2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
Comma X-Tech 5w30 oil, any good?
by BobGoblin. 12/17/18 11:40 AM
Modern Engine's Grenading?
by Nickdfresh. 12/17/18 11:15 AM
Magnetic Smartphone Holders
by willbur. 12/17/18 11:06 AM
1991 Caprice 5.0l hard starting in the AM
by WyrTwister. 12/17/18 10:55 AM
Question about new Peak OEM coolants
by PD001. 12/17/18 10:21 AM
Rev X
by Big_3_Only. 12/17/18 10:04 AM
Modern engines put less contaminants in the oil?
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
harvey_01, Gordon_Walter, MikeSheng, stantaur, Brandon9797
66703 Registered Users
103 registered members (aba4430, 4WD, 99Eclipse, AdditiveOCD, 8 invisible), 2,088 guests, and 47 spiders.
Topics295,186
Posts4,929,407
Members66,703
Most Online2,553
Oct 27th, 2018
Page 1 of 5 1 2 5
2017 Pentastar - tick on startup #4570233
11/10/17 06:57 PM
11/10/17 06:57 PM
Great White North.. eh
webfors Offline OP
webfors  Offline OP
I've noticed a tick on startup with our new van, especially now that it's getting colder.
It lasts about 2 seconds, which indicates the oil reaches the ticking area and it stops.
Is this normal for the 3.6 Pentastar? Is it filer related?
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w20, Fram DL11665
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: 2017 Pentastar - tick on startup [Re: webfors] #4570250
11/10/17 07:14 PM
11/10/17 07:14 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Sounds like an oil flow restriction. I'd be changing filters.
Re: 2017 Pentastar - tick on startup [Re: Merkava_4] #4570295
11/10/17 08:06 PM
11/10/17 08:06 PM
webfors Offline OP
webfors  Offline OP
Or poor ADBV design on the filter or housing? Trying another filter is probably the easiest/first thing to try I agree.
Re: 2017 Pentastar - tick on startup [Re: webfors] #4570326
11/10/17 09:06 PM
11/10/17 09:06 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Assuming you are using the OEM Mopar cartridge filters, I imagine you are just hearing a tensioner, I wouldn't be worried about it.
My wife's quiet FWIW, but we are running markedly different oils if your sig is current.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: 2017 Pentastar - tick on startup [Re: webfors] #4570332
11/10/17 09:10 PM
11/10/17 09:10 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Thinking ADBV also....2 secs is about right to fill the filter...
Thick vs Thin test: 15k / 43k miles complete
Re: 2017 Pentastar - tick on startup [Re: OVERKILL] #4570354
11/10/17 09:50 PM
11/10/17 09:50 PM
webfors Offline OP
webfors  Offline OP
Not using the OEM filter. I'm thinking replacing the oil filter is the next best step.
Re: 2017 Pentastar - tick on startup [Re: webfors] #4570381
11/10/17 10:18 PM
11/10/17 10:18 PM
WI
HoosierJeeper Offline
WI
My 3.2 Cherokee does it, running Mopar filters.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: 2017 Pentastar - tick on startup [Re: webfors] #4570385
11/10/17 10:20 PM
11/10/17 10:20 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
How old is the PentaStar as they revised the filter in the newer ones to help stop with the drain back and with lifter ticking.
Make sure you have the right filter in use. The first version does fit both engine revisions but won't function properly in newer Pentastars.
First Version (WIX 57526)
Revised Version (WIX WL10010)
Also make sure who ever is doing the oil change that they clip the filter into the housing lid before screwing it back into the housing. I've seen places that just drop them in the housing and tighten the lid over top and it damages the filter in the process.
My dads is a 2012 and takes the older one and my Father inlaw takes the newer one. I use Wix in both because I can get them at a good price and I have had 0 issues with them if you want to try them as a reference to see if it remedies the problem.
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: 2017 Pentastar - tick on startup [Re: webfors] #4570387
11/10/17 10:33 PM
11/10/17 10:33 PM
WI
WI
I want to say 2013 and up have the new design.
Re: 2017 Pentastar - tick on startup [Re: webfors] #4570391
11/10/17 10:37 PM
11/10/17 10:37 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Yeah but if you have some turkey at a shop somewhere that just looks up by engine size and doesn't realize there is a second filter that also fits the housing but is wrong it could be a newer engine with the older filter design and as a result it's allowing the oil to drain back and possibly not even filter it because of the differences.
Re: 2017 Pentastar - tick on startup [Re: webfors] #4570392
11/10/17 10:39 PM
11/10/17 10:39 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Some of the Pentastars had bad roller rockers as well so if a lifter is draining back slightly it could cause ticking there until it refills with oil. Good news is these are relatively easy to change depending which one it is and there is lots of YouTube videos about it.
Re: 2017 Pentastar - tick on startup [Re: StevieC] #4570405
11/10/17 10:57 PM
11/10/17 10:57 PM
webfors Offline OP
webfors  Offline OP
I think this might be it. I have an appointment Wednesday at the dealer. Same dealer that replaced the engine in my 2013. They have a good service department.
RE: filter types, thank you. I do all my oil changes and I'm using the correct filter. The dealer was nice enough to swap out my old filter stash for the new when I traded the van in for the new 2017.
Hopefully it's an easy fix. The van only has 20k KMs on it.
Re: 2017 Pentastar - tick on startup [Re: StevieC] #4570407
11/10/17 11:00 PM
11/10/17 11:00 PM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
Our 2007 is a 10w30 motor and it does not do this
maybe workers were thinner and dressed better on the shop floor back then
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: 2017 Pentastar - tick on startup [Re: StevieC] #4570412
11/10/17 11:18 PM
11/10/17 11:18 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Well, the title of the thread says it is a 2017 wink
Re: 2017 Pentastar - tick on startup [Re: webfors] #4570413
11/10/17 11:20 PM
11/10/17 11:20 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Duh, missed that... I've been up since 4am. That's my excuse... Coffee2 <--- Clearly I need some.
Page 1 of 5 1 2 5
