Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
The Beater is Even Uglier Now!
by Delta. 03/19/19 08:28 AM
Oil viscosities at 200 to 225 F
by Snagglefoot. 03/19/19 07:35 AM
What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
tbann, LisaMC, chops, drsoils, Gbear
67554 Registered Users
102 registered members (77GrandPrix, AandPDan, aircooled, AdditiveOCD, 12 invisible), 2,117 guests, and 65 spiders.
Topics286,064
Posts4,901,784
Members67,554
Most Online2,967
Mar 10th, 2019
Car front left axle shakes #4567031
11/07/17 05:25 PM
11/07/17 05:25 PM
Mississippi
PhuongFU Offline OP
PhuongFU  Offline OP
Mississippi
When Iím driving at higher speeds like on the interstate, you can feel a slight wobble coming from left from axle. And when braking you can definitely feel it. I change the rotor but problem still persists. The shaking comes from the car, no shaking in steering wheel or gas pedal so Iím guessing it isnít steering or brake related. Can also feel a little jolt/play when going over bumps like rail road tracks. Iím guessing the problem is either a control bushing or wheel bearing? Any advice will be helpful. Thank you.
Re: Car front left axle shakes [Re: PhuongFU] #4567040
11/07/17 05:34 PM
11/07/17 05:34 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
If it was a wheel bearing you would hear it.
Try rotating tires front to back and see if it changes.
Re: Car front left axle shakes [Re: Rand] #4567057
11/07/17 06:05 PM
11/07/17 06:05 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
I've had multiple bearings fail w/o noise.
Assuming you've ruled out brake issues and a bad tire (have you?):
1) Jack up the car safely. Grasp the wheel at 9 and 3 and rock it. If there's play in this dimension only, suspect a tie rod end.
2) Grasp at 6 and 12. If rocking this direction also, suspect bearings. In this dimension only; ball joints.
3) Spin the wheel and grasp the coil. If detectable vibration, suspect bearings.
If this all checks out, you can also consider bushings and an upper strut mount if equipped. Car?
There will be suspension arrangements that can make this less than perfect a diagnosis, but it has worked reliably for me on numerous occasions.
Re: Car front left axle shakes [Re: PhuongFU] #4567076
11/07/17 06:37 PM
11/07/17 06:37 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Rotate the tires and see what happens. Probably a bad belt in the tire
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Car front left axle shakes [Re: Nick1994] #4567117
11/07/17 07:48 PM
11/07/17 07:48 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Yep , what I was thinking , as a first step , any way .
Best of luck to you all , :-)
Wyr
God bless
Re: Car front left axle shakes [Re: PhuongFU] #4567186
11/07/17 08:50 PM
11/07/17 08:50 PM
out there
spasm3 Offline
spasm3  Offline
out there
I've had inner tie rods, with enough play to ocillate at certain speeds. I agree with moving the tire/wheel first. Wheel bearings can go bad without making noise, eventually they will but not always at first. Get under the car, look for loose tie rods, ball joints etc. Then move that tire to the rear.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Car front left axle shakes [Re: PhuongFU] #4567203
11/07/17 09:12 PM
11/07/17 09:12 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
first step needs to be oro_o's suggestion...check the front end out.
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: Car front left axle shakes [Re: justintendo] #4567284
11/07/17 11:02 PM
11/07/17 11:02 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
That would have been my second suggestion . In addition to bad suspension parts , do not forget bad / messed up struts / shocks . Also , perhaps bad / loose fasteners .
And do not forget / overlook , bad / loose CV Joint for FWD .
Wyr
God bless
Re: Car front left axle shakes [Re: PhuongFU] #4567306
11/07/17 11:47 PM
11/07/17 11:47 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
It is not a cardone / reman axle is it? I have had them vibrate in my Cadillac. Swapped for a used OEM and it was gone.
2001 F150 5.4L 140k miles
2013 Nissan Juke Nismo 80k
2000 Honda S2000 183k
1998 BMW 328i 170k
Re: Car front left axle shakes [Re: PhuongFU] #4567355
11/08/17 01:55 AM
11/08/17 01:55 AM
Mississippi
PhuongFU Offline OP
PhuongFU  Offline OP
Mississippi
I canít rotate tires because they are staggered but tires are new. Tie rod was changed out a few years back with Moog tie rod and it still looks good with no play. Tomorrow I will jack it up and rest the control arms on jack stands and will wiggle the wheel and see what happens. And Iíll report back to you guys.
Re: Car front left axle shakes [Re: Oro_O] #4570990
11/11/17 04:30 PM
11/11/17 04:30 PM
Mississippi
PhuongFU Offline OP
PhuongFU  Offline OP
Mississippi
So I had some help from a friend thatís a mechanic and we found out it was my front control arm bushing. He says I should buy the entire arm with bushing and ball joint already in place. Is it an easy change?
Re: Car front left axle shakes [Re: PhuongFU] #4571007
11/11/17 04:46 PM
11/11/17 04:46 PM
Mississippi
PhuongFU Offline OP
PhuongFU  Offline OP
Mississippi
They next question is mevotech or flennor?
Re: Car front left axle shakes [Re: PhuongFU] #4571012
11/11/17 04:47 PM
11/11/17 04:47 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
What kind of car is it? Control arms are straightforward and relatively easy to do.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Car front left axle shakes [Re: PhuongFU] #4571044
11/11/17 05:17 PM
11/11/17 05:17 PM
ME
eljefino Offline
eljefino  Offline
ME
Mevotech is pretty cheezy but there's also the chance that the same chinese factory is stamping out many names. Never heard of flennor.
Re: Car front left axle shakes [Re: PhuongFU] #4571065
11/11/17 05:45 PM
11/11/17 05:45 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I am cheap . If the bushing is bad , I would probably just replace the bushing .
Best of luck , :-)
Wyr
God bless
