Here's the third oil change on my V-10.
Code:
Miles on lube 1113 4883 5226
Miles on Unit 1113 5996 11222
Fe 34 21 14
Ch 0 0 0
Ni 1 0 0
Al 7 4 4
Cu 22 7 3
Pb 0 0 0
Sn 0 0 0
Cd 0 0 0
Ag 0 0 0
V 0 0 0
Si 88 46 24
Na 10 5 4
K 8 3 2
Ti 0 85 93
Mo 85 24 17
Sb 0 0 0
Mn 4 1 0
Li 0 0 0
B 211 79 64
Mg 15 12 11
Ca 2068 2161 2134
Ba 3 0 0
P 757 679 680
Zn 760 797 840
Fuel dilution 2.3 2.8 2.6
Soot
Water
Vis, 100C cSt 7.4 8.6 8.9
The mileage on the oil is up slightly, the fuel is down a bit and the viscosity is improved. I am wondering if the tow/haul mode is creating some of the dilution at high rpm, closed throttle times. This last drain I used t/h about 50% of the time vs. 100% the previous. We climbed the Rockies twice: the engine braking is excellent in t/h. On flat land I left it off.
Otherwise, wear metals have dropped off as expected and everything looks good. I will continue the 5000 mile drains and continue to experiment with tow/haul. I'm looking for Dnewton3s input.
Code:
Fe 34 21 14
Ch 0 0 0
Ni 1 0 0
Al 7 4 4
Cu 22 7 3
Pb 0 0 0
Sn 0 0 0
Cd 0 0 0
Ag 0 0 0
V 0 0 0
Si 88 46 24
Na 10 5 4
K 8 3 2
Ti 0 85 93
Mo 85 24 17
Sb 0 0 0
Mn 4 1 0
Li 0 0 0
B 211 79 64
Mg 15 12 11
Ca 2068 2161 2134
Ba 3 0 0
P 757 679 680
Zn 760 797 840
Soot
Water
