Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
Where automatic grade logic is a total fail.
by pezzy669. 06/26/19 10:53 PM
Help please! Possible chemical etch windshield
by NeedAdviceASAP. 06/26/19 10:40 PM
Insect / Ant Killer
by Warstud. 06/26/19 07:55 PM
120k Transmission - Flush or Drain
by Soflonole27. 06/26/19 07:53 PM
VOA - HCF-2, Eneos Import CVT Model H, Eneos ECO CVT
by Stucker21trt. 06/26/19 06:48 PM
2012 Mazda3 iTouring
by Kira. 06/26/19 06:46 PM
Blazer Chalet
by dishdude. 06/26/19 06:27 PM
So confused about Hemi oil
by TN Tracker. 06/26/19 06:20 PM
Gabby Chaves’ mobile oil change business
by Pat in Speedway. 06/26/19 06:03 PM
PUP 5w-30 - 2016 GS F - 5,051 miles
by Tiir. 06/26/19 05:41 PM
I-CAR Gold Class Car Wash...
by Vern_in_IL. 06/26/19 05:36 PM
Kia manual allows 5w20 and 5w30 but not 0w20?
by Whammo. 06/26/19 05:31 PM
Buy A Car...Get Freebies
by GrtArtiste. 06/26/19 05:09 PM
by Stucker21trt. 06/26/19 04:31 PM
Radar Dimax AS-8 Diamond in rough
by spiderbypass. 06/26/19 04:06 PM
icy hot additive for oils
by 1978elcamino. 06/26/19 03:33 PM
Why does diesel stink so much less than gas?
by atikovi. 06/26/19 02:29 PM
Chrisemme1, NeedAdviceASAP, Yuleeboy, Soflonole27, Bungalowbill
68504 Registered Users
27 registered members (carlprop, csandste, Dragon44, aleneros, dbias, ajchien), 860 guests, and 21 spiders.
Topics291,017
Posts4,997,180
Members68,504
Most Online2,967
Mar 10th, 2019
Amsoil SVG 75w90, 45K, 04 Chevy Tahoe #4568637
11/09/17 10:04 AM
11/09/17 10:04 AM
Texas
dhellman12 Offline OP
Texas
Will likely extend the next run to 55K based on Blackstone's recommendations. Overall looks like things are getting much better since we bought this one.
Make/Model: GM Differential
Vehicle: 2004 Chevrolet Tahoe
Code:
OIL             SVG 75w90	SVG 75w90	SVG 75w90	Unknown
MILES IN USE    45,514		35,159		25,128		Unknown
MILES ON UNIT   229K		183K		148K		123K
SAMPLE TAKEN    10/29/17	4/16/15		3/18/13		5/3/11
MAKE UP OIL	0		0		0		0
ALUMINUM	1		2		3		4
CHROMIUM	0		1		1		2
IRON		102		264		255		672
COPPER		1		5		7		28
LEAD		0		0		0		1
TIN		0		0		0		0
MOLYBDENUM	0		1		0		3
NICKEL		2		4		4		11
MANGANESE	3		6		6		26
SILVER		0		0		0		0
TITANIUM	0		0		2		0
POTASSIUM	0		0		0		0
BORON		84		93		100		179
SILICON		81		145		162		13
SODIUM		4		5		6		34
CALCIUM		6		5		9		42
MAGNESIUM	0		2		3		3
PHOSPHORUS	745		884		913		1683
ZINC		5		13		21		68
BARIUM		0		0		0		1
SUS @ 210F	79.9		83.2		88.3		69.0
Visc @ 100C	15.50		16.31		17.57		12.70
Flashpoint	425		400		415		370
Water %		0.0		0.0		0.0		0.0
Insolubles %	0.2		0.2		0.5		0.2
TAN		2.6		1.4		1.8		NA
Blackstone comments:
This is the longest oil run across the page, so it's great to see iron so low. The other metals followed iron's example, so we don't see anything cautionary here. Silicon seems to be slowly washing out of the system. It's probably just additive or harmless sealer as opposed to abrasive dirt contamination. No moisture shows up and insolubles are very low. The viscosity is fine for 75W/90 and the TAN of 2.6 shows little acidity. Great report for your rear differential
05 Kawasaki BF750 - 284hrs
12 Jeep 3.8L - Amsoil ASL 5w30 74K
04 DMax 6.6L - Amsoil AME 15w40 238K
00 WS6 5.7L - Amsoil ASL 5w30 256K
Re: Amsoil SVG 75w90, 45K, 04 Chevy Tahoe [Re: dhellman12] #4568648
11/09/17 10:12 AM
11/09/17 10:12 AM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
It could have gone 2x the mileage with no issues. The majority of wear that occurs in an axle happens from 1-10K miles which is why the iron trends downward exponentially on a per mile basis despite the runs becoming longer and longer. I have seen this in every UOA posted UNLESS there was a problem with the axle.
You can see similar behavior in the UOAs of my 2010 FX4.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & MB (Purflux) filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum Euro 0W-40 & Mann filter]
Re: Amsoil SVG 75w90, 45K, 04 Chevy Tahoe [Re: dhellman12] #4568814
11/09/17 12:37 PM
11/09/17 12:37 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
thumbsup
The important thing is the ferrous metals are TRENDING downward.
In your environment I would use a 75W110 from Lubrication Engineers or Amsoil's SVT:
https://www.amsoil.com/lit/databulletins/g2043.pdf
Infinity is a rather long time - especially towards the end. smile
Re: Amsoil SVG 75w90, 45K, 04 Chevy Tahoe [Re: MolaKule] #4568821
11/09/17 12:47 PM
11/09/17 12:47 PM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
+1 - I forgot to mention that.
Re: Amsoil SVG 75w90, 45K, 04 Chevy Tahoe [Re: dhellman12] #4568968
11/09/17 03:03 PM
11/09/17 03:03 PM
Vancouver, Canada
jaj Offline
jaj  Offline
Vancouver, Canada
Where'd all that silicon come from? The SVG VOA shows 13ppm, and the original unknown fill didn't show much, so it looks like dirt got in at the first change. That could contribute to the high iron.
Re: Amsoil SVG 75w90, 45K, 04 Chevy Tahoe [Re: jaj] #4569020
11/09/17 04:01 PM
11/09/17 04:01 PM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
The higher silicon levels after the first OC could be from silicone gasket sealer. I tend to think with the first OC at 123K and a Fe reading of 672PPM that it may take a bit to wash out ( perhaps not 60K miles over two additional OC's though).
Re: Amsoil SVG 75w90, 45K, 04 Chevy Tahoe [Re: dhellman12] #4575703
11/16/17 06:45 AM
11/16/17 06:45 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
Based on the design of most rear axles (I presume that's what we're looking at here), we should agree than not all the lube comes out upon a drain cycle; a LOT is left in the tubes.
Therefore the very high Fe at the first UOA was probably the result of a very long OCI. Then the subsequent OCIs / UOAs are showing a downward trend due to much of the residual being drained out time after time.
I'd advocate for 75k miles at a min with the SVG; maybe longer.
At 229k miles, not sure how much life is left in the vehicle overall. Mechanically it may be OK? What about rust, etc? At what point do you start to pare down on the expenses? I'm not saying there's been a bad decision thus far, but more a question of where's the practical end of ownership versus the ROI on such expenses like Amsoil and UOAs???
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Amsoil SVG 75w90, 45K, 04 Chevy Tahoe [Re: dhellman12] #5012842
02/16/19 06:41 AM
02/16/19 06:41 AM
Virginia, usa
Shata Offline
Shata  Offline
Virginia, usa
This is really awesome sample set to look at, thanks for sharing you can see awesome trend. 600ppm iron and 23ppm copper to start and how sharply the copper dropped in next 20k miles and down from there. Another two or three 20-30k sets and iron and copper will be nice and low. Really impressed with this data set. Gives you general Idea of how long it takes to get diffs to really break in and everything to wash out. Well I shouldnt say break in but...Unserviced Diff going to nice clean one.
16 Silverado 2500 LML 25k Miles
ST CK-4 15w-40
ST 75w-90 Diff.
ST Full Syn Dexron VI ATF
Fram Ultra XG9100, AC Delco Fuel
CAT Coolant filter, Fram Air, K&N Cabin
Filter Mags: Fuel, Allison, LML
