liter von 1979? - Seite 2 - 911 "G-Modell" - Elferliste, das Board für den Porschefan
Refback This thread
01-21-2016, 03:14 PM
Thread Information
There are currently 32 users browsing this thread. (0 members and 32 guests)
Similar Threads
Testing
By mrwdjv in forum Almost Anything Goes
Last Post: 05-11-2009, 04:11 PM
testing
By Spikito in forum Almost Anything Goes
Last Post: 02-21-2009, 04:56 PM
Well testing
By 99formulals1 in forum Almost Anything Goes
Last Post: 11-28-2008, 09:12 PM
Testing
By Y2KPewterSS in forum Camaro / SS
Last Post: 04-25-2007, 07:41 PM
Bookmarks
Submit to Digg Digg Submit to del.icio.us del.icio.us Submit to StumbleUpon StumbleUpon Submit to Google Google
Posting Permissions
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
code is On
[VIDEO] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Rules
Sponsors
Everywhere sidebar 1.5.3
I occasionally run two cycle fuel in an old four stroke Tecumseh engine lawn mower at camp. Never a full tank and no where nearly as rich as 40:1. Probably closer to 70:1 or thinner. Don't do it regularly, just when I want to burn off some old fuel. Been doing that for decades with that mower. It 40 years old and just keeps running. Doesn't seem to mind burning that fuel. Those old lawn mower engines aren't to fussy about anything.
