I'm getting my ducks in a row for when I drop the transmission pan on my Sierra to change the filter. My pan doesn't have a drain plug, YET! I found this on line and I'm thinking of adding this to the pan before I re-install it. I like this one because it's relatively flat on the outside with no space taken up inside the pan.
I'll need someone to weld this on since I'm not a welder, hence the reason for my topic. How much do you it would cost for someone to weld this onto my pan? Hole will aready be drilled. Just welding it in place and nothing else. Where I live I'm a little limited in the number of welders around, at least the few who advertise. I'd like to get an idea of what to expect. Thanks.
