High Lead Redline 5W40 thoughts? Ty
by Pajero
06/22/18 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
06/22/18 09:32 PM
Sparking discussion - excellent article
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Rotella CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
06/22/18 06:32 PM
Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
06/22/18 05:13 PM
Xfinity mobile cell service
by jay929
06/22/18 04:37 PM
Fuse "failure"
by dlundblad
06/22/18 04:32 PM
Do you Bluetooth your phone and car?
by ZZman
06/22/18 04:20 PM
Hastings air filters
by Spitter
06/22/18 04:18 PM
2011 Town and Country remote started itself.
by mrsilv04
06/22/18 04:06 PM
Vaughan Hammer and Superbar $10 Sam's
by hatt
06/22/18 04:03 PM
Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
101 registered (69Torino, 01rangerxl, 4WD, Ag76, 9050lx, 11 invisible), 1430 Guests and 43 Spiders online.
65299 Members
67 Forums
285802 Topics
Page 1 of 2 1 2 >
#4567050 - 11/07/17 04:54 PM 149 cc Kohler blowing oil out of vent
yeehaw1960 Offline
Loc: Nebraska
I have a 149cc Kohler on a Toro mower. It has the auto choke with the vacuum thingy attached. It's hooked to the carburetor...not the engine. It runs very (VERY) well, but while running, it blows (a steady dribble from the vent hose) oil out. It's not overfilled..it's actually about 1/2 way up the safe range.
Suggestions? I figured it had been turned over and needed to purge the oil from the vent. After running ten minutes, it still comes out at a steady (tiny) stream.
#4567087 - 11/07/17 06:13 PM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
yeehaw1960 Offline
Loc: Nebraska
A video of the thing running and dripping oil, and a picture of the fiasco.
I changed oil to straight 30wt and it did exactly the same thing. Looks like any vent mechanism it has is internal.
https://www.youtube.com/watch?v=W6GF81dBj14&feature=youtu.be
#4567131 - 11/07/17 07:01 PM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
JTK Offline
Loc: Buffalo, NY
Sure does seem to run well. I'm wondering if there's some type of screen or separator plate that's out of place, causing oil to get thrown out the breather?
I don't see forceful gas out the tube, possibly pointing to a head gasket problem or such.
Does this have an oil dipstick that needs to be read a certain way? Just trying to rule out too much oil.
Edited by JTK (11/07/17 07:01 PM)
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
#4567133 - 11/07/17 07:01 PM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
motor_oil_madman Online   content
Loc: Houston, Texas
That's your PCV hose their should be a barbed fitting on the inside of the air box.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4567137 - 11/07/17 07:03 PM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
Loc: Houston, Texas
You must be getting blow by for it to do that.
#4567197 - 11/07/17 08:07 PM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
jeepman3071 Online   content
Loc: Storrs, Connecticut
Wow that is a decent amount of oil coming out. Does the engine have good compression?
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (32k) - Castrol Edge Euro 0w40, MANN HU816X
#4567202 - 11/07/17 08:12 PM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
Warstud Offline
Loc: MIchigan
Maybe the valve that allows the air out is stuck open.
#4567227 - 11/07/17 08:33 PM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
MParr Offline
Loc: Georgia
This seems to be a somewhat common problem with that Kohler engine.
http://www.lawnmowerforum.com/showthread.php/13566-Kohler-courage-spitting-oil-out-breather-tube
2013 KIA Optima EX 2.4L. Now: Castrol Magnatec GTX 5W30 synthetic & STP S2808ML
2017 Ford Escape SE 2.0T Now: Pennzoil Platinum 5W30 & Motorcraft 910s
#4567379 - 11/08/17 02:22 AM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
yeehaw1960 Offline
Loc: Nebraska
I'll adjust the valves tomorrow first thing. Any idea of the clearances? .004 or so?
THANKS!!!
#4567447 - 11/08/17 07:06 AM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
MParr Offline
Loc: Georgia
Manual states: .003 -.005 on intake and exhaust.
#4567544 - 11/08/17 09:09 AM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
JTK Offline
Loc: Buffalo, NY
It can't hurt on checking the valve clearance, but i'm struggling to understand what this would have to do with oil being pushed out of the crankcase.
#4567622 - 11/08/17 10:16 AM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
MParr Offline
Loc: Georgia
One more thing, you may have a blown head gasket. To verify a blown head gasket, pull the dipstick after running the engine for a while. If there is smoke coming from the oil fill tube, you have a blown head gasket.
https://www.gardnerinc.com/manuals/pdf/i..._REV%200510.pdf
#4567664 - 11/08/17 10:48 AM Re: 149 cc Kohler blowing oil out of vent [Re: JTK]
+1
Valves out of adjustment may cause it to be hard to start or have lower compression if one is hanging open, but I can't really see that being an issue.
My bet is head gasket issue, blow by from rings (poor design) or a PCV issue.
Does this engine blow any smoke out of the exhaust?
#4567734 - 11/08/17 11:44 AM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
yeehaw1960 Offline
Loc: Nebraska
I'll look at the valve clearances, but I too think that's not going to be it. It starts on first pull and runs very smoothly. Can't believe the head gasket is blown (or even slightly compromised). Time to look at the dozen or so engines I have laying around (in my way). Will check for smoke from dipstick tube too. Getting a late start!
#4567807 - 11/08/17 12:48 PM Re: 149 cc Kohler blowing oil out of vent [Re: yeehaw1960]
boraticus Offline
Loc: Canada
Almost sounds like blow-by increasing crankcase pressure thus forcing oil out the crankcase ventilation tube.
OP mentions that the oil reading is showing half full. What's the process for reading the oil level? Cap screwed down or cap up? That will make a difference regarding how much oil is actually in the crankcase.
Page 1 of 2 1 2 >
