Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
24 registered members (billt460, 4WD, bmod305, Black_Thunder, AnthemBassMan, bfleeman, 2 invisible), 484 guests, and 61 spiders.
Topics286,264
Posts4,905,497
Members67,589
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
2017 Cadillac ATS 2.0T AWD - PCV modifications? #4567438
11/08/17 07:32 AM
11/08/17 07:32 AM
Great White North.. eh
webfors Offline OP
webfors  Offline OP
Howdy bitog,
purchased a new 2017 ATS 2.0T AWD. Reading the Cadillac forums there is consensus that intake valve deposits will be a problem due to intake junk from recirculated oil vapor/mist.
Many owners have opted to install a catch can. With the 3 PCV system on this engine it is not trivial.
I noticed there is limited experience with this engine on Bitog. However, this issue is not unique to the LTG.
The Caddy comes with 4 years free maintenance, which means it will be getting the dealer oil changes. They use Dexos G2 syn blend. I'll have to dig if I want to know which brand of oil.
Suggestions, recommendations and feedback welcome.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w30, Mopar MO-349
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: webfors] #4567506
11/08/17 09:34 AM
11/08/17 09:34 AM
PimTac Offline
PimTac  Offline
The dealer might be using a generic oil that does meet the specs. That could change too depending on contracts. As for the catch can, will that provoke a reaction from the dealer?
Cannot see signatures any longer so it doesn’t matter.
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: webfors] #4567515
11/08/17 09:39 AM
11/08/17 09:39 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
You don't want to lube your valve stems?
How much oil would be going in there? (should be less than a pint over an OCI)
I wouldn't go near it.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: webfors] #4567525
11/08/17 09:49 AM
11/08/17 09:49 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
Where is the evidence that a problem exists? I say, leave it alone.
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: webfors] #4567531
11/08/17 09:53 AM
11/08/17 09:53 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Save your money.
Use something like Amsoil power foam through the throttle body regularly but just before an oil change or suck up a proper cleaner through a vacuum line regularly but at oil change time and use a properly rated high quality synthetic oil in between.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: webfors] #4567542
11/08/17 10:07 AM
11/08/17 10:07 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Catch cans are a sore point with me because by design they cant work very effectively. For every ounce it "catches" many times more gets by it. Its like catching a cup full of water out of a 10 gal bucket that spilled on the carpet and declaring it would have been worse if it didn't catch this.
It takes a oil removing coalescing filter to filter oil mist out of the air stream, an element small enough to fit under the hood would quickly be overwhelmed on a car engine.
IMO leave well enough alone and deal with whatever when it comes. I think buying an extended power train warranty on anything with a turbo or DI is a good idea.
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: WobblyElvis] #4567545
11/08/17 10:09 AM
11/08/17 10:09 AM
webfors Offline OP
webfors  Offline OP
http://www.cadillacforums.com/forums/cad...e-cleaning.html
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: Trav] #4567548
11/08/17 10:13 AM
11/08/17 10:13 AM
webfors Offline OP
webfors  Offline OP
I'm leaning towards not doing anything. My historical car purchasing habits imply that I will have this car traded before the warranty is up.
However, there are reports of the engine running rough prior to the warranty being up (as a result of carbon buildup on the intake valves), which results in some dealer <> customer wrestling. That being said, I have only seen these reports on 13' and 14' model years. Not the newer years, most likely due to low mileage.
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: StevieC] #4567551
11/08/17 10:15 AM
11/08/17 10:15 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
Originally Posted By: StevieC
Save your money.
This. My CTS is direct injected. All I do is at each oil change spray a full can of intake cleaner thru with motor running. It washes past the valves and removes atleast something because gray water will come out the pipes when doing this. I'm at 147k miles and still idles smooth as glass. I think if I had a carbon problem I would feel a rough idle and perhaps some missing. Runs great just like new.
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: webfors] #4567555
11/08/17 10:18 AM
11/08/17 10:18 AM
webfors Offline OP
webfors  Offline OP
Here's an interesting question. I asked the dealer to change the oil before delivery, since the car had a bit of mileage on it. They agreed and on the work order the part number for the oil is listed as #88865715.
I searched high and low and the only reference to that part number are service work orders found online that list this oil as 0w20!!
Does anyone have any experience with GM oil part numbers to confirm?
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: GMBoy] #4567569
11/08/17 10:32 AM
11/08/17 10:32 AM
webfors Offline OP
webfors  Offline OP
Save your money.
146k miles!? Fantastic. Great to hear.
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: GMBoy] #4567571
11/08/17 10:33 AM
11/08/17 10:33 AM
webfors Offline OP
webfors  Offline OP
Save your money.
Which intake cleaner? GM specific product?
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: webfors] #4567573
11/08/17 10:33 AM
11/08/17 10:33 AM
webfors Offline OP
webfors  Offline OP
Interesting link with great pictures from a gentlemen who has a lot of experience with investigating this issue:
http://www.cadillacforums.com/forums/cad...ml#post17031185
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: GMBoy] #4567579
11/08/17 10:38 AM
11/08/17 10:38 AM
webfors Offline OP
webfors  Offline OP
Save your money.
Another question, what oil and filter do you use?
Re: 2017 Cadillac ATS 2.0T AWD - PCV modifications? [Re: StevieC] #4567682
11/08/17 11:59 AM
11/08/17 11:59 AM
CA
The Critic Offline
The Critic  Offline
CA
Save your money.
If you have done some homework on this matter before posting, you will find that deposits on DI engines are a completely different animal than traditional deposits. These deposits are extremely heavy and are not easily removed without Walnut Blasting or manual scraping. Chemical cleaners injected thru the intake tract will “barely make a dent” on the deposits if there is a decent amount accumulated.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Page 1 of 3 1 2 3
