VIRGIN ST2 STP FILTER CUT OPEN
by 53' Stude. 09/19/18 05:08 PM
Chrysler HOAT at 9 years...
by burla. 09/19/18 04:34 PM
Septic Tank pumping question
by wormwood1978. 09/19/18 03:46 PM
A5/B5 or A3/B3
by ka9mnx. 09/19/18 03:27 PM
LingLong
by sloinker. 09/19/18 02:42 PM
2018 Grand Caravan review
by tiger862. 09/19/18 02:39 PM
Diagnosing gas furnace
by Oro_O. 09/19/18 01:16 PM
Let's talk dipsticks and oil capacity
by csandste. 09/19/18 12:32 PM
Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
Alday714, Joephoto, tlelectric, sandin67, paigemoody547
66019 Registered Users
81 registered members (2013ecof150, 4WD, 28oz, 16HC, 007, 14Accent, 11 invisible), 1,437 guests, and 41 spiders.
Topics290,675
Posts4,848,154
Members66,019
Most Online3,590
Jan 24th, 2017
Oil + filter Recommendation for 2007 Honda Fit #4570964
11/11/17 04:01 PM
11/11/17 04:01 PM
Ohio
99ytrewq911 Offline OP
Ohio
Hello guys, first post. Would like some ideas.
1. What kind of vehicle you have
2007 Honda Fit 4cyl 111k miles.
Between break in period and 88k miles, 5w-20 dino oil was used every 3k, along with some mid-range filter, brand unknown.
At 88k, I switched it to M1 5w-20 (15k interval edition) and M1 (20k interval edition) filter.* I change oil and filter when the Honda Maintenance Minder dings, between 6k and 8k for safety.
Currently no oil loss whatsoever, maybe less than 2% but I'd be unable to measure this on a dipstick.
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well
3.8quarts 5w-20 API oil.
3. Where you live
Ohio, not really dusty at all, but ambient temps -25 to 95.
I do lots of roadtripping all over the place, but I think Ohio's weather range is somewhat close to some other regional extremes.
4. How you drive (easy? hard? fast? slow?)
heavy foot, faster, sometimes will take it slow but usually aggressive on the pedal.
Hitting the track is not out of the question.
Will let cruise control take over often
5. What your daily drive is like (short trips? long trips? city? highway?)
I will do long trips going down a random interstate for enjoyment, or many short trips picking items up from stores/pricechecking, and all sorts of city errands.
Between 20 and 200 miles a day, average 100. Half I would say is highway or more, it really depends on the day.
I like road tripping, often also.
Another interesting note, I carry alot of weight in the car, I required an upgrade to the coil springs so they can haul more weight without sagging.
300 pounds extra weight at all times not including other passengers, so expect the car to be nearing GVWR 700lbs ( +- 100lbs I think) at some points.
Maybe I should get a diesel van haha.
6. Whether your car has any known problems
No known problems, no detectable oil loss.
Other
I prefer synthetic for winter starts.
I am curious about additives such as Lucas stabilizer(synthetic version?), bestline, and others.
I have seen a good scientific test by the Youtube channel Project Farm, he bought two motors, and used bestline in one, regular oil in other, and saw how long it took the motor to seize after draining all oils. Bestline added motor lasted just under twice as long.
Does BITOG have any suggestions on additives or if they are good at all?
I also did use seafoam in the oil once, and it did drain darker, with no new leaking.
* Interesting note about the oil filter I use. I buy them from Walmart, and on the packaging it says 20K miles rating. I browsed O'Reillys and found only 15k rated "gold" M1 filters. I asked the clerk if he thought it could have been branding or marketing, and he said Walmart does receive older products than an auto store. Walmart does not have 15k rated M1 gold filters. Does anyone know much about this?
I have a personal preference for M1 but I heard they got worse in the past few years, I picked them because I compare metrics such as total mileage ratings (hence 15k oil). I understand this isn't the best idea.
I don't mind ordering oil online, but I prefer storebought.
Would pay a bit more for nice oil.
Thank you everyone.
Re: Oil + filter Recommendation for 2007 Honda Fit [Re: 99ytrewq911] #4570973
11/11/17 04:14 PM
11/11/17 04:14 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Any low grade synthetic or syn blend would work for 5-7k. Even a good conventional would work.
Re: Oil + filter Recommendation for 2007 Honda Fit [Re: 99ytrewq911] #4571008
11/11/17 04:46 PM
11/11/17 04:46 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
I like Synthetics. The Valvoline Max Life 5w20 is really good and pretty cheap.
Beyond that, the Mobil1 High Mileage is what I use in our 2006 Acura TSX with 170K miles.
As was posted, any good oil, with a decent filter, will be fine.
I use Wix, Mobil1, Purolater or those K&N Pro Series filters.
All good.
Re: Oil + filter Recommendation for 2007 Honda Fit [Re: 99ytrewq911] #4571009
11/11/17 04:46 PM
11/11/17 04:46 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
All good.
Re: Oil + filter Recommendation for 2007 Honda Fit [Re: 99ytrewq911] #4571031
11/11/17 05:09 PM
11/11/17 05:09 PM
USA
slacktide_bitog Offline
USA
welcome
Use any quality 5w20 or 0w20 for the OCI suggested by the computer. For cars like yours with that minder, I like to use the cheapest synthetic on sale.
For a filter, use either Fram Ultra, Wix/Napa Gold, Wix XP/Napa Platinum
Re: Oil + filter Recommendation for 2007 Honda Fit [Re: 99ytrewq911] #4571105
11/11/17 06:42 PM
11/11/17 06:42 PM
BerksCounty/Pa.
thorromig Offline
thorromig  Offline
BerksCounty/Pa.
How about the Pennzoil Platinum High Mileage 5W20 paired with a Fram Ultra. Pennzoil currently has a $10.00 rebate with the purchase of 5 quarts of synthetic oil at the moment also. Hope your shopping at Wal Mart for your oil & filter -- best way to save money. Welcome aboard also to BITOG -- let me tell you -- it gets addictive!!
00 Dodge Ram 5.2L 4x4 Edge 10W30 FU (91K)
08 Acura TL Type S 3.5L PUPP 5W20 FU (101K)
17 Jetta TSI SE 1.4L Turbo - Edge 0W40 FU (Hers) (4K)
Re: Oil + filter Recommendation for 2007 Honda Fit [Re: 99ytrewq911] #4571143
11/11/17 07:31 PM
11/11/17 07:31 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Skip any oil additives. If 0w-20 is working then stick with it. M1 is excellent oil
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: Oil + filter Recommendation for 2007 Honda Fit [Re: 99ytrewq911] #4571157
11/11/17 07:46 PM
11/11/17 07:46 PM
Georgia
MParr Offline
MParr  Offline
Georgia
If the owners manual specifies 5w20, stick with it. For filter, use OE Honda, Wix or NAPA Gold.
2013 KIA Optima EX 2.4L. Now: QSUD 5W30 & STP S2808ML
2017 Ford Escape SE 2.0T Now: Pennzoil Platinum 5W30 & Motorcraft 910s
Re: Oil + filter Recommendation for 2007 Honda Fit [Re: 99ytrewq911] #4572095
11/12/17 07:07 PM
11/12/17 07:07 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
Agree with most of the above, find an inexpensive (sales, clearance, rebates, etc.) major name syn or even semi syn 0/5w20 and run it until the MM says to change-I can usually get good oil, M1, Valvoline Syn, PP, etc for $4-10 a fill.
I stick with the OE A01 Filtech filters, otherwise Id fun a FU.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
