64856 Members
68 Forums
282390 Topics
#4571433 - 11/12/17 03:07 AM
What are the best brakes parts NAPA sells?
Loc: Colorado
My 2012 Honda Accord needs new rotors and pads very soon. The rotors are badly warped and the pads are starting the squeal. The factory breaks lasted 75,000 miles. My friend owns a diesel shop and can get me anything at NAPA for his costs which is a good discount. He owes me a favor and is doing the brake job for me. What would you recommend for the best quality rotors and pads NAPA sells for my Honda? I'd like to get the highest quality parts so pads last and are quiet and rotors don't warp. Thanks for any suggestions!
#4571434 - 11/12/17 03:16 AM
Re: What are the best brakes parts NAPA sells?
[Re: Chris B.]
Loc: West Chester, PA
Forget Napa and get yourself a set of Akebono Proacts. Just put a set on front of wife’s 2010 MDX. Have installed them many times over the years on various vehicles and they are simply fantastic in every regard. Stop on a dime, quiet as a church mouse and clean as a whistle.
Edited by artbuc (11/12/17 03:17 AM)
#4571438 - 11/12/17 03:30 AM
[Re: Chris B.]
Loc: Clovis, CA
NAPA brake pad and rotor kit for fronts: NBK-7656AXSSK1C
#4571442 - 11/12/17 03:54 AM
[Re: artbuc]
Loc: Kaiōshinkai
Forget Napa and get yourself a set of Akebono Proacts. Just put a set on front of wife’s 2010 MDX. Have installed them many times over the years on various vehicles and they are simply fantastic in every regard. Stop on a dime, quiet as a church mouse and clean as a whistle. Depending on the region NAPA does carry Akebono pads. Paired with the NAPA Ultra Premium coated rotors they make an excellent combo which I've used in many brake jobs.
Shin Gekiretsu Shin'ou'hou 01 Toyota Tundra 2WD V8 4.7L - 167k mi 02 Chevy Silverado C1500 V8 5.3L 150k mi
#4571501 - 11/12/17 07:02 AM
[Re: Kibitoshin]
Loc: Pennsylvania
Forget Napa and get yourself a set of Akebono Proacts. Just put a set on front of wife’s 2010 MDX. Have installed them many times over the years on various vehicles and they are simply fantastic in every regard. Stop on a dime, quiet as a church mouse and clean as a whistle. Depending on the region NAPA does carry Akebono pads. Paired with the NAPA Ultra Premium coated rotors they make an excellent combo which I've used in many brake jobs. +1, that combo would be tough to beat.
#4571591 - 11/12/17 09:23 AM
[Re: Chris B.]
Loc: USA
Napa carries Akebono pads  The best rotors Napa seems to carry for your car are Napa Reactive One Altrom - Mountain brand Altrom - Brembo brand Altrom - Fremax brand
#4571602 - 11/12/17 09:31 AM
[Re: Chris B.]
Loc: Deplorable in apple valley, ca
I put napa pads on my jeep. They stop fine but squeeled and made my wheels black very quickly. Took them off and went back to duralast golds.
02 Wrangler super-s 10w30 87 F250 proline 15w40 04 Tahoe super-s 10w30 Z400 Lucas 10w30 KLR250 Maxima 10w40 Can am maveric edge 5w40 57 case tractor 15w40
#4571640 - 11/12/17 10:10 AM
[Re: Chris B.]
Loc: Los Gatos, CA
I used the Reactive One pads on out 2001 Tundra. These truck have undersized front brakes. They have been very good; I would recommend them. As others have said, Akebono brake pads are top notch. As far as rotors, sometimes the cheapies can warp. I have not had an issues with any Napa part. One more thing: service your brake fluid. It will make a difference. Good luck with your new brakes!
#4571733 - 11/12/17 11:27 AM
[Re: Chris B.]
Loc: Colorado
Thanks gentlemen! I appreciate the advice! Is the Altrom - Mountain brand, Altrom - Brembo brand and Altrom - Fremax brand different rotors made by the same company?
#4571742 - 11/12/17 11:39 AM
[Re: Chris B.]
Loc: USA
Thanks gentlemen! I appreciate the advice! Is the Altrom - Mountain brand, Altrom - Brembo brand and Altrom - Fremax brand different rotors made by the same company? No, They are made by different companies. In this case, Mountain, Brembo, and Fremax. You probably know who Brembo is. Mountain is a Japanese brake disc manufacturer (they supply a lot of Japanese OEM rotors), and Fremax is a large Brazilian brake disc mfr. The Fremax rotors are made in Brazil, while the Mountain rotors are probably made in China, but could be made in Japan. The Brembos could be made anywhere, but probably China, maybe Mexico, and if you're lucky, Italy. Altrom is an importer/distributor of parts for foreign cars, similar to Beck/Arnley. For these rotors, you'll probably get Mountain/Brembo/Fremax rotors in an Altrom box. There's a small chance they'll come in the original box with an Altrom label slapped on them.
#4571869 - 11/12/17 02:13 PM
[Re: Chris B.]
Loc: Campbellsville, KY
I've installed dozens of pairs/sets of Napa brakes, mostly their mid-level SS-??? pads and premium rotors. I believe the SS pads are just OE-spec, whatever that may be, and in instances where that's semi-metallic (2006 Dodge Caravan, for instance) I've noticed plenty of dust on some cars which has me more aware of just putting on their SS pads without question. The rotors have always done well.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 110K '85 GMC C3500, 454, 130K '82 Mercedes 300CD, OM617 turbo, 165K '67 Suburban, 350, 331K
#4572561 - 11/13/17 09:22 AM
[Re: artbuc]
Loc: sw ohio
I put these pads on my Honda Accord v6 Coupe with Centric rotors. The high performance Akebonos are smooth, quiet and clean but just don't have the bite I expected. The best setup, in my opinion, is to install semi-met pads and Centric high carbon rotors (can withstand semi-met pads). This is the European setup. If your tires are up to it, can put you thru the windshield when needed.
#4573244 - 11/13/17 08:28 PM
[Re: Chris B.]
Loc: Crawfordville FL
Which akebono? ProACT or Street Performance?
Also as they are ceramic they bite much more when you get a little heat in them. A couple hard stops will make a big difference in pedal response.
Edited by SilverFusion2010 (11/13/17 08:29 PM)
2010 Ford Fusion SE 3.0L V6, 178k miles M1 AFE 0w-20
#4573341 - 11/13/17 10:18 PM
[Re: Chris B.]
Loc: Birmingham, AL
As far as Napa branded, I avoid anything other than Adaptive One or Fleet. Around here they carry Akebono for most Japanese brand cars.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 211K miles 1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 198K miles
#4573480 - 11/14/17 06:47 AM
[Re: SilverFusion2010]
Loc: sw ohio
"Which akebono? ProACT or Street Performance?
Also as they are ceramic they bite much more when you get a little heat in them. A couple hard stops will make a big difference in pedal response."
Opps- They are the ProACt. Regarding getting a little heat on the pads with a couple of hard stops to improve pedal response- that is true but one can't predict when a emergency stop is necessary. It is what it is where it is. Pads may be cold when this happens.
