2012 Grand caravan wheel fit a 2014 Town and count
Eastern Wa.
I found a set of 4 17" steel wheels off a 2012 Grand Caravan. Will they fit on my 2014 Town and country for snow tires? I have 17" rims on it now.
They will fit fine. The Caravan and T&C just clones of each other
The guy that is selling them says they won't fit his 2016 grand caravan. Did something change?
wheel-size.com shows all 3 identical ... well, it shows the center bore on the T&C to be 71.5mm but that 0.1mm wouldn't matter if it is real
225/65R17 6.5Jx17 ET40 5x127 M12 x 1.5 71.6
The wheels should fit his 2016 GC he insists that they don't something to do with the brake caliper? I know they went to a heaver duty brake starting in 2014 model year. He's going to let me try one on our 2014 T@C before I buy them. I know the brakes look tight even with a 17" wheel.
They should be a perfect fit. I owned a 2013.
The only complication you have to watch for with models older than ~2014 is the lower trim level Grand Caravans came standard with 16" wheels. 16's wont fit models with HD brakes, which ALL 2014+ will have. You need 17's for those.
