Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
46 registered members (alarmguy, Char Baby, bullwinkle, AZjeff, Ctreasure, 7 invisible), 1,060 guests, and 43 spiders.
Topics295,207
Posts4,929,909
Members66,711
Most Online2,553
Oct 27th, 2018
195-55-16 instead of 205-55-16 #4565084
11/05/17 04:33 PM
11/05/17 04:33 PM
Wa
Corollaman Offline OP
Wa
Any issues using 195 instead of 205 for snow tires? I found a set for much cheaper than the stock 205. Thanks
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4565087
11/05/17 04:36 PM
11/05/17 04:36 PM
ME
eljefino Offline
eljefino  Offline
ME
I'd go with 195/60 if they make it.
Another issue would be load range if it's less than the car calls for.
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4565092
11/05/17 04:38 PM
11/05/17 04:38 PM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
Definitely 195/60. Closer to stock diameter. .3" larger diameter and more sidewall. Both better for snow.
2010 Mazda RX8 Sport - 37k miles - ????
2006 Toyota Matrix XR AWD (Wife) - 130k miles - Valvoline Max Life 5w30
Re: 195-55-16 instead of 205-55-16 [Re: eljefino] #4565109
11/05/17 04:58 PM
11/05/17 04:58 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Agreed. If not, the 195/55 would likely be of no concern.
Narrower is generally better for snow.
The OP should do as you recommend and ensure that the weight capacity of the tires he proposes to use is adequate for the maximum front and rear axle maximum rated weights of the car as can be seen on the placard located on the driver's door jam.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4565118
11/05/17 05:07 PM
11/05/17 05:07 PM
USA
slacktide_bitog Offline
USA
What year is your Corolla? smile
I know that 205/55-16 is a very common size, which means you will have much more options
Re: 195-55-16 instead of 205-55-16 [Re: slacktide_bitog] #4565155
11/05/17 05:43 PM
11/05/17 05:43 PM
Wa
Wa
It's a 2012. I just found a like new set of sno tires P195-55-16 at a very good price. Otherwise I would go with the stock P205-55-16.
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4565176
11/05/17 05:59 PM
11/05/17 05:59 PM
USA
USA
What tire is it?
For 205/55-16, there's the Hankook iCept evo2 W320 for only $87 each from Simple Tire .
I also found the ContiWinterContact TS830P to be cheaper in 205/55 than in 195/55.
Re: 195-55-16 instead of 205-55-16 [Re: slacktide_bitog] #4565212
11/05/17 06:42 PM
11/05/17 06:42 PM
Wa
Wa
What tire is it?
Toyo Observe studless less than 500 miles. Set of 4 $150.
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4565224
11/05/17 07:01 PM
11/05/17 07:01 PM
USA
USA
So they're used, *and* the wrong size? no-no
And like others have said, the smaller tires will have a lower load rating, which may be unsafe.
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4565236
11/05/17 07:17 PM
11/05/17 07:17 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
I'd do some research on what the lowest load rated tire that you gen of corolla came with, and if your tires you want come close you should be fine.
Do you have to run 85 mph with a 1000lbs in your car ever? If so, then get the spec'd tire, but if its just you going to work then one size down should be be fine. Just keep an eye on your tire pressures as you are running slightly closer to the edge of their load envelope.
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4565241
11/05/17 07:24 PM
11/05/17 07:24 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I would check the DOT code on those used tires as well. It might be getting older and the rubber may be getting harder and losing traction. Might be good for another year or two, for which it might still be a decent deal, you'd have to evaluate that.
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4565551
11/06/17 06:09 AM
11/06/17 06:09 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Going to down in size is not a good idea.
The reduced load carrying capacity also means a greater likelihood of a tire failure. It also means less fuel economy.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4565604
11/06/17 07:08 AM
11/06/17 07:08 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
You may install this P195/55R16 at a higher inflation pressure than a P205/55R16 for equivalent OEM load.
Btw, what's the recommended pressure for ori P205/55R16 at placard, and it's load index as on tire sidewall ?
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4565712
11/06/17 09:44 AM
11/06/17 09:44 AM
PA
faramir9 Offline
faramir9  Offline
PA
The problem is that some tire shops will not install a tire with lower-than-OE load spec. For that matter, some shops will not install a non-OE size tire even if it does meet the load (and speed) spec. And as far as I know, no one makes a 195/60R16 tire.
With all that said, I would not hesitate to run the 195/55R16 winter tires if you can find a shop to install them, AND if they pass inspection from both you and a tire pro; they have lot of good tread left; you bump up the pressure a few psi; and you plan to drive conservatively, seldom if ever getting near the weight limit for your vehicle. Also be aware the speedometer and odometer will be off, slightly.
That's a lot of ifs but if you take all that into account I think you are good to go.
2005 Corolla LE, 1.8L
Valvoline MaxLife HM full-syn 5w-30
Continental TrueContact 195/65R15
Re: 195-55-16 instead of 205-55-16 [Re: Corollaman] #4567225
11/07/17 08:33 PM
11/07/17 08:33 PM
ME
eljefino Offline
eljefino  Offline
ME
Says who, the seller? Look their specs (including original tread depth) up online and bring a tread gauge.
I got 4x Champiros in 195/65/15 brand new after rebates for $109 last year and bet it could be repeated this year.
