Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
26 registered members (BlakeB, Billbert, ArrestMeRedZ, CleverUserName, Astro14, ctechbob, 1 invisible), 731 guests, and 41 spiders.
Topics290,867
Posts4,851,572
Members66,044
Most Online3,590
Jan 24th, 2017
Seafoam Question #4572317
11/13/17 12:00 AM
11/13/17 12:00 AM
Atlanta, GA
RoGuE Offline OP
RoGuE  Offline OP
Atlanta, GA
I've had a bottle of Seafoam sitting around for a while and wanted to try it on my Malibu to see if it will help with some oil consumption and rough idle. It's not a lot but it's almost a quart down after 5000 miles, but it has never used any oil before. I'm planning on changing my oil very soon as well, so I figured I might put some in the oil as well before changing it. I've used Seafoam a couple times in other other cars. It helped in one case but not the other so it's worth a shot.
Anyway, I was planning on using the brake booster line like is usually directed, but on my car it seems like the brake booster vacuum line goes directly into one of the intake runners which isn't very helpful. There is another line that goes from the valve cover directly to a part right before the throttle body. I was wondering if this will work well to suck the Seafoam in to the intake.
This particular line is part of a non serviceable PCV valve (built in to the valve cover) and recently I have noticed that there is oil seeping around the end of the hose so I know there is probably some build up of oil in the intake. I just want to make sure this will work okay for what I'm planning to do. Here are a couple photos showing what I am referring to: https://imgur.com/a/aq7hs
2007 Chevrolet Malibu
2.2L Ecotec
Re: Seafoam Question [Re: RoGuE] #4572324
11/13/17 12:08 AM
11/13/17 12:08 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Need to pour a little sea-foam into the "non-serviceable" PCV valve as well, while you are at it.
Re: Seafoam Question [Re: RoGuE] #4572336
11/13/17 01:02 AM
11/13/17 01:02 AM
Connecticut 06033
oilmutt Offline
oilmutt  Offline
Connecticut 06033
I love how clean your engine looks,I try to keep our 05 6cyl Malibu the same way,i see you have me beat!
'05 Chevy Malibu 6cyl,119k, Syn. Oil (owned)
'16 Toyota Camry,4cyl 25k Syn oil (leased)
'92 Ford Tempo ,4cly 26k Conv oil (managed)
Re: Seafoam Question [Re: RoGuE] #4572415
11/13/17 07:25 AM
11/13/17 07:25 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
I have the same engine, oil consumption has increased from 1qt/8,000m at 100,000 miles to 1qt/2,800m at 196,000 miles. Seems to be the nature of the beast. Low tension rings maybe?
The line from the valve cover to intake is the line to use for seafoam. At idle, the engine should want to draw air into the valve cover if the PCV system is operating properly. You can feel this with your finger if you block the opening to the valve cover but don't do this for too long as you will create a vacuum in the crankcase and draw ambient air in around the engine seals. I don't think pouring seafoam into the valve cover port will really clean the PCV system as the seafoam will just mix with the oil in the top of the head.
Adding seafoam to the intake, via this valve cover line, would be the best way to "treat" the engine but this will set a trouble code as air/seafoam is entering the engine without passing the MAF sensor.
An overly dirty air filter can cause a higher than usual vacuum in the intake tube which will draw excess crankcase vapours into the engine from the valve cover area. You might want to check that first.
Re: Seafoam Question [Re: RoGuE] #4572427
11/13/17 07:59 AM
11/13/17 07:59 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
Put it in a spray bottle and spray it against the throttle plate with the RPM at 1500-2000. Clean the Throttle Body at the same time.
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Seafoam Question [Re: RoGuE] #4572523
11/13/17 09:51 AM
11/13/17 09:51 AM
MB - Manitoba
FastLane Offline
FastLane  Offline
MB - Manitoba
Your overly long oil changes is why your engines use oil. My FIL just parked a Malibu with 435,000 kms on it. Doesn’t use any oil. Oil changed every 3000 miles/5000 kms since new.
2010 Silverado 4.8 4x4 Mobil 1 5W30 ACDelco PF48E
2002 Mustang GT 4.6 Mobil 1 5W30 MC FL-820S
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
Re: Seafoam Question [Re: RoGuE] #4572544
11/13/17 10:09 AM
11/13/17 10:09 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
My Santa Fe didn't use any oil when it died at 535,000km (300K miles) on 10,000km (6,000 mile) oil changes. I would have pushed the OCI further but the engine was really hard on oil so I couldn't.
Re: Seafoam Question [Re: RoGuE] #4572558
11/13/17 10:21 AM
11/13/17 10:21 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Or, we could stay on topic. The use of Seafoam.
Re: Seafoam Question [Re: RoGuE] #4572569
11/13/17 10:29 AM
11/13/17 10:29 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
I would run something stronger than Seafoam. Use Berrymans B12 Chemtool.
Re: Seafoam Question [Re: WobblyElvis] #4572581
11/13/17 10:38 AM
11/13/17 10:38 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
It was pointed out that the OCI's were the problem and implied that Seafoam was not needed, I was pointing out that I don't think that is the case based on my experience. How is that "Off Topic" shrug
Re: Seafoam Question [Re: GMBoy] #4572585
11/13/17 10:45 AM
11/13/17 10:45 AM
Ct. Usa
Bigbill Offline
Bigbill  Offline
Ct. Usa
I put seafoam in the crankcase and gas tank at the same time. Seafoam is also a upper lube too. It lubes the valve guides, valve seats, frees and reseats stuck piston rings. By the time I need fuel again the idle has smoothed out, the idle is a higher rpm. The engine seems to be happy, happy, happy. My generator had a gummed up carb. I added seafoam tothe gas tank and forgot about it. Months later we fired it up and the carb was cleaned.
Re: Seafoam Question [Re: Bigbill] #4572613
11/13/17 11:22 AM
11/13/17 11:22 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Sounds like amazing stuff, makes you wonder how anyone gets by without it.
1994 BMW 530i, 228K
1996 Honda Accord, 263K
1999 Toyota Sienna, 400K
2000 Toyota ECHO, 271K
Re: Seafoam Question [Re: kschachn] #4572736
11/13/17 12:53 PM
11/13/17 12:53 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I use it in gas for non catalytic small engine applications like my snowblower and lawn mower. Thats what it was created for way back in 1932, a sick wet boat engine. Similar to a sta-bil. The other claimed applications, like fogging your auto engine's intake and catalyst with white clouds of pale oil are silly.
06 Escalade 6.0L LQ9 AWD 165k M1 5w30
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Seafoam Question [Re: FastLane] #4572738
11/13/17 12:56 PM
11/13/17 12:56 PM
Atlanta, GA
RoGuE Offline OP
RoGuE  Offline OP
Atlanta, GA
Haha, I could lie but I must admit these photos are from 2007 when I purchased the car. I do keep it very clean so it looks similar, only the coolant and brake fluid reservoir are a little yellowed.
The difference is I have only 54k miles on mine. It's never used any oil before until now. I changed it in January and shrug
I wouldn't expect the valve cover side to be drawing in air. Okay, I'll add it through this line into the intake. If it sets a code I have a scantool I can use to clear it.
The air filter shouldn't be dirty. I replaced it maybe a year ago and I don't really drive in dusty environments, but I'll give it a check.
Maybe I'll spray down a little on the TB plate first and then run the rest through the line.
I don't think you will find many on here including myself that thinks a 5k mile OCI is long, especially with Pennzoil Platinum in there. If I followed the GM OLM in the car it would take me to around 8k miles or more.
2.2L Ecotec
Re: Seafoam Question [Re: RoGuE] #4572757
11/13/17 01:13 PM
11/13/17 01:13 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
Yeah that sounds fine...
