Quote:
In general, the normal range in males is about 270 to 1070 ng/dL with an average level of 679 ng/dL. A normal male testosterone level peaks at about age 20, and then it slowly declines. Testosterone levels above or below the normal range are considered by many to be out of balance.
That's Dr. Jeffry S. Life MD, PhD in the picture. In this video, he advocates that testosterone levels in the lower end of the normal range is not beneficial and causes health issues. He recommends testosterone levels of 800ng/dl or above for good male health. He says most doctors say if you're in the normal range, you're good. He disagrees. He says he gets his patients into the higher numbers of the normal range with the treatment and then gets them into a good diet and exercise program. He says your motivation for exercise increases dramatically with an increase in testosterone levels. He also says that testosterone treatment boosts confidence, reduces feelings of depression, and even reverses Type-2 Diabetes. And then there's the other physical benefits that we can't talk about here but you guys probably already know.
Any of you guys on testosterone therapy ?
