Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
112 registered members (allgm59, 928, Ag76, Alfred_B, Aero540T, Altima2, 10 invisible), 2,058 guests, and 57 spiders.
Topics286,236
Posts4,904,901
Members67,582
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Filter Minder #4569477
11/10/17 07:04 AM
11/10/17 07:04 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
Any tips for installing a Filter Minder?
I bought it because the Journey seems to go through filters like crazy and they aren't cheap so I would like to run them as long as possible.
-Should I try to under drill the hole in the air-box slightly for a tight seal?
-Maybe silicone around the grommet?
I got the K&N one that tops out at 10"
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Filter Minder [Re: StevieC] #4569484
11/10/17 07:20 AM
11/10/17 07:20 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Re: Filter Minder [Re: StevieC] #4569499
11/10/17 07:41 AM
11/10/17 07:41 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
That doesn't answer my question. It just talks about drilling a 11/32 hole and installing as per directions included along with the provided grease. Not about under drilling slightly and/or silicone or maybe some other tip folks can provide.
Re: Filter Minder [Re: StevieC] #4569503
11/10/17 07:46 AM
11/10/17 07:46 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
My bad for trying. Lesson learned here. If time permitted I'd delete previous post but timed out. Mods feel free to delete my posts on this thread.
Re: Filter Minder [Re: StevieC] #4569506
11/10/17 07:52 AM
11/10/17 07:52 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
No it's fine, thanks for posting the link. I had read that though... cheers
Re: Filter Minder [Re: StevieC] #4569518
11/10/17 08:04 AM
11/10/17 08:04 AM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
You can very slightly under-size the hole for a tighter fit or just use some K&N air filter grease around the grommet. Nothing special about the grease, but it was the most readily available and cheapest I could find online. My PSD came with a filter minder from the factory and I added some filter grease the first time I changed the air filter.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: Filter Minder [Re: StevieC] #4569530
11/10/17 08:16 AM
11/10/17 08:16 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Measure the sealing surface then drill a hole about .050 smaller. When you put the gauge in it wil expand the grommet. No sealer needed.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Filter Minder [Re: StevieC] #4569540
11/10/17 08:23 AM
11/10/17 08:23 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
A filter minder is a good idea and many diesel trucks come with one. But if your in mouse country better check once or 2X a year for mouse nests.
2015 Ford F250 w/Powerstroke
Re: Filter Minder [Re: Chris142] #4569545
11/10/17 08:34 AM
11/10/17 08:34 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
I was thinking a 21/64 hole instead of the 11/32. My dad has odd size bits.
Re: Filter Minder [Re: StevieC] #4569596
11/10/17 09:08 AM
11/10/17 09:08 AM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
I used one of those step drill bits and didnít need grease. I originally had the k&n version but it would max out on a brand new OEM filter so I went with a wix that goes up to 25Ē h2o
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Filter Minder [Re: StevieC] #4569607
11/10/17 09:22 AM
11/10/17 09:22 AM
One Step Beyond
MasterSolenoid Offline
One Step Beyond
My biggest concern would be to get the best seal around grommet.
That means you need a perfectly round hole.
I would rule out using a regular two flute drill bit.
I've sometimes used those on thin sheet-metal and actually had a triangle shaped hole when finished.
As another poster said, use a Step Drill Bit.
That will give you a nice round hole.
https://www.harborfreight.com/catalogsearch/result/index/?dir=asc&order=EAScore%2Cf%2CEAFeatured+Weight%2Cf%2CSale+Rank%2Cf&q=step+drill+bit
Clean off any burrs and apply a little Silicon Grease for easy installation.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Filter Minder [Re: StevieC] #4569611
11/10/17 09:24 AM
11/10/17 09:24 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
I have a step drill bit, what I might do is do the 21/64 hole with a standard bit and then clean the hole with a step bit but not let it get to the 11/32 hole they ask you to drill so that this way it's as tight/round as possible.
Re: Filter Minder [Re: StevieC] #4569692
11/10/17 10:48 AM
11/10/17 10:48 AM
Nevada, USA
gaijinnv Offline
gaijinnv  Offline
Nevada, USA
I installed the same gauge and found the 11/16" hole is perfectly sized for the supplied grommet. A little K&N grease around the grommet and on the filter minder assures a perfect seal.
IMPORTANT NOTE: Silicone grease should be no where near your air intake. Please use the K&N grease which is designed to be safe near MAF sensors.
Here's my post on the install: Filter Minder Install
HTH
USN NAVSECGRU 1970-1974
Re: Filter Minder [Re: StevieC] #4569731
11/10/17 11:27 AM
11/10/17 11:27 AM
ON, Canada eh?
StevieC Offline OP
StevieC  Offline OP
ON, Canada eh?
My Journey doesn't have a MAF. Only a MAP / Air Temperature sensor and the air temperature sensor is coated in a ceramic glaze. I'm good!
Re: Filter Minder [Re: StevieC] #4569763
11/10/17 12:04 PM
11/10/17 12:04 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I hate to burst your bubble, StevieC ..... but you will never draw 10"Hg on your Dodge Journey filter.
If you do... It will be completely caked clogged (& I'll bet it is near-collapse)
If you were to take your airbox and hook up several shop vacs to it, and try to pull 10"HG on it,
I'll bet you destroy your air filter from the force before you reach 10"HG
Page 1 of 5 1 2 5
