Originally Posted By: Traction
Originally Posted By: stockrex
I am buying 2 tires from amazon, where do I go to get them install on my fit?
Walmart? Costco?
I am getting General Altimax, anyone use them, good for snow? hwy?
Your tires are going to be useless, and dangerous if your only buying 2! Buy 4 or nothing. You are not saving a dime only buying 2.
That's a strange sentiment. I used to buy 2 tires once in a while too. I used to get lazy and not rotate the tires so the fronts would wear out after 50-60k and the rears were still good up to 80k. So after a while, I'd just buy 2, stick them on the rear and then rotate them later. Then it would repeat... Eventually I got rid of the car without having to buy 2 more.
I used to buy online, but then I just had the local tires store price match. They end up charging you tax but they don't charge to mount the tire, just for balancing. If you didn't buy the tires there, then there's an extra charge for mounting plus when you buy them there, you get lifetime balance, rotation which you don't get when you just bring the tires in.
