Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
41 registered members (2015_PSD, 87sammy, 77GrandPrix, alarmguy, aba4430, alcyon, 3 invisible), 629 guests, and 49 spiders.
Topics286,220
Posts4,904,532
Members67,579
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
0w20 oil to reduce engine noise in a Subaru OB? #4564899
11/05/17 02:26 PM
11/05/17 02:26 PM
Lexington, KY
Russell Offline OP
Russell  Offline OP
Lexington, KY
I am looking for a 0W20 synthetic oil for my 2017 Subaru Outback 2.5.that will help reduce engine noise while the engine is cold or warm.
Russell Casey
1995 BMW 525i M50TU 2.5L-6, abt 239K miles. Rebuilt trany.
2017 Subaru Outback Limited 2.5l with Eyesight, 11,000 miles
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Russell] #4564915
11/05/17 02:39 PM
11/05/17 02:39 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
Well, first things first, you won't find a concrete answer. There are a few oils that are held in high regards when it comes to volume, but very little evidence to support them actually being quieter than other brands.
That said, here are a few of those "quieter" oils (in my opinion):
QS Ultimate Durability (API SN)
PPPP/PUPPP (API SN)
Castrol Edge (API SN)
Amsoil
Redline
etc.
The common thread with those oils is a higher moly/boron composition than "average". If I were in your shoes, I'd try any of those that have your required approvals/certifications until you found one that you like.
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Russell] #4564917
11/05/17 02:40 PM
11/05/17 02:40 PM
NEUS
Bandito440 Offline
Bandito440  Offline
NEUS
I had the same engine in my Forester. You won’t find a -20 that will make a difference.
Your choices are using something heavier and risking warranty problems, or ignoring a bit of noise.
Mobil 1 0w-40 or Rotella T6 5w-40 will quiet things down, but they’re heavier than you’re looking for.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Russell] #4564918
11/05/17 02:41 PM
11/05/17 02:41 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
What is the noise? What do you expect an engine oil to do to reduce this noise? Your efforts might be better spent somewhere else.
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Russell] #4564945
11/05/17 02:57 PM
11/05/17 02:57 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Try Castrol Magnatec
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Warstud] #4564959
11/05/17 03:09 PM
11/05/17 03:09 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
I knew I was forgetting one. This is another common "quiet" oil.
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Russell] #4564965
11/05/17 03:16 PM
11/05/17 03:16 PM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
Check in the owner's manual and if it shows I'd go for a 5W20 or 0W30 or 5W30. In my MB which called for 0W40 I used 5W40 as the former was a bit too noisy for my liking upon start-up, this solved the problem.
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Russell] #4565028
11/05/17 04:36 PM
11/05/17 04:36 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
What have you tried in it so far that has been 'noisy'?
In my Accord that also specs 0w20, I've used Mobil 1 EP, then Pennzoil Platinum, then Mobil 1 AFE, and the AFE is what I've kept using since it has made the valvetrain seem noticeably quieter on cold starts. Not a huge difference but there is one. As was suggested above, Castrol Magnatec is next.
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: JustN89] #4565037
11/05/17 04:43 PM
11/05/17 04:43 PM
TX
parshisa Offline
parshisa  Offline
TX
so basically all the oils are quieter but Mobil 1? lol
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: JustN89] #4565038
11/05/17 04:48 PM
11/05/17 04:48 PM
Texas
4WD Offline
4WD  Offline
Texas
PUP was the loudest in my Cruze and tied for last in my 3.5L ecoboost … Iused a digital dB meter …
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Bandito440] #4565039
11/05/17 04:49 PM
11/05/17 04:49 PM
Texas
4WD Offline
4WD  Offline
Texas
Or 30
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: parshisa] #4565043
11/05/17 04:56 PM
11/05/17 04:56 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I switch back and forth between oils I've used Mobil 1 in my Toyota Corolla and you certainly couldn't prove it my me.
2004 Corolla 130005
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Russell] #4565048
11/05/17 04:59 PM
11/05/17 04:59 PM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
I know the 3400 in my sister's 05 impala was a tad on the noisy side all summer, (she bought it at the beginning of summer, and it had just been serviced at the local garage they normally use, not sure what oil he uses, but always uses carquest red filters, and before that it was always the local Chevy dealer)
I did an oil change on it a week ago, with the specified 4 qts of Dexos1 5w30 (AutoQuest - Meijer/Warren) ,and an XG3387.
She came down for a visit yesterday, and it was much quieter. almost unnoticeable.
forgot to check the oil level before starting the OC to see how low it was...
Mine:
13 Ford C-MAX hybrid: MC 5w20, & FL910s (in theory)
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Russell] #4565079
11/05/17 05:23 PM
11/05/17 05:23 PM
PimTac Offline
PimTac  Offline
Is the noise due to a high pressure fuel pump?
Cannot see signatures any longer so it doesn’t matter.
Re: 0w20 oil to reduce engine noise in a Subaru OB? [Re: Russell] #4565105
11/05/17 05:54 PM
11/05/17 05:54 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
I just put M1 AFE in our newer Forester, which has the same engine.
Seems reasonably quiet.
A little noise on engine start is part of what makes a Subaru a Subaru.
The '17 sounds almost exactly like the '09, which is a little scary since these have entirely different engines that just happen to share the same nominal displacement.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Page 1 of 3 1 2 3
