New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
82 registered members (53' Stude, Ablebody, 28oz, 2013ecof150, ABomb369, 55hambone, 8 invisible), 1,688 guests, and 44 spiders.
Topics290,722
Posts4,849,037
Members66,021
Most Online3,590
Jan 24th, 2017
Between these three, what oil? #4569877
11/10/17 01:10 PM
11/10/17 01:10 PM
West Ma.
rollinpete Offline OP
West Ma.
Hi Bitog community...
I want to change out the rear differential oil on my suv that's in my sig, I doubt it's ever been changed....The book says 80w 90 premium oil...I need 5.5 pints...Can I get away with using...
#1 one of these?-https://www.walmart.com/ip/Super-Tech-80W-90-High-Performance-Gear-Oil-1-Gallon/16795067
or
#2 three of these?-https://www.walmart.com/ip/Super-Tech-75W-90-Syn-Blend-Gear-Oil-1-Quart/16795248
or
#3 three of these?-https://www.amazon.com/Genuine-Ford-XY-80W90-QL-Premium-Lubricant/dp/B000NU1D3U
Can I use the cheapest one ? Is there much of a difference? Or maybe another. What would you use? The truck runs Great, and I plan on keeping it for a long time, I was ready to buy the 75w90 syn blend but am wondering if the weight of the oil would be okay...I'm trying to go the cheapest route... Thanks!
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive184k miles
Last Change;
Penn. Plat. HM. 5w30
Fram xg8a, Fram CA8141
I like my oil (slippery).
Re: Between these three, what oil? [Re: rollinpete] #4569886
11/10/17 01:17 PM
11/10/17 01:17 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I think cheapest is fine.
The Explorer Sport should be a 8.8" rear, which can handle 500HP pretty reliably.
I don't think the ol' 4.0 is working it all that hard grin
Re: Between these three, what oil? [Re: rollinpete] #4569918
11/10/17 01:57 PM
11/10/17 01:57 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I think that requires a full synthetic.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Between these three, what oil? [Re: rollinpete] #4569933
11/10/17 02:12 PM
11/10/17 02:12 PM
Nebraska
BJD78 Offline
BJD78  Offline
Nebraska
Some Ford rear diffs also require a couple of ounces of ford friction modifier in addition to the 80w90 gear oil. I would check with a ford shop, perhaps they have a gear oil that ha the friction stuff already mixed in. any of those 3 would do the job as well as the other.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
Re: Between these three, what oil? [Re: rollinpete] #4569946
11/10/17 02:28 PM
11/10/17 02:28 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
GOLDEN RULE: Dino oil in the rear.
Why don't you use Pennzoil or Valvoline or Mobil HD.
If it says 80w Id. stick with 80W.
But now Here come the axle seal leaks.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Between these three, what oil? [Re: rollinpete] #4569950
11/10/17 02:32 PM
11/10/17 02:32 PM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
If you have AutoZone get the Delo 75w90 full synthetic for $5.99/qt. It's been priced wrong for a few years.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: Between these three, what oil? [Re: rollinpete] #4569994
11/10/17 03:27 PM
11/10/17 03:27 PM
Midwest USA
LoneRanger Offline
LoneRanger  Offline
Midwest USA
Follow the owner manual recommendation. You'll get a thousand different recommendations here. Just follow owner manual recommendation and you have to deal with the Paralysis of Analysis that can set in with so many options laid out before you.
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: Between these three, what oil? [Re: RedOakRanch] #4570115
11/10/17 05:53 PM
11/10/17 05:53 PM
California
nthach Offline
nthach  Offline
California
+1, it's a really good for what it is.
I think you'll be fine with either option, but do check if the diff calls for any FM additive to be added. If the diff hasn't been touched there's a small stamped metal tag that says if FM or a specific weight is needed. If not, on the door or B-pillar certification label there's a axle code and you can see if it's a regular diff or limited slip based on that code here: http://www.blueovaltrucks.com/tech-artic...e-door-sticker/
Re: Between these three, what oil? [Re: rollinpete] #4570195
11/10/17 07:07 PM
11/10/17 07:07 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Yes, go for the ST 80W90 for its higher [email protected]*C (data not available unfortunately), never mind it's mineral.
[email protected]*C of modern day 75W90 generally does not comply with the original requirements in an 80W90 specified in your (pre-1999) book , which typically varies from [email protected]*C 150 cSt to 320 cSt.
JMHO.
Re: Between these three, what oil? [Re: rollinpete] #4570211
11/10/17 07:29 PM
11/10/17 07:29 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Where do you see that you need 80w-90?
The copy online I found shows you need 75w-140 synthetic fluid since you have the 4.0, and if you have a limited slip, you need to make sure you add friction modifier (even if the fluid you use says it has it, the Ford LS wants more than what is in the bottles).
I have Supertech 75w-140 in my truck right now, Valvoline 75w-140 in my brother in laws F150, and have used Lucas 75w-140. I have always added the Motorcraft XL-3 LS fluid to them (they all have LS).
Just use the cheapest one you can find (Valvoline at AAP with a coupon code can be had for cheap depending on the code).
1994 Honda VT1100: Peak 15w-40/PSL/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
Re: Between these three, what oil? [Re: blupupher] #4570241
11/10/17 08:05 PM
11/10/17 08:05 PM
Albany, NY
ford46guy Offline
ford46guy  Offline
Albany, NY
When these trucks came out in the mid-90s they were speced for 80W-90
Now (late 90s) Ford changed that spec to 75W150, especially if there is a limited slip.
The Valvoline fluid needs the friction modifier. I have cobra clutches in the explorer and it was making noise. It is now perfectly quiet.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Between these three, what oil? [Re: rollinpete] #4570256
11/10/17 08:21 PM
11/10/17 08:21 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
Many 8.8s call for 75W140, but if you have an open (non-LS) diff, 80W90 should be fine for that year. I use cheap 80W90 in my 1994 open 8.8. That said, 75W140 is fine to use in all 8.8s.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 216K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 199K miles
Re: Between these three, what oil? [Re: ford46guy] #4570265
11/10/17 08:28 PM
11/10/17 08:28 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Ford 75W140 has a KV @40*C of 191 cSt ..........falling within the range of 150 cSt to 320 cSt.
The above statements from blupupher and ford46guy make perfect sense , indicating engineers from Ford holds on to their grounds vis-a-vis marketing and/or finance guys ...... for now.
Not sure if penalty against CAFE (non-)compliance has been incurred though.
Re: Between these three, what oil? [Re: ARCOgraphite] #4570328
11/10/17 10:07 PM
11/10/17 10:07 PM
VA
Gebo Offline
Gebo  Offline
VA
Splain it, please. Or if I should already have read it here, I ask for forgiveness.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Between these three, what oil? [Re: blupupher] #4570559
11/11/17 08:17 AM
11/11/17 08:17 AM
West Ma.
West Ma.
page 224 http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/97expog1e.pdf
I have the non limited slip differential... door sticker says the axle is 41
Pete.
Last Change;
