My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
New TV bad picture some channels
by raaizin. 09/24/18 09:35 AM
Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
89 registered members (4WD, 2009Edge, 10ecfarmer, -SyN-, ad244, ammolab, 6 invisible), 1,956 guests, and 38 spiders.
Topics290,949
Posts4,853,019
Members66,062
Most Online3,590
Jan 24th, 2017
Radiator cap never really gets super hot to touch? #4564445
11/05/17 02:49 AM
11/05/17 02:49 AM
Gatineau QC Canada
TheMidnightNarwh Offline OP
Gatineau QC Canada
I noticed the other day the radiator cap never gets real hot to touch. I can feel some warmth to it but not burning hot. The upper rad hose does become hot to touch and the car doesn't overheat.
Is something wrong, should I be worried and check for something or it's fine?
Re: Radiator cap never really gets super hot to touch? [Re: TheMidnightNarwh] #4564459
11/05/17 04:42 AM
11/05/17 04:42 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Does your cooling system need to be topped off?
Re: Radiator cap never really gets super hot to touch? [Re: TheMidnightNarwh] #4564467
11/05/17 05:24 AM
11/05/17 05:24 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
If the upper hose is hot, you don't overheat, if heater works good, you are fine. My radiator cap is never hot to the touch. I am assuming you do maintain proper level.
The "thinking" man's friend.
Re: Radiator cap never really gets super hot to touch? [Re: OneEyeJack] #4564779
11/05/17 12:28 PM
11/05/17 12:28 PM
Gatineau QC Canada
Gatineau QC Canada
No I filled it up about 2 weeks ago, checked every day and then to make sure it was wasn't leaking and looks good. Always coolant to the top when I take it off in the morning.
Re: Radiator cap never really gets super hot to touch? [Re: TheMidnightNarwh] #4564788
11/05/17 12:35 PM
11/05/17 12:35 PM
Michigan
ZZman Offline
ZZman  Offline
Michigan
Is your cap on a plastic tank or a metal radiator?
2003 Mercury Grand Marquis. Rotella T6 Multi-Vehicle oil
2008 Sebring Hardtop convertible. Rotella T6 Multi-Vehicle oil
2006 Kawasaki Vulcan 900 LT. Amsoil Metric 10w-40
Re: Radiator cap never really gets super hot to touch? [Re: ZZman] #4564824
11/05/17 01:10 PM
11/05/17 01:10 PM
ME
eljefino Offline
eljefino  Offline
ME
yeah this. How would your cap get hot? You have boiling water pushing on a rubber gasket under a metal disc under a spring under the part you put your hand on.
If you've ever noticed the handle on a wood stove, it's a spring, so it doesn't conduct heat very well.
Re: Radiator cap never really gets super hot to touch? [Re: eljefino] #4564900
11/05/17 02:27 PM
11/05/17 02:27 PM
Gatineau QC Canada
Gatineau QC Canada
It's not on the overflow tank, it's on the rad itself.
So you're saying it's normal it doesn't get hot? All the videos I watch they say if your cap is hot don't open, even says so on the cap itself. But it's never really hot like that.
Re: Radiator cap never really gets super hot to touch? [Re: TheMidnightNarwh] #4565196
11/05/17 07:24 PM
11/05/17 07:24 PM
ME
eljefino Offline
eljefino  Offline
ME
Back 30 years ago with brass radiators the radiator tank would conduct heat to the cap fairly efficiently through the mounting boss.
And if you remove a cap holding back pressure it could cause instant explosive steam, no fun.
Grab the upper radiator hose to get a feel for temp, even with 1/4" of rubber they get pretty hot.
Re: Radiator cap never really gets super hot to touch? [Re: TheMidnightNarwh] #4566323
11/06/17 10:29 PM
11/06/17 10:29 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Probably some air trapped under the cap acting as an insulator. If you're brave you can burp the system. Take an old rag and very slightly start to remove the cap, just enough that you hear it hiss. When it gurgles tighten it back.
Or just wait until it's cold and top up the rad. I kinda like the hot purge though.
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: Radiator cap never really gets super hot to touch? [Re: TheMidnightNarwh] #4567554
11/08/17 10:18 AM
11/08/17 10:18 AM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
Are the caps with a lever to release pressure still sold? Sounds to me like a warm cap would mean an air gap at the tank top. The 528e uses a pressure cap on the expansion tank. I once drove a '62 F250 with bad radiator. It was summer and we took it on a 200 mile trip to rescue my '62 Bug. We carried water jugs and stopped 5 times to add water. That was one of the bug's many good points. A shop fab'ed tow rig pinned to the front beam and they towed like they weren't even there grin2
Thick oil is better grin2
