The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
29 registered members (Agnosto, Bailes1992, carlprop, c502cid, chance, 4 invisible), 634 guests, and 62 spiders.
Topics286,097
Posts4,902,471
Members67,560
Most Online2,967
Mar 10th, 2019
What is a catch can? #4568876
11/09/17 01:33 PM
11/09/17 01:33 PM
Missouri
chiefsfan1 Offline OP
Missouri
Alright I have read on this board people using catch cans.
Now this is dumb but what is that? shrug
MacBean Clan Motto: Touch Not A Catt Bot A Targe. (Don't touch this cat without a shield).
2011 Toyota Camry XLE 2.5 I4
2014 Escape SE 1.6 EcoBoost AWD
Re: What is a catch can? [Re: chiefsfan1] #4568878
11/09/17 01:38 PM
11/09/17 01:38 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
It condenses oily vapors from the crankcase PCV / Breather hose system before allowing it go back into the engine via the throttle body or intake so that only air returns and not oil. Although there is question about their effectiveness in daily drivers. It cuts down on the oil that is burned or that can leave gunky residue on things like valves etc.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: What is a catch can? [Re: chiefsfan1] #4568885
11/09/17 01:44 PM
11/09/17 01:44 PM
Missouri
Missouri
Interesting. Thanks! I research them. Having s Eco Boost had me thinking.
Re: What is a catch can? [Re: chiefsfan1] #4568891
11/09/17 01:53 PM
11/09/17 01:53 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
If you do put one in put something in that will help the oil condense before returning because of high under hood temperatures it could keep the oil-vapor in vapor right through the entire can and back into the system. Some folks will put the can in the bumper or in front of the radiator to keep it cooler and condense the vapor. Just make sure where you put it, it is accessible because it will need emptying if it catches anything.
Re: What is a catch can? [Re: chiefsfan1] #4568902
11/09/17 02:01 PM
11/09/17 02:01 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Most of the catch cans I've seen that are effective usually have a steel-wool stuffing or wire mesh to not only increase the surface area of the 'catch' material and thereby make it more effective, but the hidden and likely main reason for this is that since the PCV gasses have to navigate a longer path through the steel wool, the gas cools off significantly. This may be why some folks stick the can in the bumper or in the airflow- they dislike the slight mess the mesh creates and think it's unneeded, hindering the performance of their can.
P.S.- 'most' port-injected daily drivers will probably not 'need' a catch can. If you have a GDI engine, it may certainly help with both LSPI and intake valve deposits.
Re: What is a catch can? [Re: SubieRubyRoo] #4568904
11/09/17 02:06 PM
11/09/17 02:06 PM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
Can't speak for LSPI but cans do next to nothing for intake deposits. Ask the VW/Audi guys who had them real bad, installed cans, and they did nothing to help.
Re: What is a catch can? [Re: chiefsfan1] #4568906
11/09/17 02:08 PM
11/09/17 02:08 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
Something else to consider with your direct injection engine is the volatility of the oil. Less evaporative loss is a good thing but with DI engines it means less to gunk up the intake and valve stems. The Petroleum Quality Institute of America has lists of PCMO tests where you can look at properties of many different brands pretty easily: http://pqiamerica.com/PCMO_Sample_Summary_12_15_2016.html
You don't need a catch-can or worry about oil volatility...but this is BITOG.. every incremental little bit is mandatory.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: What is a catch can? [Re: chiefsfan1] #4569166
11/09/17 07:42 PM
11/09/17 07:42 PM
WV
loneryder Offline
loneryder  Offline
WV
You also need to prevent them from freezing up in cold weather as there is a lot of moisture in that vapor.
Re: What is a catch can? [Re: loneryder] #4569301
11/09/17 10:06 PM
11/09/17 10:06 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
You might not want them filling up with water, either.
2011 Toyota Prius now at 97K
