Zipcode error
by aquariuscsm
06/24/18 01:36 PM
NHRA drag racing Racing question??
by daddi
06/24/18 01:33 PM
Milesyn 5w30 5 gal pails $50.94 w/prime
by Samrsnow
06/24/18 01:20 PM
Removing Broken Bathtub Drain
by Warstud
06/24/18 01:15 PM
Buffer Pads
by TheLawnRanger
06/24/18 01:10 PM
Recommend an oil to me... Pennz, M1, Castrol...?
by chinee
06/24/18 12:39 PM
Filter for Hydro Gear ZT2800 - Toyota???
by Lancruza
06/24/18 12:39 PM
Motul 5W30, 3000KM/12 mo, 06 Acura RSX-S 161K KM
by lemaitrix
06/24/18 12:38 PM
DeWalt dcf887b 3spd impact driver
by JC1
06/24/18 12:34 PM
Grit guard wash board
by JC1
06/24/18 12:22 PM
Truck Lug Nut Spikes
by ET16
06/24/18 12:12 PM
Tier III fuel is on the way
by ZZman
06/24/18 11:53 AM
ACDelco Dexos 0W20 UOA
by DanMiller
06/24/18 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
06/24/18 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
06/24/18 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
06/24/18 10:18 AM
What to do when your Glock jams
by bigj_16
06/24/18 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
06/24/18 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
06/24/18 09:03 AM
Brisket flat on charcoal
by 04SE
06/24/18 08:45 AM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
92 registered (aquariuscsm, alphadog, AnthemBassMan, 330indy, BAJA_05, andyd, 7 invisible), 1562 Guests and 34 Spiders online.
65312 Members
67 Forums
285914 Topics
Page 1 of 2 1 2 >
#4565219 - 11/05/17 06:54 PM Would SUPERTECH syn be ok for 10k?
SumpChump Offline
Loc: Upper Midwest by the Lakes USA
Wondering if a run on 10k on SuperTech 5w-20 full syn would be ok in my 2013 Camry 2.5L 2AR-FE? Car has 65k on it.
The oem filter always looks ok after 10k with 5k oil change. It does 50miles a day at 55, reaches what should be full temp of course. We have four seasons if that is a factor with some mild chances for dilution and or some high temp exposure if the 10k rund through a summer and into a winter.
Just wondering.
#4565222 - 11/05/17 06:58 PM Re: Would SUPERTECH syn be ok for 10k? [Re: SumpChump]
slacktide_bitog Offline
Loc: USA
Yes, ST syn should be just fine for 10k with no problems. You may also want to consider the ST 0w20
Mahle makes a great cartridge filter for your 2AR smile
#4565223 - 11/05/17 07:01 PM Re: Would SUPERTECH syn be ok for 10k? [Re: slacktide_bitog]
SumpChump Offline
Yes, second person in a day I have hear good things about Mahle.
I got the 5W on a Wal-Mart web special (one that wasn't a "web error" which was sweet). Indeed back to 0W next time I stock my shelves.
#4565226 - 11/05/17 07:02 PM Re: Would SUPERTECH syn be ok for 10k? [Re: SumpChump]
danez_yoda Offline
Loc: texas
Heres one data point.
https://bobistheoilguy.com/forums/ubbthr...h_5#Post4508304
For highway miles, it should be fine but the only way to be sure is to run say 7500 miles and do a UOA to make sure things are OK to 10K.
Make sure your filter is up to the task.
Edited by danez_yoda (11/05/17 07:04 PM)
#4565233 - 11/05/17 07:12 PM Re: Would SUPERTECH syn be ok for 10k? [Re: SumpChump]
JohnnyJohnson Offline
Loc: Wet side WA
Your car and a UOA will tell your for sure. Run one at 6000 and see what you get. One OIC 4000 miles less is going to cost you squat!
2004 Toyota Corolla 121790
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4565248 - 11/05/17 07:28 PM Re: Would SUPERTECH syn be ok for 10k? [Re: SumpChump]
NH73 Offline
Loc: Pa, USA
It is GF-5 which what Toyota recommends, so should be fine. But Toyota does recommend 0w20.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
#4565282 - 11/05/17 07:57 PM Re: Would SUPERTECH syn be ok for 10k? [Re: NH73]
Loc: Wet side WA
2006 Duramax 74047
#4565410 - 11/05/17 10:13 PM Re: Would SUPERTECH syn be ok for 10k? [Re: SumpChump]
Linctex Offline
Loc: Waco, TX
I'd run it for 10,000 and not lose any sleep over it.
#4565412 - 11/05/17 10:15 PM Re: Would SUPERTECH syn be ok for 10k? [Re: SumpChump]
69GTX Offline
Loc: Connecticut
Probably can do it. But, considering that you can buy other better rated synthetics as cheap or cheaper on rebate (M1, PP, QSUD, Synpower, etc.) why do it? Are they selling SuperTech fully syn for under $12/jug now?
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4565415 - 11/05/17 10:19 PM Re: Would SUPERTECH syn be ok for 10k? [Re: SumpChump]
jakewells Offline
Loc: Cave City KY
i run the supertech dino in my trucks for 10,000 with out problems.
1994 Ford F150 302 4R70
Chevron Delo SAE 30 CF/SL Fram XG8A
1978 Chevy Nova 250 I6 3 on the tree.
Rotella 10W40 Fram TG30
#4565459 - 11/05/17 11:38 PM Re: Would SUPERTECH syn be ok for 10k? [Re: SumpChump]
lawrencerd Offline
Loc: NC
Does a 0w-20 ST Syn exist? I haven't seen it here, but I'd be interested in it.
#4565461 - 11/05/17 11:39 PM Re: Would SUPERTECH syn be ok for 10k? [Re: SumpChump]
Mainia Offline
Loc: Upper midwest
I thought I saw 2 reports that barely made it to 10,000 miles. Itís a 7,500 mile oil.
#4565467 - 11/06/17 12:10 AM Re: Would SUPERTECH syn be ok for 10k? [Re: Linctex]
Merkava_4 Offline
Loc: Clovis, CA
That's because you got plenty of money to buy a new engine I'm assuming.
#4565501 - 11/06/17 04:32 AM Re: Would SUPERTECH syn be ok for 10k? [Re: SumpChump]
SilverFusion2010 Offline
Loc: Crawfordville FL
There are better oils for the same money.
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
#4565502 - 11/06/17 04:37 AM Re: Would SUPERTECH syn be ok for 10k? [Re: Merkava_4]
dlundblad Offline
Loc: Indiana
We just don't have as much money as you and can't afford to dump top tiered synthetics at 1.5k.. crackmeup
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
Page 1 of 2 1 2 >
