Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
06/22/18 05:13 PM
Xfinity mobile cell service
by jay929
06/22/18 04:37 PM
Fuse "failure"
by dlundblad
06/22/18 04:32 PM
Do you Bluetooth your phone and car?
by ZZman
06/22/18 04:20 PM
Hastings air filters
by Spitter
06/22/18 04:18 PM
2011 Town and Country remote started itself.
by mrsilv04
06/22/18 04:06 PM
Vaughan Hammer and Superbar $10 Sam's
by hatt
06/22/18 04:03 PM
Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
Bench Drill Press
by Propflux01
06/22/18 02:30 PM
IAT Sensor
by artbuc
06/22/18 02:26 PM
2013 Nissan Rogue, 5,100 miles, Supertech Conv
by TheOilWizard
06/22/18 01:46 PM
NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
83 registered (2015_PSD, 93cruiser, bdcardinal, ammolab, Astro14, 77GrandPrix, 13 invisible), 1486 Guests and 57 Spiders online.
65294 Members
67 Forums
285789 Topics
Page 1 of 2 1 2 >
#4569214 - 11/09/17 07:35 PM PP Euro 0w40 - cold flow properties
webfors Offline
Loc: Great White North.. eh
Is this for real!?
http://www.pennzoil.com/en_ca/products/f...c_Motor_Oil.pdf
-40 degrees celcius MRV of 13,200
Is this the only 0w40 with cold flow properties this good?
While this is not Dexos certified, I suspect it would be a great oil in the new ATS... thoughts?
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w30, Fram DL11665
15 DL650, Valvoline 20w50, KN-138
Small engines; RT5 10w30
#4569216 - 11/09/17 07:39 PM Re: PP Euro 0w40 - cold flow properties [Re: webfors]
webfors Offline
The non Euro PUP is more what I would expect, and closer to M1's 0w40 in terms of cold flow specs:
http://www.pennzoil.com/en_ca/products/f...tinum-0W-40.pdf
#4569221 - 11/09/17 07:42 PM Re: PP Euro 0w40 - cold flow properties [Re: webfors]
69GTX Offline
Loc: Connecticut
Don't know about the low MRV. Maybe because of the GTL? It's certainly better than the 21,600 M1 0w-40 claims.
I note that both of these oils do not show BMW LL-01 approval. So they are similar in that regard too. wink
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4569245 - 11/09/17 08:02 PM Re: PP Euro 0w40 - cold flow properties [Re: webfors]
dishdude Offline
Loc: Phoenix
Anyone know if they sell PP Euro at Autozone or O'Reilly? I need some 5w-40 for my Fiat.
2018 Challenger SRT
#4569249 - 11/09/17 08:05 PM Re: PP Euro 0w40 - cold flow properties [Re: dishdude]
SatinSilver Offline
Loc: OH
I'd check Amazon first.
Pennzoil Euro 5w40
Edited by SatinSilver (11/09/17 08:05 PM)
#4569265 - 11/09/17 08:17 PM Re: PP Euro 0w40 - cold flow properties [Re: webfors]
Virtus_Probi Offline
Loc: New England
Interesting that the non-Euro 0W40 has slightly better CCS results but much worse MRV numbers...I guess those two tests are measuring quite different physical properties, anyway.
I haven't seen a VOA for either product, but I'd guess the Euro product is probably high SAPS and might have a lot of calcium that could be problematic for LSPI...but, it also might have a lot of ZDDP that would help quench LSPI. The Pennzoil Euro L oils are mid to low SAPS that are likely low in calcium but probably also with a low starting TBN.
2014 Forester XT, 80500 miles
Last Change;
Valvoline Full Synthetic 5W30 d1G2
Tokyo Roki 15208AA170 filter
#4569299 - 11/09/17 09:05 PM Re: PP Euro 0w40 - cold flow properties [Re: webfors]
1JZ_E46 Offline
Loc: Oregon
Castrol EDGE 0W-40 pour point is -53C! Due to it being mostly PAO.
EDGE product data sheet
Unfortunately Castrol doesnt list actual pumping or cranking viscosities. Regardless safe to assume it wins.
Edited by 1JZ_E46 (11/09/17 09:08 PM)
2007 BMW X5 4.8i, 105K: Castrol EDGE 0W-40, Mann
2012 Mini Cooper, 45K: Castrol EDGE 0W-30, Mann
#4569459 - 11/10/17 05:45 AM Re: PP Euro 0w40 - cold flow properties [Re: webfors]
shanneba Offline
Loc: Indiana (IN)
Red Line 0w-40 has a pour point of -60 C.
CCS Viscosity, Poise, @ C [email protected]
https://www.redlineoil.com/Content/files/tech/0W40_MO_PROD_INFO.pdf
2003 BMW 330Ci
2013 HD Sportster XL1200C
#4569512 - 11/10/17 06:58 AM Re: PP Euro 0w40 - cold flow properties [Re: shanneba]
webfors Offline
How does that translate to cP for comparison?
#4569515 - 11/10/17 07:01 AM Re: PP Euro 0w40 - cold flow properties [Re: webfors]
Loc: New England
The c is for centi-, just multiply Poise by 100 to get cP.
Last Change;
#4569621 - 11/10/17 08:37 AM Re: PP Euro 0w40 - cold flow properties [Re: webfors]
webfors Offline
I would be nice to have the -40 results for comparison.
#4569658 - 11/10/17 09:20 AM Re: PP Euro 0w40 - cold flow properties [Re: shanneba]
OVERKILL Offline
Loc: Ontario, Canada
Which turns into 5,700cP @ -35C, which compares to 5,960cP @ -35C for the SOPUS product and 6,062cP @ -35C for AMSOIL signature and 5,888cP @ -35C for AMSOIL Euro 0w-40.
Given the repeatability of the test, they are all extremely close.
2016 Durango Limited
2016 Grand Cherokee SRT
#4569705 - 11/10/17 10:04 AM Re: PP Euro 0w40 - cold flow properties [Re: webfors]
webfors Offline
Can we conclude the Pennzoil is almost entirely GTL or PAO? It has cold weather numbers that compare to PAO/Ester products.
#4569758 - 11/10/17 10:57 AM Re: PP Euro 0w40 - cold flow properties [Re: webfors]
OVERKILL Offline
From the MSDS:
So 5-15% PAO and then 0-90% some low-vis base oil which, if it is similar in VI to a PAO, would be 4.xcSt @ 100C.
That points to a whole lotta VII.....
#4570406 - 11/10/17 10:59 PM Re: PP Euro 0w40 - cold flow properties [Re: OVERKILL]
zeng Offline
Loc: Malaysia
From the MSDS:
Thanks Overkill, on the msds details.
Could Pennzoil GTL 0W40 keep VII low enough to be close to Redline's , by employing 6/8/10 cSt @100*C GTL basestocks ?
From PDS, what parameter I should look for to 'assess' whether thin 4 cSt or thicker 8 cSt @100*C base stock is used , that's of course assuming 8/10 cSt is available in the market ?
Page 1 of 2 1 2 >
