All,
If you own a recent vintage Toyota 4x4, this VOA should interest you.
For the transfer case, Toyota specifies a very special oil for which Amsoil and RedLine do not have a substitute. You have to special order this fluid from Toyota, at a cost of about $55 a quart! I have provided this VOA for your consideration. Looks different than any normal Gear Lube I have seen. It comes in these one-quart cans:
Here is the VOA:
Here is the VOA:
