Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
2003 Honda power steering problem
by hogpops
06/24/18 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
06/24/18 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
06/24/18 03:21 PM
Castrol 0W40 vs 5W40??
by Realfine69
06/24/18 03:02 PM
Paint impurities on a new car
by Quattro Pete
06/24/18 02:49 PM
2014 Ram wheel FIT on a 2005 Ram?
by SumpChump
06/24/18 02:41 PM
Do people buy from telemarketers?
by Chris142
06/24/18 02:06 PM
TGMO 0W20, 8100km/5mo, 2013 Lexus GS350AWD 118K KM
by David_Corbett
06/24/18 01:54 PM
Sonoma Raceway
by Warstud
06/24/18 01:51 PM
Zipcode error
by aquariuscsm
06/24/18 01:36 PM
NHRA drag racing Racing question??
by daddi
06/24/18 01:33 PM
Milesyn 5w30 5 gal pails $50.94 w/prime
by Samrsnow
06/24/18 01:20 PM
Removing Broken Bathtub Drain
by Warstud
06/24/18 01:15 PM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
103 registered (A310, 69Torino, 2015_PSD, bbhero, 379KITTY, 55hambone, 9 invisible), 1588 Guests and 36 Spiders online.
65312 Members
67 Forums
285932 Topics
#4572576 - 11/13/17 09:37 AM Moog Complete Knuckle Assembly
SubLGT Offline
Loc: Idaho
Something new from Moog.
Quote:
New MOOG complete knuckle assemblies include all of the premium components – MOOG knuckle and backing plate with corrosion-resistant E-coat; MOOG wheel hub assembly; National® axle bearing; axle nut; and lock ring – needed for a complete repair. By relying on this comprehensive, bolt-on solution, service providers can save time and eliminate the need for special tools or a press, resulting in an easier installation.
http://www.moogparts.com/moognews/MOOG-Complete-Knuckle-Assemblies-Simplify-Bearing-Replacement.html
#4572625 - 11/13/17 10:34 AM Re: Moog Complete Knuckle Assembly [Re: SubLGT]
Miller88 Offline
Loc: Onondaga County
Ha!
I always wondered why no one had done this.
Press in bearings are incredibly stupid when it comes to replacing them.
If I kept the focus, I intended on either buying a complete new knuckle and pressing in the bearing/hub and replacing the knuckle or getting a junkyard one with a good bearing.
Cheaper (and easier) than paying a shop or to struggle getting the press in bearing out.
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
#4572654 - 11/13/17 11:02 AM Re: Moog Complete Knuckle Assembly [Re: Miller88]
Trav Offline
Loc: MA, Mittelfranken.de
Originally Posted By: Miller88
Ha!
Its a 10-15 min job to press them. I certainly wouldn't buy a cheap Chinese knuckle with Made in China National bearing and hub to save a few min. OE brake shields are usually good for 10+ years the ones from China probably less than half that.
Thanks I'll pass.
#4572700 - 11/13/17 11:31 AM Re: Moog Complete Knuckle Assembly [Re: SubLGT]
mcwilly Offline
Loc: Canada
I recently did the one bearing on my toyota echo. Everything was so corroded into place it took a couple hours to actually remove the knuckle. After that I dropped it off at a shop and paid 1 hour shop time ($120 CAD) to press out and press in a new bearing ($30CAD). I looked for a whole knuckle assembly, but there was none available. If I could have got one for sub $200 I would have done it in a heart beat. Would be able to skip the shop and just swap out knuckles.
2010 Subaru Sti 71,000km
2001 Toyota Echo 232,000km
#4572739 - 11/13/17 11:56 AM Re: Moog Complete Knuckle Assembly [Re: SubLGT]
LeakySeals Offline
Loc: Hudson, NH
I like how it has the brake/dust shield installed.
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4572797 - 11/13/17 12:38 PM Re: Moog Complete Knuckle Assembly [Re: SubLGT]
thrace Offline
Loc: USA
On last front bearing, chose Timken USA and had it pressed in. Could have bought made in China hub with bearing for less but until made in China bearing lasts as long as made in U.S.A., will avoid China made bearing.
#4572980 - 11/13/17 03:48 PM Re: Moog Complete Knuckle Assembly [Re: thrace]
Miller88 Offline
Uhhh ... the last few sets of Timkens were made in China ...
18 Forester 2.5I 6M
00 Jeep Cherokee
#4572981 - 11/13/17 03:48 PM Re: Moog Complete Knuckle Assembly [Re: LeakySeals]
Trav Offline
The shield on some are a simple 3/4 bolt on requiring only rotor removal but on some others its bolted on behind the hub, to change these the hub must be pressed out and with it the outer inner bearing race.
Of greater concern is to me anyway is the quality of the material used for the knuckle itself, this is such a critical part a failure is usually catastrophic. Never buy a used knuckle from a front end total if OE new is no longer available but if the car was just junked they tend to be fine, always check it out carefully even have it fluxed or dye checked if aluminum if anything at all looks suspicious.
Sorry, with Moog doing so much importing from third world countries and declining quality in many of their products this is one part I really don't want to use. If it was the old Moog 20-30 yrs ago I probably wouldn't have any reservations. JMHO.
#4573004 - 11/13/17 04:23 PM Re: Moog Complete Knuckle Assembly [Re: SubLGT]
Audios Offline
Loc: Lyndhurst NJ
Moog is just the name now, I went through 2 tie rod ends on an ML500 within 6 months before I went to an OE brand. Both times failed in the same spot, and had tons of play. Id worry if these come along at a too good to be true price.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2005 BMW M3 BMW Twin Power 10/60
1998 BMW M3/4/5 Fuchs 5/40
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
#4573008 - 11/13/17 04:27 PM Re: Moog Complete Knuckle Assembly [Re: SubLGT]
dlundblad Offline
Loc: Indiana
No thanks.
Probably a hefty penny more than just the bearing too.
You get less for more!!!
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4574695 - 11/15/17 08:54 AM Re: Moog Complete Knuckle Assembly [Re: Trav]
Miller88 Offline
Ha!
Thanks I'll pass.
Not 10-15 minutes on something that's been run in the salt for the last 15 winters
18 Forester 2.5I 6M
00 Jeep Cherokee
#4574735 - 11/15/17 09:28 AM Re: Moog Complete Knuckle Assembly [Re: SubLGT]
researcher Offline
Loc: Michigan
I had a bearing go bad on the front of the 96 civic. The knuckle was so far gone the bearing couldn't be pressed out without damage to the knuckle! In this case, just bought a new knuckle from Honda. Figured this one lasted 21 years.
But Moog's quality is really going down the drain, quickly! Let them learn the hard way that when they go cheap people will learn to stay away from them. regardless of the price. Only when their stock price is affected will they notice.
#4574819 - 11/15/17 10:34 AM Re: Moog Complete Knuckle Assembly [Re: Miller88]
Trav Offline
I am talking actual press time once its off.
