Employer Exit Interview.
by JustinH
8 minutes 33 seconds ago
Ceratec vs. Archoil 9100
by Phishin
12 minutes 9 seconds ago
Acclaim radiator ?
by urrlord
14 minutes 23 seconds ago
Understanding Idle Control Circuit
by artbuc
Today at 07:59 AM
Annual drain on Mobil1 5w20 high mileage?
by ryan2022
Today at 07:36 AM
Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
Today at 06:58 AM
Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
ronw1309, Suth31, yamahaboy125, Turboholic, TrpNY
65284 Registered Users
82 registered (Alex_V, 2004tdigls, ARCOgraphite, andyd, A310, ArrestMeRedZ, 9 invisible), 1352 Guests and 36 Spiders online.
65284 Members
67 Forums
285691 Topics
Page 1 of 2 1 2 >
#4566341 - 11/06/17 10:04 PM Mopar 10yr/150K Coolant question
Mantooth Offline
Loc: Southern Indiana
I'm needing to fill the reservoir tank in my Durango. Owners manual isn't much help since it only recommends the Mopar fluid and doesn't give a spec. I do know it has the 10yr/150k in it.
Today, I went to NAPA for some items. I mentioned needing a jug of coolant for my 2014 Durango and Dex-cool is what they said would work. I didn't have my glasses with me so I couldn't read the small print on the jug. After getting home, I pretty sure this is the wrong stuff.
Anyone know what brand is compatible with the factory fill? Or do I just need to bite the bullet and get a jug from the dealer?
Thanks..
'14 Durango AWD 3.6,(mine) Hav ProDS 5w30/Napa Gold
'15 Journey AWD 3.6, (wife's) Napa Syn 5w20/Napa Gold
'01 F250 4x4 7.3PSD, 126k, M1 TDT 5w40/MC
#4566354 - 11/06/17 10:22 PM Re: Mopar 10yr/150K Coolant question [Re: Mantooth]
fisher83 Offline
Loc: Omaha, NE USA
Should be the Zerex G-05.
2015 Toyota RAV4 Limited 41k
2016 Nissan Frontier Pro-4x 18k
#4566358 - 11/06/17 10:27 PM Re: Mopar 10yr/150K Coolant question [Re: fisher83]
zrxkawboy Offline
Loc: SD
No, G-05 is HOAT...a '14 should have Chrysler's (purple) OAT. Not sure which aftermarket coolant may be compatible.
"Think of all the Ford owners who will someday want an automobile." John Dodge
#4566365 - 11/06/17 10:47 PM Re: Mopar 10yr/150K Coolant question [Re: Mantooth]
Nyogtha Offline
Loc: San Antonio, TX
I'd bite the bullet and get the purple Mopar coolant. There is an orange dyed Fiat coolant that's compatible but that's all I'm aware of.
I would not use Dexcool, Dexclones, or G-05 myself.
Mopar changed from G05 HOAT to their own (& Fiat) OAT in MY 2013.
Edited by Nyogtha (11/06/17 10:50 PM)
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
#4566389 - 11/07/17 12:05 AM Re: Mopar 10yr/150K Coolant question [Re: Mantooth]
Nyogtha Offline
See SAE article below
http://articles.sae.org/11284/
#4566395 - 11/07/17 12:45 AM Re: Mopar 10yr/150K Coolant question [Re: Mantooth]
Nyogtha Offline
Price for 50/50 mix on Amazon looks reasonable for top-off purposes.
https://www.amazon.com/Mopar-Year-Mile-Coolant-Premixed/dp/B017DP43ZC
Concentrate price on Amazon isn't outrageous either
Amazon Mopar OAT
Edited by Nyogtha (11/07/17 12:57 AM)
#4566413 - 11/07/17 02:24 AM Re: Mopar 10yr/150K Coolant question [Re: Mantooth]
The_Nuke Offline
Loc: D/FW Metroplex
Yep, what they gave you would work in the 2012 and below models, but they moved to the OAT kind (purple kool-aid looking stuff) in 2013, so it is incompatible with yours. In fact, it's highly incompatible if I remember correctly, as in, top off with that stuff and you'll get sludge deposits pretty quickly (depending on how much is mixed in obviously).
2012 Dodge Charger
- R/T with pursuit pkg.
- 5.7L + A5 + 2.65
"..it's got cop tires, cop shocks, cop suspension..."
#4566420 - 11/07/17 03:32 AM Re: Mopar 10yr/150K Coolant question [Re: zrxkawboy]
demarpaint Offline
Loc: NY
That is correct! HOAT and OAT do not mix, mixing them causes bad problems, there is a lot of info about that on the web. 2013 was a transition year, some early 2013's had HOAT, others used OAT, at least in Wranglers, and there were a lot of problems when the two were mistakenly mixed. The good news is one is dyed orange HOAT the other, OAT is purple.
Mixing the two will cause a sludge in the cooling system, and in many cases flushing will not remove it. Replacing the radiator, thermostat, heater core, and repeated flushing of the block is the only fix, very costly.
God Bless Our Troops
#4566495 - 11/07/17 06:55 AM Re: Mopar 10yr/150K Coolant question [Re: Nyogtha]
Mantooth Offline
I order a jug from Amazon a few week ago when I noticed it was getting low. They sent me the 5yr/100k jug instead of 10yr/150k. No issues sending it back other than it was a little of a hassle. After that, I resorted to finding a local store that had an aftermarket replacement.
Amazon Mopar OAT
#4566515 - 11/07/17 07:21 AM Re: Mopar 10yr/150K Coolant question [Re: demarpaint]
Mantooth Offline
I'll just bite the bullet and drive out to my dealer a pick up a jug of Mopar coolant. Better safe than sorry.
#4566524 - 11/07/17 07:35 AM Re: Mopar 10yr/150K Coolant question [Re: Mantooth]
2010Civic Offline
Loc: Minnesota
I agree with going to the dealer. You will pay a little extra but it isn't something you buy very often.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Honda oil filter
54,061 miles
#4566614 - 11/07/17 09:09 AM Re: Mopar 10yr/150K Coolant question [Re: Mantooth]
Panzerman Offline
Loc: Port Orange, Florida
Some sites say there is little difference in OAT and HOAT and others say it's like nixing cement. For top off I think you would be fine. I have seen some bad mixtures and the orange sludge that comes from it, but that was after many years and I have yet to see antifreeze litterally clog the system. Look at the head gasket sealers they send through there and that doesn't even clog it.
Glycol, dexcool or wonder coolants would be bad to mix with OAT but I think these Jeeps had more going on since it was just the Jeeps that had issues. Just my opinion and I would color match if I could in a new car.
Edited by Panzerman (11/07/17 09:10 AM)
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
#4566659 - 11/07/17 09:45 AM Re: Mopar 10yr/150K Coolant question [Re: fisher83]
440Magnum Offline
Loc: Texas
NO! G-05 is now the "older" Chrysler spec coolant. The current formula is a pure OAT, not a HOAT. As such it is probably similar to DexCool, but I believe its an OAT made with an organic acid OTHER than 2 EHA found in DexCool. Until the aftermarket catches up and creates a coolant that specifically meets the FCA spec, I'll be sticking with dealer-sourced Mopar fluid for my wife's JGC. Or for top-off less than maybe a quart, just use distilled water. Its not going to shift the freeze/boil points that much.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
#4566676 - 11/07/17 09:58 AM Re: Mopar 10yr/150K Coolant question [Re: Mantooth]
KrisZ Offline
Loc: Toronto, Canada
I ended up buying from the dealer when I needed to top off our minivan. I paid close to $50 for a 50/50 jug. Needles to say, I will fully switch to G-05 at about 5 year mark.
What makes this coolant so [censored] expensive?
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4566684 - 11/07/17 10:07 AM Re: Mopar 10yr/150K Coolant question [Re: Mantooth]
Sayjac Offline
Loc: The Old North State
If I had to pick a current aftermarket AF for the newer FCA, it would be Peak Global Lifetime. Also a Long Life OAT AF with no 2eha found in Dex OAT.
The Amazon prices linked for the Mopar, don't look too crazy.
Page 1 of 2 1 2 >
