Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
06/17/18 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
06/17/18 05:18 PM
Car Sales Scammers on Letgo
by ZZman
06/17/18 04:18 PM
Air shocks or Timbren for trailer towing ?
by Oldtom
06/17/18 04:10 PM
Which coil for a 2002 Focus Zetec?
by slacktide_bitog
06/17/18 04:07 PM
Blink -Roadside assistance, any experience?
by MoneyJohn
06/17/18 03:22 PM
Some garage art!
by ls1mike
06/17/18 03:12 PM
California Law
by PiperOne
06/17/18 02:37 PM
honda vs tyc a/c condenser?
by researcher
06/17/18 02:31 PM
To all the Fathers out there.
by rollinpete
06/17/18 01:37 PM
'14 Mercedes E350 Coupe - Castrol Edge 0w40
by FlyPenFly
06/17/18 01:08 PM
2007 Chrysler 4.0L SOHC engine - why 10w-30 req'd?
by 92saturnsl2
06/17/18 12:54 PM
you can see my crack when I dismount a tire
by eljefino
06/17/18 12:44 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
73 registered (08z06, aquariuscsm, 330indy, 2015_PSD, 4WD, 9 invisible), 1450 Guests and 33 Spiders online.
65258 Members
67 Forums
285491 Topics
Page 1 of 2 1 2 >
#4567796 - 11/08/17 12:39 PM Swaying/jumpy rearend when going over some bumps
wing0 Offline
Loc: Ontario, Canada
I am not an expert in suspensions, but just wanted to know which to go after first.
Honda with double wishbone rear suspension. Shocks/springs are factory and gone through 270k km of mostly highway driving. Swaybar links has been replaced at dealership through warranty once around 130-140k km due to knocking noise.
At bridge expansion joints or lowered manholes, I feel the rearend sways a bit while going over them.
No knocking noise yet from the links, but one of them feels quite easy to move side to side if I try wiggling with my hand. The other one has more resistance.
However, I don't know if this swaying/jumpy feeling is coming from the shocks or because the links are worn out, just not to the point where they're knocking.
Any thoughts?
#4567798 - 11/08/17 12:42 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
Bottom_Feeder Offline
Loc: Occupied Virginia
270k on the shocks/struts? I think I see the issue. wink
#4567802 - 11/08/17 12:45 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
fenixguy Offline
Loc: NC
^^This^^
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
#4567828 - 11/08/17 01:01 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
Drew99GT Offline
Loc: Colorado Springs
Yea; I bet those shocks are totally blown. Try the bounce test.
#4567846 - 11/08/17 01:15 PM Re: Swaying/jumpy rearend when going over some bumps [Re: Drew99GT]
wing0 Offline
I did do the bounce test and they all settle back to steady state after 1 bounce. Going over normal speedbumps at posted/normal speed seems fine.
Maybe I should rephrase when it happens, when expansion joints are at an angle where the rear tires don't go through the joint in sync, then I can feel the swaying. The best example is an overpass ramp connecting 2 highways that completes a 90 degree turn over time. The same is true when driving manhole, only one side of the rear goes over. That's when I sort of feel it.
I am wondering if sway bar links can have this effect or it's purely from shocks?
I have some swaybar links in my Rockauto cart and not sure if it's worthwhile to try and replace them first.
#4567851 - 11/08/17 01:22 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
Sway bar end links are easy to tell if they need replacing via a visual inspection. Shocks and struts, not so much unless they are leaking. The bounce test is not very accurate. I still vote for them being the problem.
What year/make/model is this?
#4567871 - 11/08/17 01:50 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
nthach Offline
Loc: California
I vote shocks. At that age if you're willing to rebuild the suspension, new bushings and sway bar links won't hurt either.
#4567875 - 11/08/17 01:55 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
mightymousetech Offline
What kind of tires do you have?
Double wishbone rear suspension?
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4567890 - 11/08/17 02:08 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
Drew99GT Offline
Grab the sway bar links and wiggle them; if they're worn that much, you'll feel it. Likewise, the bushings can be checked visually; if they're all cracked up, they need replacing.
#4567952 - 11/08/17 03:06 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
Dave9 Offline
Loc: Cincinnati, USA
At 270K there is unquestionably wear on anything factory that wears.
Shocks/struts, spring seats, wishbone bushings, links, etc., even springs by now. If it's a strut tower I would replace the whole tower w/spring as a unit at this point. If you just want to know which are contributing the most, shocks/struts do tend to wear out in less than half the time of the rest, but hitting a pothole/curb/etc too hard can have less predictable wear or damage.
The question is how much to invest in a vehicle with that many mi, how much longer you expect to keep it and how much that "sways a bit" matters. Most people would just slow down going over such things and would have replaced their original shocks/struts 150K miles ago and have done it again by now.
The swaybar links, having been replaced at half the mileage it has now, it would make perfect sense that they're due for it again.
Edited by Dave9 (11/08/17 03:09 PM)
#4567958 - 11/08/17 03:10 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
Rand Offline
Loc: NE,Ohio
Knowing what vehicle would help..
a 2007 f150 would be different vs a 1999 focus zx2
2017 Jeep Cherokee Trailhawk V6
#4567983 - 11/08/17 03:32 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
EdwardC Offline
Loc: Chicago, IL
So, your description of the issue does slightly point to something with the sway bar. One wheel bumps would twist the sway bar while a bump on two wheels of the same axle would not really engage the sway bar. However, sway bar end links don't actually do anything to control the sway. If connected at both ends and not making noise, it's not causing your rear end to jump around.
My guess for a Honda with a rear double wishbone suspension with that mileage to be a 90s Civic (not sure if the rear is a true double wishbone or a multi link) or a Prelude. I'm guessing if it was an NSX of S2000, he would have mentioned that.
Either way, the sway bar, shock and any bushings/ball joints are the major items that allow/restrict movement.
#4567997 - 11/08/17 03:47 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
wing0 Offline
Thank you all for your comments so far.
It's a 2006 Acura CSX(Civic).
Left rear swaybar links can be wiggled much easier with hand versus right side.
I know I should replace the shocks at the very least, but hoping to do that after winter since we got tons of potholes here around this time frame.
I guess if car is out of alignment could also cause this? Even though car is tracking straight right now and alignment was done early 2017.
I am hoping to keep the car till around 350k km which will be about 1.5 to 2 years worth of driving.
Edited by wing0 (11/08/17 03:47 PM)
#4568190 - 11/08/17 07:02 PM Re: Swaying/jumpy rearend when going over some bumps [Re: Bottom_Feeder]
Kuato Offline
Loc: Colorado
Yup! Your car most definitely needs new shocks.
Thick vs Thin test: 15k / 43k miles complete
#4568237 - 11/08/17 07:47 PM Re: Swaying/jumpy rearend when going over some bumps [Re: wing0]
SumpChump Offline
Loc: Upper Midwest by the Lakes USA
I had a new 2011 Sentra that had the rearend jolt to a side when going over a bump on either side. It also ran at 4-5k RPM stone cold just to do 20mph when below 50F. Apparently a feature of the transmission warmup programming. For me driving at 5k at 20mph for the four miles to work was unacceptable even after I was told by Nissan regional.... "its is normal". Great interior and features though.
Page 1 of 2 1 2 >
