stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
106 registered members (BeerCan, 2015_PSD, anndel, ArrestMeRedZ, AndyB, 2010Civic, 17 invisible), 1,928 guests, and 66 spiders.
Topics286,430
Posts4,908,103
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
For Any Welders Out There #4564567
11/05/17 08:45 AM
11/05/17 08:45 AM
N. Georgia Mtns
Sierra048 Offline OP
N. Georgia Mtns
I'm getting my ducks in a row for when I drop the transmission pan on my Sierra to change the filter. My pan doesn't have a drain plug, YET! I found this on line and I'm thinking of adding this to the pan before I re-install it. I like this one because it's relatively flat on the outside with no space taken up inside the pan.
I'll need someone to weld this on since I'm not a welder, hence the reason for my topic. How much do you it would cost for someone to weld this onto my pan? Hole will aready be drilled. Just welding it in place and nothing else. Where I live I'm a little limited in the number of welders around, at least the few who advertise. I'd like to get an idea of what to expect. Thanks.
2014 Nissan Frontier
2014 GMC Sierra 1500
Re: For Any Welders Out There [Re: Sierra048] #4564570
11/05/17 08:51 AM
11/05/17 08:51 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
I paid $30 for someone to tig weld a Dorman plug onto mine.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: For Any Welders Out There [Re: Sierra048] #4564575
11/05/17 08:56 AM
11/05/17 08:56 AM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
Thatís an NPT bung and plug, NPT isnít usually used on drains (especially automotive) because it tends to wear out after several uses and not seal well.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: For Any Welders Out There [Re: Sierra048] #4564577
11/05/17 08:57 AM
11/05/17 08:57 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Guy I use pretty regularly welded a bung onto a rear end cover on my GMC for $10 (factory plug in the case hopelessly rusted & stripped). Look for a little local guy who does stuff for cash.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: For Any Welders Out There [Re: tom slick] #4564580
11/05/17 08:57 AM
11/05/17 08:57 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
A little Teflon tape fixes that issue-then the tape wears instead of the fittings.
Re: For Any Welders Out There [Re: Sierra048] #4564581
11/05/17 08:58 AM
11/05/17 08:58 AM
out there
spasm3 Online content
spasm3  Online Content
out there
You can buy a pan with a drain plug cheap enough. I usually don't like a lot of dorman stuff, but i have this pan and its going on when i change the fluid on the avalanche. It feels well made and has a nice drain bolt.
$35 and no welding. A few reviews about incomplete stamping, but mine looks fine and is flat.
https://www.amazon.com/Dorman-265-811-Transmission-Oil-Pan/dp/B002U6ELS4
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: For Any Welders Out There [Re: motor_oil_madman] #4564582
11/05/17 08:58 AM
11/05/17 08:58 AM
Pennsylvania
Slick17601 Offline
Slick17601  Offline
Pennsylvania
Good advice, you want TIG for this application.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: For Any Welders Out There [Re: Slick17601] #4564591
11/05/17 09:07 AM
11/05/17 09:07 AM
Houston, Texas
Houston, Texas
Originally Posted By: Slick17601
[quote=motor_oil_madman]I paid $30 for someone to tig weld a Dorman plug onto mine.
It will leak or look like [censored] with any other method due to being so thin.
Re: For Any Welders Out There [Re: Sierra048] #4564594
11/05/17 09:08 AM
11/05/17 09:08 AM
Houston, Texas
Houston, Texas
I don't recommend the Dorman plug unless you're having it welded.
Re: For Any Welders Out There [Re: tom slick] #4564603
11/05/17 09:17 AM
11/05/17 09:17 AM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
In this situation, NPT will do just fine. It is not sealing against pressure, so it does not have to be torqued heavily. Tape or joint compound (I prefer the compound) will lubricate the threads and ensure no wear on the threads.
Heavy truck axle drains are 1/2 in NPT. They have FPT on the axle and the MPT plug screws in flush so that it is not sticking down and risking damage if the truck is driven over a rock. If a flanged plug sealed with an o-ring is used, there is the danger of it getting sheared off by a rock and the driver only finds out when the axle loses all its oil and starts making horrible sounds or seizes up. I have drained the oil in many axles with MPT plugs and there has never been an issue with the drain plugs.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: For Any Welders Out There [Re: Sierra048] #4564607
11/05/17 09:20 AM
11/05/17 09:20 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
You only get about yes, half the fluid out when changing the transmission fluid. B&M is a long standing performance automatic transmission specialist and offers a drain plug kit for cheap. You'll leave a little in the pan how it's designed, but again, you never get all the fluid changed out regardless.
https://www.amazon.com/80250-Automatic-Transmission-Universal-Drain/dp/B00029WR78
Me: 13' VW GTI 3 door 6 speed manual
Re: For Any Welders Out There [Re: spasm3] #4564615
11/05/17 09:26 AM
11/05/17 09:26 AM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
^Correct answer. It's one of the only Dorman parts I would recommend.
Re: For Any Welders Out There [Re: Sierra048] #4564629
11/05/17 09:41 AM
11/05/17 09:41 AM
One Step Beyond
MasterSolenoid Offline
One Step Beyond
Your on the right track.
What I did was,
* Buy a Hex Nut with the same thread as your current Drain Plug.
* Have Hex Nut welded onto (exterior) Pan.
* Drill Hole thru Pan.
* Use the same Drain Plug you were using before.
Once a year I now do a Drain-N-Fill of Trans Fluid.
Cost: My Nephew did the welding (= free).
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: For Any Welders Out There [Re: Sierra048] #4564640
11/05/17 09:48 AM
11/05/17 09:48 AM
Illinois
tig1 Online content
tig1  Online Content
Illinois
I have tig welded drain plugs for myself and others. Cost; Is the pan aluminum or steel?
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: For Any Welders Out There [Re: skyactiv] #4564641
11/05/17 09:49 AM
11/05/17 09:49 AM
Houston, Texas
Houston, Texas
That's what I had welded on. Lol it's like $7 I didn't have faith in that plastic washer not leaking.
Page 1 of 3 1 2 3
