Just a word of advice folks... Bought a couple of these 8x7 EZEE metal panel sheds from a manufacturer called Arrow through a local home improvement store here called Rona, for a rental property I have.
These sheds have to be the worst design I have seen and the directions have different part numbers in each language so you have to use all 3 sets to figure out which parts you have because all 3 sets are different for some reason. The instructions are also quite vague at best so you are left sorting out which way things go and then taking things apart because it's backwards etc.
The panels all clip together using friction to hold them together into one another but they don't grip firmly together so they come apart as you are trying to put on the top/bottom channels. In my opinion this could have been remedied with some more screws.
Anyways I thought I would let everyone know in case someone was looking for a cheap shed just for the lawn mower/bikes sort of thing to stay away from these. They are anything but "EZEE" and they need a lot of customizing to make them sturdy. To 2 full days to assemble on of these because so much time was spent trying to sort out the panels that kept un-clipping / the directions that made no sense / part numbers that didn't exist.
https://www.rona.ca/en/galvanized-steel-ezee-garden-shed-charcoal-8-x-7-04585009
