Are all Dexos 1 Gen 2 Oils the Same?
by Gene K. 09/22/18 01:58 PM
ECOGARD X10479 CUT OPEN
by 53' Stude. 09/22/18 01:38 PM
Rust-Oleum Driveway Sealer review
by SVTCobra. 09/22/18 01:24 PM
Flush OAT/IAT mixture
by OpenClose. 09/22/18 12:20 PM
And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
63 registered members (911Don, Bailes1992, Astro14, A310, 53' Stude, 8 invisible), 1,898 guests, and 37 spiders.
Topics290,826
Posts4,851,073
Members66,040
Most Online3,590
Jan 24th, 2017
Changing ATF in Toyota with No Dipstick ? #4570906
11/11/17 02:45 PM
11/11/17 02:45 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Im getting ready to change the ATF in my 05 LS430 and my son's 09 IS350. Neither one has dipstick. I'm read a little and it seems very important to check the ATF at a certain temp. I have a infrared thermometer whereby I could get some decent temps all over the pan and sort of take an average. OR, i can just drain out what I can while it is cold and simply add that much back.
Is there some device I can purchase that will take the ATF temp? Or should I just assume it was properly filled from the factory?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Amsoil in all engines, transmissions and differentials
Re: Changing ATF in Toyota with No Dipstick ? [Re: Gebo] #4570919
11/11/17 03:01 PM
11/11/17 03:01 PM
Minnesota
leje0306 Offline
leje0306  Offline
Minnesota
When I owned my 2012 4Runner, I recall there was a procedure that included jumping terminals on the obdii port that would cause the trans temp light to flash at the correct temp.. Im not sure if that applies to your Lexus
Re: Changing ATF in Toyota with No Dipstick ? [Re: Gebo] #4570924
11/11/17 03:06 PM
11/11/17 03:06 PM
Ajax,Ontario, Canada
Pelican Online content
Pelican  Online Content
The proper procedure would require a Lift, a vacuum pump, another pump for the fluid, a vacuum regulator and a special tool made by Toyota if the tranny fluid is above the recommended temp. All this will take approx 1.5 to 2 hrs. NOBODY does it this way as too costly and time consuming. Go to Weber University on U Tube to see it. This is why Toyota/Lexus have a machine that does all this via the cooling lines of the transmission, about 30-45 min time wise. It's precise and IMO well worth the cost.
Re: Changing ATF in Toyota with No Dipstick ? [Re: Pelican] #4570927
11/11/17 03:09 PM
11/11/17 03:09 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Engineered to prevent DIY car maintenance.
2004 Corolla 124786
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Changing ATF in Toyota with No Dipstick ? [Re: Gebo] #4570930
11/11/17 03:15 PM
11/11/17 03:15 PM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
Unfortunately Toyota wants you to take it to the dealerships for service.
Re: Changing ATF in Toyota with No Dipstick ? [Re: Gebo] #4570934
11/11/17 03:17 PM
11/11/17 03:17 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Re: Changing ATF in Toyota with No Dipstick ? [Re: Gebo] #4570935
11/11/17 03:20 PM
11/11/17 03:20 PM
Toronna
maxdustington Online content
maxdustington  Online Content
Toronna
The reason for the temperature stuff is because the fluid expands when it gets hot, and the fluid drained from a hot trans will take up more volume than ambient temp fluid from a bottle.
You can do it the simple way and let the car cool off outside and put your new jug of oil outside so the fluid in the trans and the new fluid will be the same temp. You then measure how much came out and put the same back in. Easy peasy.
My 03 jetta 1.8 5 spd auto has no dipstick, only a fill hole. I had to use this method to change the "lifetime" fluid at 200k km. I'm not sure how you would put the fluid back in on your car, but there has to be a fill hole or a sensor hole that can be used to fill.
The cooler line flush is the way to go, but just doing a D&F is better than nothing. My car can drain 3.5 out of 5 litres I think and the first change made a big diff in how it shifted, the old oil was black as coal.
Edit: Wow, I just watched that vid. That is intense! I would just pull the plug and straw, drain it and replace what was removed. I think the idea is that a shop will not be able to wait for the car to cool down, so they have to be able to replace hot fluid with ambient temp fluid. That is not necessary for a DIYer. I think a D&F is better than a cooler line flush in this instance as how could you check the fluid level with any sort of accuracy? On my car you have to put the trans through the gears to fill the galleries in the trans before using the stand pipe to check the level, and people on forums seems to have to add a little extra fluid even then.
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
Re: Changing ATF in Toyota with No Dipstick ? [Re: Gebo] #4570939
11/11/17 03:25 PM
11/11/17 03:25 PM
New England
Virtus_Probi Offline
New England
When the "lifetime" ATF in my RAV4 got blacker'n Hades, I found a local Toyota specialty shop that had purchased the special extractor to deal with the stupid design of that tranny.
Still expensive, but way cheaper than the dealer and they seemed to know what they were doing and care about their customers.
2014 Forester XT, 86000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Changing ATF in Toyota with No Dipstick ? [Re: Gebo] #4570946
11/11/17 03:31 PM
11/11/17 03:31 PM
Louisiana
Bebop367 Offline
Bebop367  Offline
Louisiana
Pretty good write up and how to get to proper level:
http://www.agcoauto.com/content/news/p2_articleid/345
I done it twice with no problems.
Would be whole lot easier with a dipstick.
Re: Changing ATF in Toyota with No Dipstick ? [Re: Gebo] #4570978
11/11/17 04:16 PM
11/11/17 04:16 PM
Southeast
BlakeB Online content
BlakeB  Online Content
Southeast
On my Tacoma I use my ultragauge to check the fluid level at the proper temp. (97-115F) I jumped the two pins on the obd2 port (4,13)and started the temp check procedure and then plugged my UG back in the last time I did a pan drain and verified that the fluid was to be checked at 97-115, some people on the forums say that the range is 115-130, clearly it's not, at least not in my case.
Re: Changing ATF in Toyota with No Dipstick ? [Re: BlakeB] #4570994
11/11/17 04:37 PM
11/11/17 04:37 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
Interesting find! I can't imagine there is a massive difference in fluid level if you check at 108*F vs at 125*F.
But one thing we can't confirm (I assume you maybe are a member over at TacomaWorld) is that the AT OIL TEMP light uses the same PIDs as the Ultragauge. On my Torque OBD app, I was able to get the Trans Pan and TC Outlet temps, but both were based on formulaic PIDs..
Re: Changing ATF in Toyota with No Dipstick ? [Re: Gebo] #4571056
11/11/17 05:35 PM
11/11/17 05:35 PM
Utah
CKN Offline
CKN  Offline
Utah
Take it to a dealer or reputable independent shop.
Re: Changing ATF in Toyota with No Dipstick ? [Re: Reddy45] #4571104
11/11/17 06:42 PM
11/11/17 06:42 PM
Southeast
Southeast
No, but what I can confirm is when the temp check light comes on and goes off for my vehicle. Now I don't need to put it into temp check mode to check the fluid level. It would be interesting to install an OBD2 splitter and see what techstream showed vs the ultragauge. What I can tell you is this, after my truck sits all night, the coolant and atf temps will be exactly the same at startup. For example, when I went to work yesterday I got in my truck after it had been sitting outside for 10 to 12 hours, the coolant and atf at the pan and TC were all 41F.
Somebody checked on a 4runner and the difference in fluid level between the cool side of the temp check range and the hot side was about 6oz. 18 degrees in the temp check range and 6oz of fluid difference = 1oz per 3 degrees of temperature change.
I am on TW, 07 sport 4x4.
I have a few posts in the last few pages of this thread.
https://www.tacomaworld.com/threads/diy-full-flush-for-automatic-transmission.68462/page-41
Re: Changing ATF in Toyota with No Dipstick ? [Re: leje0306] #4571163
11/11/17 07:55 PM
11/11/17 07:55 PM
Kentucky
Fsharp Offline
Fsharp  Offline
Kentucky
Same deal on my 2007 ES350. Jumping 2 pins in the port and a certain procedure of starting the car and moving the shifter. In mine not the trans temp light, but the transmission gear indicator display would flash.
It worked, but next time Im letting the dealer handle it.
I dont like the drain, measure and then fill with the same amount route because who knows if the right amount was in there before.
Re: Changing ATF in Toyota with No Dipstick ? [Re: JohnnyJohnson] #4571191
11/11/17 08:25 PM
11/11/17 08:25 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Sad...but true.
Eliminates indy car repair shops, too mad
