Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
3.5EB Gen II: Oil & Interval
by Gene K. 09/19/18 06:09 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
21 registered members (Ablebody, BlakeB, c502cid, carloz, CaspianM, 4 invisible), 867 guests, and 40 spiders.
Topics290,698
Posts4,848,443
Members66,021
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Royal Purple Synthetic #4565313
11/05/17 09:34 PM
11/05/17 09:34 PM
Winnipeg, Canada
Tony67 Offline OP
Tony67  Offline OP
Winnipeg, Canada
hi guys i came across this youtube video showing a comparison between these synthetics and Royal purple to my surprise came in one of the last in terms of flow in cold temperatures. I was planning on running with royal purple in my suzuki sx4 for the winter up here in Northern Canada. Now i'm second guessing my choice. Would you guys agree there's better oil brands for cold temperature winter use?
Heres the link.
https://m.youtube.com/watch?v=uQ_vxdO_9nc
Re: Royal Purple Synthetic [Re: Tony67] #4565323
11/05/17 09:45 PM
11/05/17 09:45 PM
FL, USA
shurguywutt Offline
shurguywutt  Offline
FL, USA
If you are worried about cold start definitely use a 0w instead of 5w. RP is overpriced, I prefer Valvoline or M1 any day
2008 Pilot 2WD J35Z1 148k
Maxlife Blend 10w-30
FRAM Ultra Synthetic
Fumoto F106SX
Re: Royal Purple Synthetic [Re: Tony67] #4565328
11/05/17 09:51 PM
11/05/17 09:51 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
cool video If it get's that cold where you are I'd go with a 0w oil plus you can thin oil by using some mmo or rislone ...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive184k miles
Last Change;
Penn. Plat. HM. 5w30
Fram xg8a, Fram CA8141
I like my oil (slippery).
Re: Royal Purple Synthetic [Re: Tony67] #4565333
11/05/17 09:55 PM
11/05/17 09:55 PM
WY
sloinker Offline
sloinker  Offline
WY
You may also look into an ester based synthetic as they have superior cold pour points in many comparisons.
0W-30 is impressive for cold pour point. Noack is better with the 5W-30 but probably isn't as much of a concern with those cold temperatures. Mobil 1 is great and cheaper than Red Line but doesn't match its cold pour performace per published specifications.
https://www.redlineoil.com/0w30-motor-oil
Re: Royal Purple Synthetic [Re: Tony67] #4565384
11/05/17 10:53 PM
11/05/17 10:53 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Up there, I'd be all over 0W oils smile
And no, I would not use RP ...
Re: Royal Purple Synthetic [Re: Tony67] #4565399
11/05/17 11:04 PM
11/05/17 11:04 PM
Winnipeg, Canada
Tony67 Offline OP
Tony67  Offline OP
Winnipeg, Canada
I just put the royal purple about a month ago with a new oil filter. Can i drain the rp and pore in the mobil 1 and leave the oil filter on place without changing it yet? Can the mobil mix with a bit of the rp that was left in the oil filter? Or do i need to do a complete oil change?
Bit upset about buying 5- 5 liter jugs of this royal purple a few weeks back.
Re: Royal Purple Synthetic [Re: Tony67] #4565405
11/05/17 11:09 PM
11/05/17 11:09 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
All my family in North Dakota get Mobil 1 0W-20 recommended to them by me.
Re: Royal Purple Synthetic [Re: Tony67] #4565426
11/05/17 11:31 PM
11/05/17 11:31 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
It's fine to leave the filter on. Personally, I wouldn't extend the oil change very far, but there won't be any damage done by mixing the two oils.
To be honest, I wouldn't even dump the RP just yet. I would run it out until the first time the temperature hit -10 degrees F or so, then take it some place to have them change the oil for me because that's just too dang cold! Canada That should give you another month or so and wouldn't be as much of a waste of oil.
Re: Royal Purple Synthetic [Re: Tony67] #4565472
11/06/17 01:43 AM
11/06/17 01:43 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
For that kind of money, buy some real synthetic oil -- Conklin.
Re: Royal Purple Synthetic [Re: Tony67] #4565492
11/06/17 04:15 AM
11/06/17 04:15 AM
Texas
4WD Offline
4WD  Offline
Texas
If you go to the product specs on 0w20 or 0w30 Mobil 1 ~ they tend to show rotary test values (MRV and cranking tests)
Id just run a 0w in winter and until time to change oil. How much do you drive in a year? Can you use the RP part of the year?
Re: Royal Purple Synthetic [Re: Tony67] #4565499
11/06/17 05:24 AM
11/06/17 05:24 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
LOL, went to have a look at their Product Data Sheet to comment on what's pretty obvious within it, and you have to create an account to view it...makes linking to it pretty hard.
When you look at their data sheets, most of it has pretty rubbish pour points and cold temperature performnace in some grades, leading one to the point of view that their 0W40 in particular IS synthetic, while a bunch of their other grades IN THE SAME LINE are more GrIII than anything else.
That's not a hater talking...that's a data sheet.
A data sheet that you have to sign up to see...
They are a joke...
Re: Royal Purple Synthetic [Re: Tony67] #4565500
11/06/17 05:27 AM
11/06/17 05:27 AM
'Stralia
'Stralia
Oh, but regardless...if you need -40C performance, you need a 0W...they are actually rated for that.
Re: Royal Purple Synthetic [Re: Tony67] #4565519
11/06/17 06:23 AM
11/06/17 06:23 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
My car has an oil pump so I'm not too sure how relevant that video is...
I'm assuming you have some sort of pan or block heater?
I'd leave the RP in.
"Zed's dead baby, Zed's dead."
Re: Royal Purple Synthetic [Re: Tony67] #4565563
11/06/17 07:24 AM
11/06/17 07:24 AM
New England
Virtus_Probi Offline
New England
While I was in warranty, I preferred to use 5W30 because that was what Subaru recommended. Somebody pointed me to this cool list of 5W30 synthetic VOAs (that is, unfortunately, almost 5 years old now and hasn't been updated) and I saw that RP was not one of the stronger CCS performers.
http://www.pqiamerica.com/March2013PCMO/Marchsyntheticsallfinal.html
So RP 5W30 was about 40% thicker than M1 in the CCS test...probably not the end of the world, but I thought it could be noticeable on a really cold night during a ski trip to the Whites with my car parked outside (which I do most weekends in season). There were other things about the M1 formulation that I liked, so it was an easy choice for me to pick that over RP and even save some money.
Now that I'm out of warranty, I am very comfortable with using a 0W30 and probably will do so in December...not sure yet what I'm going to use, though. I have been keeping an eye out for the new M1 0W30 AFE bottles with a dexos1 Gen 2 license, haven't seen them yet.
2014 Forester XT, 86000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: Royal Purple Synthetic [Re: Tony67] #4565566
11/06/17 07:27 AM
11/06/17 07:27 AM
Canada
camrydriver111 Offline
Canada
I would not change it just because of the video but I wouldn't buy it again.
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
Page 1 of 3 1 2 3
