Hi guys,
I am about to do an oil change on my car and deciding on which filter to use.
The problem is options in Australia are somewhat limited and I would prefer a synthetic material.
I can get this filter:
http://www.rycofilters.com.au/products/syntec
However it is not available in the size I need which is:
Seam Diameter 71.00mm
Overall Height 101.00mm
Seal Outside Diameter 66.00mm
But rather in this size:
Seam Diameter 69.50mm
Overall Height 86.00mm
Seal Outside Diameter 64.00mm
Both filters have a bypass valve of 15psi.
I run 6k mile OCI on Shell Helix Ultra oil.
Engine has relatively high miles however is clean inside.
Would I be OK running the smaller filter or should I stick to the designated one?
