I have a 149cc Kohler on a Toro mower. It has the auto choke with the vacuum thingy attached. It's hooked to the carburetor...not the engine. It runs very (VERY) well, but while running, it blows (a steady dribble from the vent hose) oil out. It's not overfilled..it's actually about 1/2 way up the safe range.
Suggestions? I figured it had been turned over and needed to purge the oil from the vent. After running ten minutes, it still comes out at a steady (tiny) stream.
