Sharpening Drill Bits
by ET16. 03/23/19 08:03 AM
more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
86 registered members (alarmguy, advocate, 4WD, Astro14, 1foxracing, 5 invisible), 1,584 guests, and 53 spiders.
Topics286,272
Posts4,905,717
Members67,589
Most Online2,967
Mar 10th, 2019
2017 Ford F53 6.8V-10-Kendall GT-1 5W-30 5226 mile #4569550
11/10/17 08:39 AM
11/10/17 08:39 AM
USA
AITG Offline OP
AITG  Offline OP
USA
Here's the third oil change on my V-10.
Code:
Miles on lube  1113   4883   5226
Miles on Unit  1113   5996  11222
Fe               34     21     14
Ch                0      0      0
Ni                1      0      0
Al                7      4      4
Cu               22      7      3
Pb                0      0      0
Sn                0      0      0
Cd                0      0      0
Ag                0      0      0
V                 0      0      0
Si               88     46     24
Na               10      5      4
K                 8      3      2
Ti                0     85     93
Mo               85     24     17
Sb                0      0      0
Mn                4      1      0
Li                0      0      0
B               211     79     64
Mg               15     12     11
Ca             2068   2161   2134
Ba                3      0      0
P               757    679    680
Zn              760    797    840
Fuel dilution   2.3    2.8    2.6
Soot            <.1    <.1    <.1
Water           <.1    <.1    <.1
Vis, 100C cSt   7.4    8.6    8.9
The mileage on the oil is up slightly, the fuel is down a bit and the viscosity is improved. I am wondering if the tow/haul mode is creating some of the dilution at high rpm, closed throttle times. This last drain I used t/h about 50% of the time vs. 100% the previous. We climbed the Rockies twice: the engine braking is excellent in t/h. On flat land I left it off.
Otherwise, wear metals have dropped off as expected and everything looks good. I will continue the 5000 mile drains and continue to experiment with tow/haul. I'm looking for Dnewton3s input.
The answer to 80% of BITOG questions: Read the book, follow directions.
Changing oil is not maintenance. Maintenance is the science of inspecting equipment to find and fix things before they break.
Re: 2017 Ford F53 6.8V-10-Kendall GT-1 5W-30 5226 mile [Re: AITG] #4569754
11/10/17 11:49 AM
11/10/17 11:49 AM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
Your UOA looks good for relatively new engine. The only things that really stand out are the fuel dilution of 2.6% and cST viscosity of 8.9, barely just in the 30 wt range. And this is after only after a ~5200 miles OCI on a Modular engine. Normally these Modular engines are usually quite easy on oil. Maybe the V-10 Modular is tougher on the oil than the V-8 Modular's.
Whimsey
Re: 2017 Ford F53 6.8V-10-Kendall GT-1 5W-30 5226 mile [Re: AITG] #4569792
11/10/17 12:16 PM
11/10/17 12:16 PM
WV
loneryder Offline
loneryder  Offline
WV
Looks good to me. I get similar uoa's for my RV v-10 using Syn 5-20. I tow a trailer or a dolly with a car and motorcycle. Only use T/H in the mtns. Don't use a drop of oil in 4-5k. My last uoa had some fuel in it. I think because I idled it to warm it up to change the oil and it never got hot enough to evaporate everything. Is that what you did?
Re: 2017 Ford F53 6.8V-10-Kendall GT-1 5W-30 5226 mile [Re: AITG] #4569816
11/10/17 12:32 PM
11/10/17 12:32 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
How many qts sump? %5k seem low miles for a big sump. if 6qts, then I get it.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: 2017 Ford F53 6.8V-10-Kendall GT-1 5W-30 5226 mile [Re: AITG] #4569925
11/10/17 02:07 PM
11/10/17 02:07 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Iron is coming down nicely and honestly looks really good for an engine working that hard with that much swept volume. The fuel is what it is, my guess is that the open loop fine tips in around 70-80% load or throttle position and might be a little rich to prevent detonation which may be where the fuel is coming from, it certainly didn't hurt anything. Looking good!
Luke
Re: 2017 Ford F53 6.8V-10-Kendall GT-1 5W-30 5226 mile [Re: AITG] #4573242
11/13/17 09:24 PM
11/13/17 09:24 PM
USA
AITG Offline OP
AITG  Offline OP
USA
This sample illustrates the difference between a problem and an occurrence. While the fuel dilution isn't what I would like to see, the wear metals indicate that the engine is suffering NO ill effects. That makes the dilution an occurrence and not a problem.
It does tell me that 5000 miles is going to be my limit on OCI.
BTW: it's a 7 quart capacity including a coolant-to-lube oil cooler. No oil added between changes.
Re: 2017 Ford F53 6.8V-10-Kendall GT-1 5W-30 5226 mile [Re: AITG] #4587205
11/28/17 06:43 AM
11/28/17 06:43 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
The wear metals are all dropping; Al, Cu, Pb have already normalized. Fe it is coming down very nicely. This engine will continue break-in for perhaps another OCI or two, and then should be fairly steady after that.
Clearly the fuel, at this level, isn't affecting wear. If it doubled to 5%, I'd be more cautious. But at this level, it's just fine. Fuel dilution has been reasonably consistent, and yet wear is dropping with break in. I have no idea why there is that amount of fuel; more than I'd expect to see as mod motors (never being DI, but MPI) just typically never have much fuel. But, regardless of the origin, it's not hurting anything at this level. Worth keeping an eye on ... but nothing to use as an excuse to change something. Sure - we'd like to see fuel below 1%; so what? There is no correlation exhibited here; let's not cause a panic where none is due.
Cannot recall what the OCI is per OEM; 5k miles? I'd stick to OEM OCI simply for warranty at this point. Then you might be able to stretch it out a bit.
Motor on with confidence!
What UOA service is this? Just curious.
Side note - I with that the V-10 was still available in the SD primary line-up (F250/F350); would probably prompt me to get a new truck. Although, from what I've seen, the 6.2L is a stout engine as well.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2017 Ford F53 6.8V-10-Kendall GT-1 5W-30 5226 mile [Re: dnewton3] #4588450
11/29/17 08:27 AM
11/29/17 08:27 AM
USA
AITG Offline OP
AITG  Offline OP
USA
OCI is 5000 miles per Ford. I'll stick to that for the foreseeable future.
The lab is Polaris.
