I just read a post in this forum where a very knowledgeable person said that the "Golden Rule was to use Dino in the Rear." That really got my attention. I want to know more about this. Anybody got time for their input? I have a teachable spirit....
I have never heard about the Golden Rule for differential fluids. However, I would never use anything but a synthetic in a differential in a cold weather climate. This isn't the video I was looking at, but it demonstrates the difference between a dino and a synthetic diff fluid in cold weather. While the synthetic is a 75W and the dino is an 80W, the dino still doesn't offer flow like it should, even when it reaches the temperature where it is supposed to start working.
Originally Posted By: LoneRanger
Dino (conventional) adheres to the gears better than synthetic.
Based upon what? Any factual information to share to substantiate this statement?
IMO, if it's a regular use rear-end and not for towing or hauling heavy loads I would use conventional at the right viscosity recommended by the manufacturer for the climate it's operated in. Otherwise I would go to synthetic for higher heat applications.
Dino does not "adhere" better to anything unless you are talking about deposits in an engine.
Synthetic “adheres” to that little book that comes in the glove box… some may have noticed OEM’s spec synthetic in gear sets before it became more common in the ICE …
Never heard of that golden rule. Currently running Castrol Syntrax 75w90 Synthetic in an 01 Tacoma with OM spec of 80w90 dino. Purchased on AZ close out <$5 a bottle. Guess that means that's one 'golden rule' I won't be observing.
It's the KV@40*C that matters.
Oh yes, dino has higher pressure-viscosity coefficient than synthetics god in PAO's providing thicker MOFT for stronger components protection as a primary function of lubrication, all other parameters are secondary.
Yes. Group I and II oil has better polarity. Group III, which majority of "synthetics" are today, has poor polarity for metal cling as compared to Grp I and II. Known fact and common knowledge on here.
In farm equipment with gear boxes that we see that sit for 6 to 9 months at a time that have syn gear oil in them. You can see the gears will have rust on them from the oil line and up. Never have seen that with dino oil in them. The syn oil drains off of them completely with that much sit time and they have no protection.
How does that equate to less wear or longer oil life?
