When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
96 registered members (28oz, 64bawagon, ABomb369, Aero540T, AandPDan, advocate, 10 invisible), 1,180 guests, and 45 spiders.
Topics290,632
Posts4,847,745
Members66,011
Most Online3,590
Jan 24th, 2017
VDC light and brake light. 2016 Nissan Quest. #4568808
11/09/17 12:33 PM
11/09/17 12:33 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
We've been having a steady VDC light occasionally come on and most recently the "Brake" light on startup that goes out the first time you mash the brakes on our 2016 Nissan Quest SV with about 44K miles on it. We bought it "Certified Used" from a Nissan dealer in April 2017 with 32300mi on it.
The brake fluid reservoir is approaching the "add" line, but it's pretty close to between add and full, a tad closer to "add".
I pulled a front and rear wheel to check the brakes and the pads are pretty well worn, but could probably go another 10K miles+. The rear caliper pistons are extended a fair amount. The rotors look like new yet. Gotta love "certified used" when within 10K miles of purchase, you need 2 new tires and within under 12K miles, new brakes.
Could these lights be related to the amount of pad wear and brake fluid level? I've not experienced this with any of my other vehicles in the past. Just wondering if this is a Nissan thing? It's been a while since I've owned one. The last Nissans we owned were back around 2001 (2 different Sentras).
Thanks.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: VDC light and brake light. 2016 Nissan Quest. [Re: JTK] #4568817
11/09/17 12:40 PM
11/09/17 12:40 PM
Utah, USA
28oz Online content
28oz  Online Content
Utah, USA
Pad wear, probably not. Fluid level? Perhaps. My 2004 Quest is on its third ABS pump for the same issue. I get the light trifecta of Brake, VDC, and SLIP whenever it dies. It really could be a lot of things. Get the code pulled and go from there.
1990 Nissan 300zx - Castrol Edge Euro 0W-40
2004 Nissan Quest - Pennzoil Platinum Euro 0W-40
2003 Ford Excursion 7.3 PSD - Mobil 1 TDT 5w-40
Re: VDC light and brake light. 2016 Nissan Quest. [Re: 28oz] #4568833
11/09/17 12:54 PM
11/09/17 12:54 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
I forgot to add, I did scan for codes with my basic scanner and it indicated "no codes present". Perhaps a more advanced one will show something.
My model has several dash icons associated with the vehicle dynamics control. The one that stays lit from time to time is the icon of the car leaving skid marks. More recently is the word "brake", such as when the P-brake is on, which it isn't. We've cycled it. The "brake" light goes out. The skid mark (lol) light comes on at odd times when under way and then will be off after the next restart.
Re: VDC light and brake light. 2016 Nissan Quest. [Re: JTK] #4568842
11/09/17 01:01 PM
11/09/17 01:01 PM
California
nthach Offline
nthach  Offline
California
Any fluid leaks at the MC, lines or a flaky level switch at the reservoir? Maybe a broken CAN line from the PCM to the ABS ECU? But if you had a broken CAN line, you'd see a communications related DTC or even a CEL.
Re: VDC light and brake light. 2016 Nissan Quest. [Re: JTK] #4568845
11/09/17 01:02 PM
11/09/17 01:02 PM
Utah, USA
28oz Online content
28oz  Online Content
Utah, USA
Yes, you will need a fancier scanner than a typical engine code scanner. It will need to be capable of reading ABS codes. Some auto parts stores have them, some don't. If you bought it "certified" less than a year ago, maybe a trip to the dealer is in order. Even if you have to pay for a diagnostic, you'll at least know what you're up against.
Re: VDC light and brake light. 2016 Nissan Quest. [Re: JTK] #4568854
11/09/17 01:09 PM
11/09/17 01:09 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
Thanks. My first plan of action is to do a pad slap all the way around and go from there. I really don't want to take it in as-is, because the dealer will almost certainly want to replace brakes that won't be covered. I do have bumper/bumper coverage until 100K miles, but of obviously those don't cover wear items like brakes.
nthatch- No fluid leaks what so ever.
Re: VDC light and brake light. 2016 Nissan Quest. [Re: JTK] #4568857
11/09/17 01:11 PM
11/09/17 01:11 PM
Utah, USA
28oz Online content
28oz  Online Content
Utah, USA
thumbsup
Re: VDC light and brake light. 2016 Nissan Quest. [Re: JTK] #4568860
11/09/17 01:12 PM
11/09/17 01:12 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
That seems like an awfully short time of ownership for a certified vehicle to need brake work as mentioned. I'd call the sales manager about it since the salesman won't have any say in the matter. See if they will make things right. Since that should have been noticed when it was turned in. Never hurts to try.
Re: VDC light and brake light. 2016 Nissan Quest. [Re: SatinSilver] #4568867
11/09/17 01:24 PM
11/09/17 01:24 PM
Utah, USA
28oz Online content
28oz  Online Content
Utah, USA
Perhaps, but if there was enough pad material left to pass a state safety inspection, they likely didn't care when they "certified" the vehicle. That would just be added expense for the dealer that wasn't strictly and technically needed at time of sale.
Re: VDC light and brake light. 2016 Nissan Quest. [Re: SatinSilver] #4568868
11/09/17 01:25 PM
11/09/17 01:25 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
Yeah, it was a fiasco early on. Was missing the spare tire, had only one FOB and has some other small issues when I picked it up, even though all those items were checked off as being in order on the multi page check list that "certified vehicles" must pass prior to sale. My salesman quit the day after I picked the van up, etc.. You couldn't make this stuff up. I went on such a letter writing and phone calling mission after that, they extended my warranty for me and made all the above items right. They did replace two of the tires the day I picked the van up, but I'm sure they were with used tires. All 4 matched, but they weren't new from the get-go. Rears had probably 80-90%, fronts were 75%.
FWIW, I didn't buy this van because it was "certified", it just happened my darling bride liked it and it was a decent price.
Re: VDC light and brake light. 2016 Nissan Quest. [Re: JTK] #4568942
11/09/17 02:42 PM
11/09/17 02:42 PM
CA
The Critic Offline
The Critic  Offline
CA
Normal. Top off the brake fluid and the lights will go off.
2011 Toyota Prius - 173k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 131K - Mobil 1 EP HM 5W-30
Re: VDC light and brake light. 2016 Nissan Quest. [Re: JTK] #4568985
11/09/17 03:13 PM
11/09/17 03:13 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
at many dealers, "certified" means nothing except an inflated price. our "Certified" Jeep had a leaking transfer case, leaking rear end, and couple of others things wrong that "should" have been caught during inspection. lol
best yet, instead of fixing them gratis, they charged it against my extended warranty - who paid it, but called me to ask if these things were broken at delivery - to which I replied "yes".
I'm also not sure that you want dealer installed tires. Carmax put 4 new tires on ("Epic Tour") that vibrated like crazy. nothing could be done to get rid of the vibration (4 visits to 2 different shops) other than replace the tires with real tires.
2019 Cherokee, 2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: VDC light and brake light. 2016 Nissan Quest. [Re: tomcat27] #4569033
11/09/17 04:25 PM
11/09/17 04:25 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
Originally Posted By: tomcat27
at many dealers, "certified" means nothing except an inflated price.....
Absolutely agree. The only decent item this dealer chain includes with it is a 5yr/100K mile power train only warranty. The rest is genuine fluff and on delivery day, I called them out every item they pencil-whipped on their "certification" check list. It was a total joke. Like I say, we went this way after looking at and test driving older, way more beat and more expensive Honda Odysseys and Toyota Siennas. This Nissan cost me $19K everything all in. It stickered at over $30K new.
Realistically could have been bought new for $25K-ish + TTL.
Critic, thank you for confirming that! I mail ordered a full set of pads as well given the state of wear I saw.
Re: VDC light and brake light. 2016 Nissan Quest. [Re: JTK] #4572824
11/13/17 01:55 PM
11/13/17 01:55 PM
Buffalo, NY
JTK Offline OP
JTK  Offline OP
Buffalo, NY
In regards to my VDC and brake lights coming on/off, as The Critic suggested above, low brake fluid level is all it was caused by. While I'm waiting for my pad set to come in, I added enough brake fluid to satisfy the level switch for now.
It's kind of a neat feature built into these late model Nissans. Pads wear down, causing the caliper pistons to extend out, sucking up lots of brake fluid. The level runs towards the low mark on the reservoir triggering the level switch, which intermittently sets a VDC and/or BRAKE light. I've not had any other vehicle do this.
Like other cab forward vehicles I've seen, the Quest has two brake fluid reservoirs. One (sealed, no cap) on the firewall, then another one tubed to it within easy reach. The higher up, more forward one has the level switch.
