Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
106 registered members (ArrestMeRedZ, aquariuscsm, acme, allgm59, asand1, 928, 6 invisible), 2,062 guests, and 61 spiders.
Topics286,236
Posts4,904,909
Members67,582
Most Online2,967
Mar 10th, 2019
Jack #4564703
11/05/17 10:54 AM
11/05/17 10:54 AM
Texas
WyrTwister Offline OP
Texas
Went by O'Reilly Auto Parts yesterday and found this floor Jack on sale . The one I have , I have had for years ( belonged to my late Dad ) . But it leaks jack oil & I have to top it off from time to time .
Had to jack up the back of the 1991 Caprice , to get both rear wheels odd the ground . Used the old jack to raise the passenger side , jacking against the frame . Shoved a jack stand unser the fraim & let the jack down untill some weight was resting on the jack stand .
Repeated the whole process on the driver side , with the new AC Delco jack . It did not go quite as high as I needed . Do not know if it is just lower to the ground & had to use up some of that reach before it contacted the frame ? Of it just does not have as much reach as the old jack ?
Think I could have used a 4" x 4" wood block between the jack " cradle " & the frame , to make it work better ? I did get the jack stand slid under the frame , so all is well .
Put the AC Delco jack in the trunk of the Sonic . It is lower to the ground .
https://www.oreillyauto.com/detail/acdel...-Ton+Floor+Jack
Best to you all , :-)
Wyr
God bless
Re: Jack [Re: WyrTwister] #4564717
11/05/17 11:12 AM
11/05/17 11:12 AM
texas
danez_yoda Offline
danez_yoda  Offline
texas
they sell rubber jack pucks on amazon. Be careful with 4x4 blocks. They have a grain running through them which could split under high load. them. I woul be more comfortable with glueing and screwing together some plywood to make apuck. By the time you so that, you have saved a dollar but spent a couple of hours.
Re: Jack [Re: danez_yoda] #4564746
11/05/17 11:44 AM
11/05/17 11:44 AM
Texas
Texas
Good tip !
Thanks , :-)
Wyr
God bless
Re: Jack [Re: WyrTwister] #4564751
11/05/17 11:56 AM
11/05/17 11:56 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
A lot of those smaller trolley jacks don't quite have the lift height that you might need, especially for an SUV or even a smaller CUV.
I wouldn't try making too high of a puck to get the height you need, it can get a little iffy with a big spacer between the saddle and the car. Another option if you have enough ground clearance between the jack and the car would be to get a piece or two of 12x2 and put the jack on top of that.
Re: Jack [Re: EdwardC] #4564797
11/05/17 12:39 PM
11/05/17 12:39 PM
Texas
Texas
Another good tip ! :-)
I used to have a " spacer " made from 2 - 3/4" x 12" x 12" pieces of plywood . I then attached 4 pieces of 2" x 4" along the bottom edge . This left a " pocket " in the center , that the 2" x 4" did not cover . The " cradle " of the floor jack fit nicely into this " pocket " .
This added almost 1-1/2" of height and the " pocket kept it from moving on the " cradle " . The 12" x 12" top did a good job , if you were jacking against an oil pan or transmission pan . Spread out the pressure .
I also made a second spacer , the top was the same , but I used 3 - 2" x 4" x 12" on the bottom , to make that solid . This could be stacked on top of the first " spacer " and the wood surface against another wood surface did not slip or slide . The whole thing was stable .
Thanks , :-)
Wyr
God bless
Re: Jack [Re: WyrTwister] #4564949
11/05/17 03:02 PM
11/05/17 03:02 PM
Canada
i_hate_autofraud Offline
Canada
For me, a long wood block, oak in my case, spreads the jack load so
there's no bending or distortion in the under structure of a car that can't
take 1,500 Lb on a jack contact patch that may be as small as 1" dia (in the case
of a small bottle jack).
Re: Jack [Re: WyrTwister] #4564977
11/05/17 03:35 PM
11/05/17 03:35 PM
WA (USA)
Y_K Offline
Y_K  Offline
WA (USA)
a hockey puck from Amazon, Wlamart or your local source. Mine was on sale for a $1.
I general, this is not a very safe design for a jack, but it will do if you are careful.
