Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
119 registered members (2015_PSD, 555, 97f150, 69Torino, 2012AccentSE, 64bawagon, 16 invisible), 2,108 guests, and 59 spiders.
Topics286,156
Posts4,903,136
Members67,565
Most Online2,967
Mar 10th, 2019
Changing radiator on driveway with slight slope #4569077
11/09/17 05:36 PM
11/09/17 05:36 PM
ny
llmercll Offline OP
llmercll  Offline OP
ny
I need to swap the radiator on my 2003 Jetta and the only place I can do it is my driveway with a slight slope. This is a new place and I've never jacked the car up on this driveway, in addition my garage is full of junk so it's my only choice if I want to DIY. I believe the driveway is less steep near the bottom so I would probably do it there.
https://i.imgur.com/4eZwRWc.jpg
https://i.imgur.com/sFVWR5z.jpg
https://i.imgur.com/dlZNx4k.jpg
https://i.imgur.com/ch00lGA.jpg
I would engage the parking brake, jack up the front two tires, place jack stands, and then chock the rear wheels. I just wonder if this is too much of an incline to do safely.
Thanks!
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4569081
11/09/17 05:39 PM
11/09/17 05:39 PM
USA
oldhp Offline
oldhp  Offline
USA
If you do as you say I would say you are good to go.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4569083
11/09/17 05:42 PM
11/09/17 05:42 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You're fine. Nothing to worry about.
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4569084
11/09/17 05:45 PM
11/09/17 05:45 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I'm glad to see that you decided to attempt the job.
My driveway slopes both ways from a peak in the center, and I am used to it. It isn't really any more dangerous sloped to the rear like that as long as the wheels are chocked. I would almost prefer that because you will theoretically gain more clearance under the front and there is more weight on the rear end of the car making it a bit more stable.
Personally I would back it up more to gain more room in front of the garage door. I suppose you will be opening the garage door, but you will be working in that area and you will want enough room to lay down under the bumper to get that lower rad hose. If you are going to flush it through the lower rad hose you will be working in that area a lot.
Nice car dude, but you should consider fixing those rusty fenders. I did mine last year and it is much worse underneath than on the surface, trust me.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4569089
11/09/17 05:53 PM
11/09/17 05:53 PM
MN
Tman220 Offline
Tman220  Offline
MN
Thanks!
You will be fine on the slope, HOWEVER, One major thing I would change is set your wheel chocks at the rear tires FIRST You then put the car in neutral and let the car roll into your chocks until it stops, then set your parking brake, then you can jack the car up and set it on jackstands. Doing this will greatly reduce the risk of the car shifting/moving while you are jacking it up and/or placing the jackstands.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4569106
11/09/17 06:23 PM
11/09/17 06:23 PM
ON, Canada eh?
StevieC Online content
StevieC  Online Content
ON, Canada eh?
My dad's driveway has the same slope and I just put a wheel-stop on the back tire and put on the emergency brake. You're fine.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4569112
11/09/17 06:35 PM
11/09/17 06:35 PM
Chicago, IL
EdwardC Online content
EdwardC  Online Content
Chicago, IL
Agreed with the others, you'll be fine. Also agree with Tman, chock the wheels first, let your car roll into them, then set the parking brake. This way you have the wedged tires in addition to the brakes keeping the car from moving.
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4569141
11/09/17 07:06 PM
11/09/17 07:06 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
I would back it up to the garage and drive forward up on ramps if you have them.
"Zed's dead baby, Zed's dead."
Re: Changing radiator on driveway with slight slope [Re: rooflessVW] #4569164
11/09/17 07:41 PM
11/09/17 07:41 PM
ny
llmercll Offline OP
llmercll  Offline OP
ny
I believe I need to take the tires off for the rad replacement.
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4569203
11/09/17 08:27 PM
11/09/17 08:27 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
You could do it in the street.
Do you really need to have it on jack stands to change the radiator?
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4569271
11/09/17 09:27 PM
11/09/17 09:27 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
YOU sir, are just fine.
Thick vs Thin test: 15k / 43k miles complete
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4572592
11/13/17 10:48 AM
11/13/17 10:48 AM
ny
llmercll Offline OP
llmercll  Offline OP
ny
Just want to let everyone know the repair went well =)
Re: Changing radiator on driveway with slight slope [Re: Kuato] #4572806
11/13/17 01:44 PM
11/13/17 01:44 PM
Atlanta, GA
RoGuE Offline
RoGuE  Offline
Atlanta, GA
I don't see how anything could make it in to the garage...
2007 Chevrolet Malibu
2.2L Ecotec
Re: Changing radiator on driveway with slight slope [Re: llmercll] #4573327
11/13/17 10:54 PM
11/13/17 10:54 PM
New York
JoeJ Offline
JoeJ  Offline
New York
I also have an inclined driveway. It works fine just use a floor jack and adjust your jackstands to what you need. A magnetic level is a good thing to use too.
Joe
