Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
102 registered members (aquariuscsm, 928, Ag76, Alfred_B, Aero540T, Altima2, 12 invisible), 2,091 guests, and 59 spiders.
Topics286,236
Posts4,904,891
Members67,582
Most Online2,967
Mar 10th, 2019
MK6 GTI oil separator "PCV" valve went bad #4571524
11/12/17 08:29 AM
11/12/17 08:29 AM
The Midwest
skyactiv Offline OP
skyactiv  Offline OP
The Midwest
My wife was driving home from the grocery store yesterday when the check engine light came on. The engine idle was jumping around erratically. I quickly diagnosed the oil separator was bad. It's the original that lasted 112K miles. The rubber diaphragm was torn. I rushed off to the nearby VW dealer with 20 minutes to spare before the parts dept closed. It took 20 minutes to install the new one. This makes the 3rd issue I've had with my VW which I bought new.
Me: 13' VW GTI 3 door 6 speed manual
Re: MK6 GTI oil separator "PCV" valve went bad [Re: skyactiv] #4571642
11/12/17 11:11 AM
11/12/17 11:11 AM
Lyndhurst NJ
Audios Online content
Audios  Online Content
Lyndhurst NJ
Very common on those cars, Im surprised it lasted that long, I had one this week on a Q5 with only 59k. I think you can only order the diaphragm online now, but I usually do the whole separator as well.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: MK6 GTI oil separator "PCV" valve went bad [Re: skyactiv] #4571652
11/12/17 11:17 AM
11/12/17 11:17 AM
Tampa, Florida
flanso Online content
flanso  Online Content
Tampa, Florida
Though I have fewer miles on my GTI than you do, I am trying to be prepared. Did the failed oil separator throw a code? What were the other two issues that you mentioned in your post?
Thanks
Re: MK6 GTI oil separator "PCV" valve went bad [Re: skyactiv] #4572064
11/12/17 06:34 PM
11/12/17 06:34 PM
The Midwest
skyactiv Offline OP
skyactiv  Offline OP
The Midwest
The oil separator was hissing air and I got a misfire code for every cylinder.
if someone ignores replacing a bad oil separator on this engine, there is a good chance you'll blow the rear main seal.
DO NOT DRIVE your car if this happens! You can buy VW parts cheaper at ECS tuning, AutohausAZ, Deutsche Auto Parts
I own a stick and the dual-mass flywheel went out around 50K. I didn't bother with the warranty as I wanted a bulletproof replacment
in case I decided to mod my car.
The intake manifold secondaries quit opening at high RPM. A new intake is reasonably priced. I also cleaned the intake valves while I was at it which
is another issue the older TSI engines have.
I replaced my ignition coils at 100K, even through I never had a failed coil on my car.
I still like my car and am satisfied with it regardless of the issues I've had. I'm still peeved off about the hit & run accident.
