Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Z08969, TCU_Adam, deaner1979, jdana24, KlenFrappe379
71061 Registered Users
74 registered members (AndyB, 94astro, 4WD, AurionX2, atikovi, BeerCan, 6 invisible), 1,381 guests, and 18 spiders.
Topics303,499
Posts5,235,235
Members71,061
Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota #4569765 11/10/17 12:05 PM
T
Texasdoc Offline OP
T
Custom 408W in a cobra replica with about 3000 miles total on the motor. I built it with all new parts except the 1982 block. Full machining with line hone, head decking, etc. It has AFR 195 heads. About 1500 miles ago I had to completely rebuild the heads. TWO spring failures (one intake, one exhaust, one on each side) required me to replace all intake valves, 2 exhaust valves, all springs, and all valve guides. No idea why the springs failed. I've checked spring height, seat pressure, verified lift, pushrod length, etc.
Anyway, after the rebuild, I ran Castrol Dino 10W-30 for about 200 miles, then drained, replaced the filter (WIX) and switched to Valvoline VR1 10W30. This oil had about 1000 miles. After I replaced the oil, I noted the motor was pinging a bit. I have reduced the timing to eliminate the pinging.
I'm not sure where the Aluminum, chromium, Iron, Copper, and Silicon is coming from. Not sure if it is left over from the rebuild or something new going on. I run a K&N air filter with a PCV system so I don't know where dirt/silicon could be getting in.
While draining this oil, it looked a lot darker/dirtier than the previous Castrol, so I went back to Castrol (white bottle). It also seems to run smoother/quieter with the Castrol. It has roller lifters and rockers, so I don't really need the increased Zinc of the VR1.
Any thoughts? Where do you think this combination of metals is coming from?
Code:
Aluminum   26
Chromium    8
Iron       61
Copper     19
Lead        5
Tin         1
Molybdenum 22
Nickel      1
Manganese   2
Silver      0
Titanium    2
Potassium   4
Boron      29
Silicon   236
Sodium    285
Calcium  2016
Magnesium 11
Phosphorus 1127
Zinc.    1319
Barium.   0
SUS   58.8
cST   9.89
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Texasdoc] #4569779 11/10/17 12:12 PM
K
Kuato Offline
K
Sounds like a fun car!
At only 3000 miles on what is a new engine, I'd think those are still initial wear metals. You should see the numbers come down over the next 10k-20k miles. That's my opinion, and of course a few more UOAs are in order to watch the trends.
Thick vs Thin test: 15k / 43k miles complete
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Kuato] #4569803 11/10/17 12:22 PM
L
Linctex Offline
L
I agree, even though "High Perf Aftermarket" parts are designed to make HP, the machine work is usually pretty bad.
You can expect a fair amount of metal as everything wears in - - and I don't see anything alarming about your numbers.
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Texasdoc] #4569807 11/10/17 12:24 PM
L
Linctex Offline
L
Silicon can come from sealant.
K&N filters are pretty porous and let a fair amount of dust through.
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Texasdoc] #4569821 11/10/17 12:33 PM
B
bullwinkle Offline
B
Your Si numbers are pretty high, that would account for the high wear metals, along with still breaking in. I didn't see what filter you were using, I would try a high efficiency filter like a Royal Purple, Fram Ultra, or even a Fram Tough Guard to try to catch as much crud as possible-and either cut open the filter or send it to someone here to see what it is catching. A K&N air filter is a rock catcher, if your part of TX is the least bit dusty a better filter, or a foam pre filter over your K&N, would also be a smart move.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Texasdoc] #4569855 11/10/17 12:51 PM
Chris142 Online Content
Online Content
That Silicone is huge! How much sealer was used? Hopefully that much is not getting past the air filter.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Texasdoc] #4569960 11/10/17 02:44 PM
V
Virtus_Probi Offline
V
This report scared me off K&N air filters, actually returned one that I had purchased but not used.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
2014 Forester XT, 114800 miles
Last Change;
Valvoline AFS 5W30
Tokyo Roki 15208AA170 oil filter
Subaru 16546AA10A air filter
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Texasdoc] #4569992 11/10/17 03:27 PM
T
Texasdoc Offline OP
T
I have the typical oval Cobra-style filter. Due to hood restrictions, I can't use a 14" round filter. I tried a 9 inch round that was about an inch taller, but actually had less filter area. I can go back to the paper filter.
I'm going to watch the silicone. It may just be resetting the oil pan, heads and intake.
I am using the WIX 51515 - standard Ford F1A size. Most of what I've read states that as long as it is a decent filter (aka: not Fram) they are all about the same. It is not a racing filter with a 70 micron filter size. I did cut one open between the Castrol and the VR1 and didn't find any metal bits.
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Texasdoc] #4570064 11/10/17 04:39 PM
T
Texasdoc Offline OP
T
Since I have an open hood scoop, I need a filter that will tolerate getting wet. I don't plan on driving in the rain, but have gotten wet a few times. The paper filters won't work. If they get wet in the rain, they will dissolve. WIX makes a cellulose filter that may work. Is cellulose a paper, cotton, or foam filter?
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Texasdoc] #4570076 11/10/17 04:55 PM
T
Texasdoc Offline OP
T
The WIX cellulose filter is a paper filter.
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Texasdoc] #4570700 11/11/17 10:55 AM
A
advocate Offline
A
Ditch the K&N and go back to a paper filter for best filtration while you are sorting things out with this engine. Also don't be afraid of Fram oil filters, they are good! They have a better filter media then the Wix or Ford/Motorcraft/Purolator filter. A filter that filters better will do nothing but help you out. Any Fram will do with your short intervals, the extra guard, tough guard, Ultra or their Racing line even.
Fram Racing Oil Filter
Re: Ford 408W, 10W-30 VR1, 1000 mi interval, 5000 tota [Re: Texasdoc] #4570750 11/11/17 11:43 AM
L
Linctex Offline
L
See if AEM makes a fibered (not paper) filter that fits your oval air cleaner.
