Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
112 registered members (2012AccentSE, Aichiguy, albenjoseph, 2015_PSD, 69Torino, Ag76, 13 invisible), 1,891 guests, and 59 spiders.
Topics286,112
Posts4,902,875
Members67,565
Most Online2,967
Mar 10th, 2019
Water Dispensing Line freezing up #4568543
11/09/17 08:22 AM
11/09/17 08:22 AM
MURICA
maverickfhs Offline OP
MURICA
So I have a GE fridge and in a week, 2nd time water line is frozen. Never happened in last 5 years, maybe it's getting old?
https://www.youtube.com/watch?v=iWDcbfUWqdY
Any suggestions to take care of it permanently, I can thaw it using hair dryer and few other tricks, but want to take care of it forever for cheap.
Any suggestions or advice? Thank you.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Water Dispensing Line freezing up [Re: maverickfhs] #4568556
11/09/17 08:32 AM
11/09/17 08:32 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
If it's chilling the water before it dispenses then it most likely has a coil of tubing somewhere near one of the cooling coils internally. It could be that the coils are icing up internally and freezing the water in the tubing. It's most likely caused by a bad defrost cycle timer, logic board problem or defrost heating coil not working properly.
What are the temperatures inside the fridge/freezer sections averaging?
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Water Dispensing Line freezing up [Re: StevieC] #4568563
11/09/17 08:47 AM
11/09/17 08:47 AM
MURICA
MURICA
Thanks, 9 is the coldest and freezer is at 3 and fridge section is at 3 too.
Water is coming from the supply line and freezing up where it dispenses, after using a dryer around dispensing area it's working fine now. Usually it happens overnight since no water use. Never happened during a daytime.
Re: Water Dispensing Line freezing up [Re: maverickfhs] #4568577
11/09/17 09:09 AM
11/09/17 09:09 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
If the dispenser is on the freezer side it's possible you have a cold air leak from the freezer around the tubing and as the air leaks out it's freezing the water in the nozzle. Can you feel drafts coming out around the nozzle when the compressor / circulation fan are running?
Also what is the actual temperature inside the freezer / fridge using a thermometer?
Re: Water Dispensing Line freezing up [Re: maverickfhs] #4568583
11/09/17 09:14 AM
11/09/17 09:14 AM
MURICA
MURICA
Yes, it's on the freezer side and I can feel cold air leak, definitely.
I have not checked actual temperature, but can check using an IR thermometer .
Re: Water Dispensing Line freezing up [Re: maverickfhs] #4568585
11/09/17 09:14 AM
11/09/17 09:14 AM
PimTac Offline
PimTac  Offline
Is the refrigerator located on a exterior wall? Your supply may be freezing because of a change in insulation. Mice for example or you forgot to cover the hose bibb for winter?
Cannot see signatures any longer so it doesn’t matter.
Re: Water Dispensing Line freezing up [Re: PimTac] #4568586
11/09/17 09:16 AM
11/09/17 09:16 AM
MURICA
MURICA
Thanks, I checked everything supply line is fine and it's ONLY freezing around dispensing area, everywhere else is good.
Re: Water Dispensing Line freezing up [Re: maverickfhs] #4568599
11/09/17 09:31 AM
11/09/17 09:31 AM
MN
ironman_gq Offline
ironman_gq  Offline
MN
Your ice door flapper isn't sealing properly, could be frosted up or the gasket could be getting a little stiff.
Re: Water Dispensing Line freezing up [Re: ironman_gq] #4568600
11/09/17 09:32 AM
11/09/17 09:32 AM
MURICA
MURICA
Yes, I think it's possibly flapper. Any suggestions to fix it?
Re: Water Dispensing Line freezing up [Re: maverickfhs] #4568602
11/09/17 09:33 AM
11/09/17 09:33 AM
PimTac Offline
PimTac  Offline
Just did some DDG searching. It’s a common problem with GE refrigerators. Perhaps a call to GE customer service. They might have a free fix.
http://bustedrefrigerator.com/is-your-refrigerator-water-dispenser-line-frozen
https://www.applianceblog.com/mainforums/threads/1338-GE-Water-Dispenser-Line-keeps-freezing-up
Re: Water Dispensing Line freezing up [Re: maverickfhs] #4568614
11/09/17 09:50 AM
11/09/17 09:50 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
If you store frozen vegetables in the freezer, sometimes one or a few get lodged in there and will block that line. Peas, especially. Lack of flow will contribute to freezing.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Water Dispensing Line freezing up [Re: maverickfhs] #4568659
11/09/17 10:20 AM
11/09/17 10:20 AM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
Do you have a reliable thermometer? Put it in the freezer side and see if you can adjust the freezer temp setting to be "lower" (not as cold) while keeping the temps in the below 32 range.
It could be that your particular fridge has a wacky refigerant charge and the system is chilling a lot more than it should, given the settings on the dials.
Re: Water Dispensing Line freezing up [Re: maverickfhs] #4568695
11/09/17 10:49 AM
11/09/17 10:49 AM
Michigan
motorcity Offline
motorcity  Offline
Michigan
I put the heater kit on mine. Worked for a short while, but its back to freezing up.
Re: Water Dispensing Line freezing up [Re: motorcity] #4568706
11/09/17 10:55 AM
11/09/17 10:55 AM
MURICA
MURICA
What did you do after that? Any other fix?
Re: Water Dispensing Line freezing up [Re: maverickfhs] #4568729
11/09/17 11:19 AM
11/09/17 11:19 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Close up that small air leak and that should fix it...if not, increase the freezer temp slightly.
Thick vs Thin test: 15k / 43k miles complete
